2 Replies Latest reply on Oct 21, 2008 3:47 PM by Newsgroup_User
    Get a  property value in a list of lists
    Level 7
      Hello:
      I need to get this value "Gb" from this list
      a=[["Gb":114,"E":10],["Ab":243]]
      When I write this I get an error
      put a.getPropAt(1)
      Can you help me please?
      thank you.
        • 1. Re: Get a  property value in a list of lists
          robdillon Most Valuable Participant
          put a[1].getPropAt(1)
          • 2. Re: Get a  property value in a list of lists
            Level 7
            I have a suspicion that Rob's answer isn't going to work for you,
            because it depends on you knowing that "Gb" is the first element of the
            first list. If you do in fact know this, then your lists should just be
            regular linear lists, the "Gb": part serves no purpose.
            Unless I am mistaken, what you have is not even a correctly formed
            property list, so you won't be able to use any of the property list
            functions anyway. A property list would look like this:
            a=[[#Gb:114,#E:10],[#Ab:243]]
            In this case you could easily write a handler that searches for the
            first occurrence of #Gb. It wouldn't matter which list it was in, or in
            which position within the property list it was located. This function
            will return the value of the property passed (or VOID if it isn't found).
            on getPropValueFromListofPropLists myProp, myListOfPropLists
            returnValue = VOID
            repeat with x in myListOfPropLists
            if x.findPos(myProp) then
            returnValue = x.getProp(myProp)
            exit repeat
            end if
            end repeat
            return returnValue
            end
            put getPropValueFromListofPropLists(#Gb,a)
            -- 114
            put getPropValueFromListofPropLists(#Ab,a)
            -- 243
            put getPropValueFromListofPropLists(#XXX,a)
            -- <Void>
            I strongly recommend you use a correct property list. Using the symbol()
            function you can turn strings like "Gb" into symbols (#Gb)
            Arielle wrote:
            > Hello:
            > put a.getPropAt(1)
            > thank you.
