Expand my Community achievements bar.
SOLVED
Visual Composer: How do I make an list item menu change to all pages where menu appears
Avatar
Level 2
Hi there:
Site is www.avivainsurance.ca
I am trying to use Visual Composer to make an edit to the phone number on the site based on mbox variable. User arrives from campaign A set campaign A in the variable and serve up a different phone number.
Problem is that the phone numbers exist in a menu that appears on every page. And when I make my edit in Visual Composer it only changes the value for that one page I made the edit on.
So I ask:  How do I make an list item menu change to all pages where menu appears?
Thanks for the help!
P
1 Accepted Solution
Avatar
Correct answer by
Level 10
Hi Ryan,
Please see the below documentation . It will definitely help you to achieve the use case described above :
https://marketing.adobe.com/resources/help/en_US/target/target/t_temtest.html
Thanks & Regards
Parit Mittal
View solution in original post
1 Reply
Avatar
Correct answer by
Level 10
Hi Ryan,
Thanks & Regards
Parit Mittal
