4 Replies Latest reply on Mar 12, 2017 4:47 AM by arpitgupta26
    Using profile parameters
    pamh555 Level 1
      I am working on a POC for calling profile parameters in an mbox, and I see plenty of instruction for how to do this in Target Classic, but nothing in Target Standard. Is anyone doing this now?
        • 1. Re: Using profile parameters
          Løjmann Level 3
          Hi Pam,
          Can you share a few more details about what you are trying to do, then I'll see if I can help you.
          • 2. Re: Using profile parameters
            pamh555 Level 1
            Absolutely! The goal of the POC is to use an mbox to load profile parameters for authenticated users into Target, then on another device/browser, after authentication, to use those profile parameters to deliver content [specifically populating an ordering widget]. In a use case we would use dynamic values, but for the POC we are great with static.
            e.g., of adding the parameters [per https://marketing.adobe.com/resources/help/en_US/target/target/r_target_behavioral_steps.h tml]
            <div class="mboxDefault">
                <p>Testing adding profile parameters.</p>
            mboxCreate('test_profiles', 'profile.eVar45=eVar45', 'profile.origin=DAL', 'profile.destination=NYC', 'profile.dateOut=02/12/2017', 'profile.dateRtn=02/12/2017', 'profile.paxType=ADT', 'profile.promo=flyfree');
            It is my understanding that in Target Classic, we would then use something like following code in the offer order to 'show' the profile parameter values: ${profile.origin}
            I am not seeing any values passing however.
            • 3. Re: Using profile parameters
              Løjmann Level 3
              Hi Pam,
              If you via a mbox (or the API) populate the specific profile field, then you need to refer to it like ${profile.paxType} and if you created the specific profile field via Profile Scripts, then you would use ${user.paxType}.
              It is therefore important, that you always know how you are populating the specific field within Adobe Target.
              Try that out and let me know if it works :)
              Best Regards,
              Thomas Løjmann
              Lead Architect
              eCapacity A/S
              • 4. Re: Using profile parameters
                arpitgupta26 Level 1
                Hi Pam,
                Just wanna confirm here , I believe you are adding the script code to your mbox.js file , if not than try that.
                For better debugging of mbox call : can you check the mbox trace by adding the url with the below parameter
                You can grab the authentication token from your marketing cloud by going to  [Target -> Setup Tab -> Implementation on Left Rail ]
                Hope this helps .
                Arpit Gupta
