2 Replies Latest reply on Apr 7, 2016 8:47 AM by nmickley
    Cart Recommendations
    nmickley
      Team,
      We would like to show very specific recommendations on the cart page based on a product(s) in the customer's cart.
      For example, we would like to have many of if/then configurations like:
      If a "#2 Pencil" is in a customer's cart then show the "White Eraser".
      Is this possible? If so, can you help point me in the right direction?
      It seems that if it is possible I would do so with a custom attribute (see attachment). However, I can't get the "Select Attribute" dropdown to populate. I have custom attributes in my feed...
      Thanks a ton in advance!
      Nick
        • 1. Re: Cart Recommendations
          Jon Tehero Adobe Employee
          Hi Nick,
          You are exactly right! You can achieve this by passing in the entity.id of the #2 pencil to a profile parameter of your choosing, such as "profile.lastItemAddedToCart"
          Example 1:
              function targetPageParams() {
                return {
                "profile.lastItemAddedToCart": "[ENTITY-ID-FOR-THE-NUMBER-2-PENCIL]"}
          Example 2 (with a sample entity.id of 1337-273 for your #2 pencil to show syntax)
                return {
                "profile.lastItemAddedToCart": "1337-273"}
          These examples assume you are using Premium Recommendations implementation. If not, you can do the same by passing the profile.lastItemAddedToCart into an mboxCreate function
          Then you can create a criteria using the following settings: "Based on" > "Custom Attribute" > Select Attribute > "profile.lastItemAddedToCart"
          Note: in order to see the profile.lastItemAddedToCart appear in the dropdown, you will need to fire off a call to our servers and it will lazy load into the UI.
          • 2. Re: Cart Recommendations
            nmickley Level 1
            Jon,
            Thank you for your help. I'll give this a go.
            Best,
            Nick
