9 Replies Latest reply on Jan 15, 2018 1:38 AM by trishas77569438
    Can't finde the format of the reportInterval option for the Target API
    marc_blecher Level 1
      Hi!
      Since the AB activity performance report is restricted to 100 days for daily resolution I have to split my API calls up in several intervals and merge the result manually afterwards.
      But the input format of the option reportInterval is not documented (or respectively I haven't found it yet). :(
      The API usually delivers time intervals as a string in the following format: 1477036800000-1477386000000
      But if I provide this format for the reportInterval the API call fails with the following error message:
      {"httpStatus":400,"requestId":"pVrZB7VcKx0Q9Vllz6KHrN9V2ty3rhy7","requestTime":"2016-10-25T08:54:30.852Z", "errors":[{"errorCode":"typeMismatch.activityPerformanceReportParameters.reportInterval","message":"wrong parameter value [1477036800000-1477386000000] for parameter [reportInterval];","meta":{"reportInterval":"1477036800000-1477386000000"}}]}
      What is the correct intervall format for this call?
      Regards
      Marc
