1 Reply Latest reply on Sep 30, 2016 3:08 AM by ParitMittal
    search&promote facet flow expects json while seach is working with xml response
    asn_177 Level 1
      We are using search&promote for seach on our site.
      The usage is prettymuch inline with the OOTB searchpromote components in libs/cq/searchpromote path.
      We receive an XML from s&p server.
      We now are looking at having facets, I tried putting linklist facet on results page to get facets but it failed, so looking at logs and going through jar I noticed that facet component in its dialog calls a servlet (path+facetList.json) this servlet calls searchpromoteservice's get facetList method.
            String facetList = this.searchpromote.getFacetList(memberId, accountNo);
            JSONObject facets = new JSONObject(facetList);
            out.write(facets.toString());
      but it then tries to convert string response as JSON object and fails since the URL http://sp10050b5b.guided.ss-omtrdc.net/design/sp_id=MyID-MyAccount&sp_fn=facets results xml rsponse.
      Only changing this setting in search & promote to return json would suffice or I will have to make any other changes as well?
      Regards,
      Allhad
