4 Replies Latest reply on Oct 2, 2017 10:37 AM by gylesf73140248
    How to target on browser Language using Expression Targets?
    xbarcelona Level 1
      Hi there
      I want to target base on browser language (ex. German) but are not sure how to create a correct Expression-Target for this?
      Not sure if user.header or user.browser should be used and how the correct syntax should look like? Then there is also user.header('accept-language') and user.header('accept') which both seem to fit somehow?
      I created these 3 Expression Targets but am not sure about which one is correct?
      1.return user.header('accept-language')=="de";
      2.return (user.header.indexOf('de') != -1);
      3. return (user.browser.indexOf('de') != -1);
      thanks for your help.
      Nicolas
      • 0. Re: How to target on browser Language using Expression Targets?
        Shekhar_Dhiman Adobe Employee
        Hi Nicolas,
        Thank you for reaching out to Adobe Community.
        I would request you to kindly try and use the below code and see if it helps:
        return user.header('accept-language').indexOf('de') > -1
        Thanks!
        • 2. Re: How to target on browser Language using Expression Targets?
          TheQuinn
          Do you know when this list of languages will be increased as it is incredibly restricted.
          • 3. Re: How to target on browser Language using Expression Targets?
            ParitMittal Level 5
            Hi Mike,
            Thanks for reaching out to Adobe Target community .
            Can you please let us know the browser language on which you want to base your targeting activity?
            Regards
            Parit
            • 4. Re: How to target on browser Language using Expression Targets?
              gylesf73140248
              Hello,
              I am trying to do something similar, but with language and locale.
              What exactly does the user.header('accept-language') get?  usually the accept language has locale and factor weighting included.  Accept-Language - HTTP | MDN
              for example if i wanted to create a profile script differentiating england from united states for english, i would need to parse the language and locale.   would the user.header("accept-language") give me "en-gb" or "en-us"?
              Does using console.log work for debugging these scripts?  It is difficult to use the built in target parameters without know exactly what it provides.
              any help would be much appreciated!
              Gyles Fohl
