2 Replies Latest reply on Oct 15, 2015 7:29 PM by ethang66605959
    mboxLoadSCPlugin
    webthanga
      The mboxLoadSCPlugin is the bridge between the sitecatalyst and target. But this function has a critical random error. In case we use a Adobe tag manager to have the sitecatalyst code, The s_code will be loaded into the website as a third party resource. At this point, The mboxLoadSCPlugin makes the page to go blank whenever a loading variation occurs. When i investigated in mbox.js, I saw a mboxStandardScPluginFetcher used if the DOM is not loaded. Otherwise it goes for mboxAjaxScPluginFetcher. Now the error scenario comes. mboxStandardScPluginFetcher is picked as the DOM is not yet loaded. It proceeds to load function. In the meantime, if the DOM completes loading, the document.write will be over-writing the whole page and make it blank with only a mbox call.
      Fix:  Fix is simple to pick mboxAjaxScPluginFetcher always regard less of DOM load. this works fine.
      Any thoughts on this ?
      • 0. Re: mboxLoadSCPlugin
        ethang66605959
        Raag Shanker wrote...
        Hi
        It would be best if you contact client regarding this as this would involve detailed testing through our engineering team.
        Alternatively you can also submit this as an idea via ideas.omniture.com
        Could you please describe in the detail?
