Expand my Community achievements bar.
Join us for an upcoming in-person Adobe Target Skill Builders event ~~> We're hosting these live learning opportunities to equip you with the knowledge and skills to leverage Target successfully. Learn more to see if we'll be coming to a city near you!
SOLVED
HTTP Status 500 - Unknown action mapping for: entity.recommendations.upload
Avatar
Level 2
Hi Everyone, i have in the past created successful custom recommendations to manually override products of my choice. But in the past few weeks, when i follow this code to upload this script to add products its throwing the HTTP status 500 - unknown action mapping error.
https://recommendations.omniture.com/rest?action=entity.recommendations.upload &client=clientCode&environmentId=184868&clientToken=51dafdf4-f825-4581-a7c0-8ce9db31bd31 &algorithmName=sampleCustomAlgorithm&recommendations=<recommendations><recommendation> <key>1</key><entityId>2</entityId><entityId>3</entityId> <entityId>4</entityId></recommendation></recommendations>
I am literally adding my client name and defining host group as production & giving my client token & its throwing this apache error.
Sri
1 Accepted Solution
Avatar
Correct answer by
Level 8
Hi Sri,
Since this a custom implementation I'd suggest you reach out to Client Care(as you've already done) and seek help from them on this. This may involve close interaction with the engineering team hence the suggestion.
Nikhil
View solution in original post
Avatar
Level 1
Communicate with the developers
Avatar
Level 8
Hi Sri,
Let me check on this with the relevant team. In meanwhile can you ensure that you've referred to https://marketing.adobe.com/resources/help/en_US/rec/r_Uploading_Custom_Algorithm_Data.html and are passing the correct values in the fields required? One observation from this code from the looks of it would on the clientCode. Can you use the clientcode that is displayed under the client API token on the Settings page instead of the literal name add and let us know the result?
Nikhil
Avatar
Level 2
Hi Klara, by developers you  mean the consulting team? I havent found any developer info yet.
Avatar
Level 2
Thanks Nikhil,
Yes i am referring to custom algorithm data, I am using our approriate client API token & algorithmname & parent SKUs. I sent the updated code & my client details in the Incident [Incident: 141217-000110] i launched, i just copied the template here on the forum.
I had success Creating and uploading the algorithm (attaching success message below), but when i go to the backend and create the respective algorithm & set it live it doesn't work on the live site - meaning the entity SKUs are not displayed on the Key Item, i have listed.
_______________________________
<operation>
<status>success</status>
<response>recommendations successfully uploaded</response>
</operation>
Avatar
Level 8
Hi Sri,
Since you've already created a ticket I'll request you to kindly refer to the response by the ClientCare team as they are better equipped to handle this. Do let us know in case you're not getting a timely response and I'll forward it accordingly to the right team.
Nikhil
Avatar
Level 2
Hi Nikhil, I just heard back from the team. Thanks!
I am wondering if i am missing the 3rd step, as the naming and upload process is updating successful, as for the next steps, one goes to the backend on the recommendation and defines the algorithm and choice the mbox and recommendation area right?
Sri
Avatar
Level 8
Yes. That would be correct.
Regards
Nikhil
Avatar
Level 2
Hi Nikhil,
  I have an additional question, I get this popup message "The mbox: Rec_Prod_Disp is already being used by the recommendation: PDP Right Recs. Are you sure you want to activate this recommendation group? popup when". When i am activating the custom recommendation set. But i want this new custom recommendation to sit in the exact same div as the current right rail recommendation (image & template div attached), that is displaying viewed also viewed algorithm. I am having problems doing that, whenever i go forward and hit ok to the above message the algorithm goes live but the SKU still doesnt reflect the custom SKUs of my choice.
 All i am trying to do is run viewed also viewed on all pages besides few skus in the right hand side rail area of our PDPs. We already have a MBox triggering this, obviously i will be using the same Mbox right? I was told to implement a new Mbox but this looks like is replacing the Current MBOX. Is there any conditions that i can apply to already existing PDP Rec to not be displayed on these SKUs (Where i want Custom Recs to show up)???
Sri
Avatar
Correct answer by
Level 8
Hi Sri,
Nikhil
