1 Reply Latest reply on Oct 24, 2008 7:54 AM by Karl_Sigiscar_1971
    AdvancedDatagrid with a summary row
    Karl_Sigiscar_1971 Level 3
      Hello,
      I have an AdvancedDatagrid with two grouping fields in a summary row.
      Everything works fine when there is no labelFunction associated with it.
      But as soon as I specify a labelFunction, the summary row fields are empty. I need a labelFunction to format dates and numbers.
      How to write a proper labelFunction for an AdvancedDatagrid with a summary row ?
      Regards,
      Karl.
        • 1. AdvancedDatagrid with a summary row
          Okay, I figured it out.
          Now, I have two label functions set at the AdvancedDataGridColumn level for the summary row fields and one labelFunction set at the AdvancedDataGrid level for all the other fields.
          <mx:AdvancedDataGridColumn id="amountTotal" dataField="sumAmount" labelFunction="sumAmountLabelFunction" />
          <mx:AdvancedDataGridColumn id="collectedTotal" dataField="sumCollected" labelFunction="sumCollectedLabelFunction" />
          In order to avoid a null pointer exception on the sumAmount and sumCollected fields in the label function, I use the hasOwnProperty() method to check before access. Otherwise, this exception will happen while expanding the tree.
          private function sumAmountLabelFunction(item:Object, column:AdvancedDataGridColumn):String
          if(item.hasOwnProperty("sumAmount"))
          return this.numberFormatter.format(item.sumAmount);
          return "";
          private function sumCollectedLabelFunction(item:Object, column:AdvancedDataGridColumn):String
          if(item.hasOwnProperty("sumCollected"))
          return this.numberFormatter.format(item.sumCollected);
          return "";
