1 Reply Latest reply on Oct 15, 2015 7:29 PM by chongkan01
    Multivariate AB-Test [Singular Experience Dominance]
      I am implementing a 5x5 multivariate test.  After filling out the campaign with the "designed" components, I activated the test.  In order to see the alternate experiences, I cleared the cookies & cache, but we've only received two experiences out of a possible 25 experiences after dozens of cache clearing.
      The oddity behind the two experiences was that one experience remained by & large dominate. The second experience only showed after clearing the cache 20 times, and then on a follow-up cache-clear it would revert to the first experience.  I tried setting up a separate test, but a similar experience was generated.
      Is there a secondary component missing that will fix the near static experience?  Or is this functionality how the test is setup?
      • 0. Re: Multivariate AB-Test [Singular Experience Dominance]
        - In order to be able to see an experience directly you can use URL parameters for offer level targeting.
        - if you are testing the random/even distribution among offers, you will need to wait until a large amount of visits is counted. I have experienced differences of 30-50 visits at the very beginning of the test, but the bigger the amount of visits gets, the more even the distribution on the experiences gets.
        - If you are stucked with the default experience, then you are probably getting a timeout and TnT is blocking the test for 15 mins.
