0 Replies Latest reply on Oct 23, 2008 11:38 AM by Steve Ewing
    Is RoboHelp_CSH.js still required for RoboHelp 7.0?
    Steve Ewing
      I am creating a series of context sensitive WebHelp files. Up to now I have had no problem with the API calls. The help files were recently added to a new secure internet environment and do not appear to be finding the js files and display as a blank white screen. I looked at the file directory and noted that we do not have RoboHelp_CSH.js in the directory but do have a help_file_name_csh.htm. Does this htm file do the job the RoboHelp_CSH.js file did in earlier versions?
      For now I just need to know whether we should deploy the RoboHelp_CSH.js file or not.
      The issue was raised because of the problem in the new secure environment
      The same files accesssed using an encryption token on an Intranet work fine and open the context sensitive topic files. The new environment is a government environment using an epass encryption functionality. The developers think the help file is losing the relative path to the js files due to a new imposed structure to the application and supporting directories.
