3 Replies Latest reply on Oct 15, 2015 7:29 PM by AllDayDev
    storing an array of strings in a profile attribute
    kevin_faurholt
      I have the following profile script:
      user.arrayTest
      if (mbox.name == "kevins_mbox") {
        user.setLocal("arrayTest", ["hello", "world"]);
        return user.getLocal("arrayTest");
      However, when trying to use the array in a JS offer via: ${user.arrayTest}
      The final output looks like this: [hello, world] - i.e. the quotes are missing and a JavaScript error is thrown.
      According to this document: http://microsite.omniture.com/t2/help/en_US/tnt/pdf/js_expression_cheat_sheet.pdf
      "Script Profile Parameters are found under the mboxes/profiles tab. You
      can write Javascript programs that return any Javascript type (String,
      integer, array, etc)"
      Can someone tell me what I am doing wrong here?
      Many thanks,
      Kevin
      • 0. Re: storing an array of strings in a profile attribute
        AllDayDev Adobe Employee
        With just the snippet above, quotation marks should not be getting removed.
        However, they would not be printed out if you were trying to display/use one of the elements of the array. i.e. you would need to something like this get the quotation marks printed out:
        ['"hello"', '"world"']
        It would be helpful to have some more context.
        What is the JavaScript error you are getting?
        Can you be more specific about what you are doing with ${user.arrayTest}?
        Is it possible to share the page on which you are trying to implement this custom code? a link to the page, the page code, etc.
        - Carey
