1 Reply Latest reply on Oct 15, 2015 7:29 PM by chongkan01
    Is there a way to AB test test results screen with Adobe Target?
    田畑_直
      Adobe target is great for AB testing static HTML pages, but can it be used to AB test dynamic contents? e.g. UI for search results screen etc.
      • 0. Re: Is there a way to AB test test results screen with Adobe Target?
        chongkan01 Level 1
        For testing dynamic content I do the following:
        1- Before attempting to change any content, verify that the content is loading. Check every 300ms for the content presence, once it is loaded, replace it. Abort after say 5 attempts.
        2- If the Search results are returned with a page reload, you can use the URL parameters, or you can add a parameter to the mbox to use a different offer or to do something different if the URL remains the same after reloading.
        3- If the content is loaded with AJAX ( my case ), I simply add an event handler to the Search button and once it is triggered, I start checking for the new content before replacing it.
        To avoid flickering problems, I hide the containers and unhide them after replacing their contents.
