1 Reply Latest reply on Apr 28, 2017 11:11 PM by MC Stuff
    AEM 6.2 Forms configuration manager: database initialization step error (ALC-TTN-011-021)
    Victoria Agafonova Level 1
      I'm trying to install AEM 6.2 Form.
      As an environment i have:
      - Windows Server 2016,
      - MSSQL 2016,
      - WAS 8.8.5.11
      That is WAS Environment settings :
      ************ Start Display Current Environment ************
      WebSphere Platform 8.5.5.11 [BASE 8.5.5.11 cf111649.01] running with process name WIN-E27OMR6R7U2Node01Cell\WIN-E27OMR6R7U2Node01\server1 and process id 2756
      Host Operating System is Windows Server 2012, version 6.2
      Java version = 1.6.0, Java Runtime Version = pwa6460_26sr8fp35ifx-20161110_01 (SR8 FP35), Java Compiler = j9jit26, Java VM name = IBM J9 VM
      was.install.root = W:\IBM\WAS
      user.install.root = W:\IBM\WAS\profiles\AppSrv01
      Java Home = W:\IBM\WAS\java\jre
      ws.ext.dirs = W:\IBM\WAS/java/lib;W:\IBM\WAS\profiles\AppSrv01/classes;W:\IBM\WAS/classes;W:\IBM\WAS/li b;W:\IBM\WAS/installedChannels;W:\IBM\WAS/lib/ext;W:\IBM\WAS/web/help;W:\IBM\WAS/deployto o l/itp/plugins/com.ibm.etools.ejbdeploy/runtime
      Classpath = W:\IBM\WAS\profiles\AppSrv01/properties;W:\IBM\WAS/properties;W:\IBM\WAS/lib/startup.jar; W:\IBM\WAS/lib/bootstrap.jar;W:\IBM\WAS/lib/jsf-nls.jar;W:\IBM\WAS/lib/lmproxy.jar;W:\IBM \ WAS/lib/urlprotocols.jar;W:\IBM\WAS/deploytool/itp/batchboot.jar;W:\IBM\WAS/deploytool/it p /batch2.jar;W:\IBM\WAS/java/lib/tools.jar
      Java Library path = W:\IBM\WAS/lib/native/win/x86_64/;W:\IBM\WAS\java\jre\bin\compressedrefs;W:\IBM\WAS\java\ jre\bin;C:\Windows\system32;C:\Windows;W:\IBM\WAS\lib\native\win\x86_64;W:\IBM\WAS\bin;W: \ IBM\WAS\java\bin;W:\IBM\WAS\java\jre\bin;C:\ProgramData\Oracle\Java\javapath;C:\Windows\s y stem32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C: \ Program Files\Microsoft SQL Server\Client SDK\ODBC\130\Tools\Binn\;C:\Program Files (x86)\Microsoft SQL Server\130\Tools\Binn\;C:\Program Files\Microsoft SQL Server\130\Tools\Binn\;C:\Program Files\Microsoft SQL Server\130\DTS\Binn\;C:\Program Files (x86)\Microsoft SQL Server\Client SDK\ODBC\130\Tools\Binn\;C:\Program Files (x86)\Microsoft SQL Server\130\DTS\Binn\;C:\Program Files (x86)\Microsoft SQL Server\130\Tools\Binn\ManagementStudio\;C:\Progra~1\Java\jdk1.8.0_121\bin;C:\Users\admin\ AppData\Local\Microsoft\WindowsApps;C:\Progra~1\Java\jdk1.8.0_121\bin;.;
      Orb Version = IBM Java ORB build orb626-20161012.00
      ************* End Display Current Environment *************
      That is JAVA_HOME:
      C:\Users\admin>java -version
      java version "1.8.0_131"
      Java(TM) SE Runtime Environment (build 1.8.0_131-b11)
      Java HotSpot(TM) 64-Bit Server VM (build 25.131-b11, mixed mode)
      On the Database Initialization step i recieve an error:
      Here is SystemOut log:
      (The whole log file is attached as a file to this post)
      [4/28/17 20:45:25:522 AST] 000005ab PofBootstrapp E   TRAS0014I: The following exception was logged com.adobe.livecycle.bootstrap.BootstrapException: ALC-TTN-011-021: Bootstrapping failed for platform component [PersistentObjectFramework].  The wrapped exception's message reads:
      null
          at com.adobe.livecycle.bootstrap.bootstrappers.PofBootstrapper.bootstrap(PofBootstrapper.jav a:95)
          at com.adobe.livecycle.bootstrap.framework.ManualBootstrapInvoker.invoke(ManualBootstrapInvo ker.java:78)
          at com.adobe.livecycle.bootstrap.framework.BootstrapServlet.doGet(BootstrapServlet.java:167)
          at javax.servlet.http.HttpServlet.service(HttpServlet.java:575)
          at javax.servlet.http.HttpServlet.service(HttpServlet.java:668)
          at com.ibm.ws.webcontainer.servlet.ServletWrapper.service(ServletWrapper.java:1233)
          at com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest(ServletWrapper.java:782)
          at com.ibm.ws.webcontainer.servlet.ServletWrapper.handleRequest(ServletWrapper.java:481)
          at com.ibm.ws.webcontainer.servlet.ServletWrapperImpl.handleRequest(ServletWrapperImpl.java: 178)
          at com.ibm.ws.webcontainer.filter.WebAppFilterManager.invokeFilters(WebAppFilterManager.java :1114)
          at com.ibm.ws.webcontainer.servlet.CacheServletWrapper.handleRequest(CacheServletWrapper.jav a:87)
          at com.ibm.ws.webcontainer.WebContainer.handleRequest(WebContainer.java:949)
          at com.ibm.ws.webcontainer.WSWebContainer.handleRequest(WSWebContainer.java:1817)
          at com.ibm.ws.webcontainer.channel.WCChannelLink.ready(WCChannelLink.java:200)
          at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleDiscrimination(HttpInboundLink .java:463)
          at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.handleNewRequest(HttpInboundLink.jav a:530)
          at com.ibm.ws.http.channel.inbound.impl.HttpInboundLink.processRequest(HttpInboundLink.java: 316)
          at com.ibm.ws.http.channel.inbound.impl.HttpICLReadCallback.complete(HttpICLReadCallback.jav a:88)
          at com.ibm.ws.tcp.channel.impl.AioReadCompletionListener.futureCompleted(AioReadCompletionLi stener.java:175)
          at com.ibm.io.async.AbstractAsyncFuture.invokeCallback(AbstractAsyncFuture.java:217)
          at com.ibm.io.async.AsyncChannelFuture.fireCompletionActions(AsyncChannelFuture.java:161)
          at com.ibm.io.async.AsyncFuture.completed(AsyncFuture.java:138)
          at com.ibm.io.async.ResultHandler.complete(ResultHandler.java:204)
          at com.ibm.io.async.ResultHandler.runEventProcessingLoop(ResultHandler.java:775)
          at com.ibm.io.async.ResultHandler$2.run(ResultHandler.java:905)
          at com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java:1892)
      Caused by: java.lang.reflect.InvocationTargetException
          at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
          at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:60)
          at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:37)
          at java.lang.reflect.Method.invoke(Method.java:611)
          at com.adobe.livecycle.bootstrap.bootstrappers.PofBootstrapper.bootstrap(PofBootstrapper.jav a:88)
          ... 25 more
      Caused by: com.ibm.ejs.container.UnknownLocalException: nested exception is: com.ibm.ejs.container.UnknownLocalException: nested exception is: java.lang.Exception: See nested Throwable
          at com.adobe.pof.odapi.POFSchemaManagerImpl.synchronizeAll(POFSchemaManagerImpl.java:1127)
          at com.adobe.pof.odapi.POFSchemaManagerRemoteBean.synchronizeAll(POFSchemaManagerRemoteBean. java:511)
          at com.adobe.pof.odapi.EJSLocalStatelessadobe_POFSchemaManagerLocalEJB_626825cc.synchronizeA ll(Unknown Source)
          at com.adobe.pof.odapi.POFSchemaManagerLocalEJBAdapter.synchronizeAll(POFSchemaManagerLocalE JBAdapter.java:135)
          at com.adobe.idp.docmanager.DocumentDBBootstrap.bootstrap(DocumentDBBootstrap.java:51)
          ... 30 more
      Caused by: com.ibm.ejs.container.UnknownLocalException: nested exception is: java.lang.Exception: See nested Throwable
          ... 35 more
      As far as I understood (if right), something is wrong with libs an application is using, possibly, something wrong with Java version. But i can't catch the problem definitely
