1 Reply Latest reply on May 26, 2017 11:55 AM by workflowuser
    AEM Workflow on CM - parameter values
    arunp61160614 Level 1
      What configuration values need to provide for a Correspondence letter post processing to an AEM Workflow (not LC Workflow). UI gives options of 1. Data File Path 2.Attachment Path 3. Layout Path 4. PDF Path.
      If we have NAS mounted file system attached to AEM servers what could be some sample values?
        • 1. Re: AEM Workflow on CM - parameter values
          workflowuser Adobe Employee
          You can give the following
          Post Process - AEM Worflow - Get Signers(This will depend on your workflow name)
          Structure Payload - > Folder( This is the easiest option and recommended)
          Data File Path - > Data.xml( this is the xml data of the CM letter that is stored relative to the payload of the workflow process
          Attachments Path -> Attachments ( Attachments folder to store the attachments . This folder is relative to the payload folder of the the workflow process)
          Layout Path - > can be blank
          PDF Path - > Letter.pdf (The CM Letter that is stored. This node is relative to the payload folder of the the workflow process)
          The path of the payload process is
          etc/fd/dashboard/payload node.
