3 Replies Latest reply on May 18, 2017 6:58 AM by BjornEricsson
    DDX Assembler removing usage rights on the attached pdf
      We have a scenario :
      a livecycle process uses ddx to attach pdf (lets call it child pdf) to the parent pdf. The parent pdf is then apply usage rights.
      At the end of the process it output a the parent pdf with the child pdf attached to it.
      What is causing a problem now is that the child pdf (which used to have usage rights applied) have now got usage right removed.
      We have proved that it works if done manually using acrobat, but somehow its not working in an orchestration using ddx.
