3 Replies Latest reply on Nov 4, 2017 9:41 AM by Naresh Katkam
    Prepopulate values in multifield
    rk39193348 Level 1
      I have a scenario where I need to prepopulate values inside multifield. How to achieve this? Please help?
        • 1. Re: Prepopulate values in multifield
          rk39193348 Level 1
          rk39193348 wrote...
          Also I need the values entered inside my multifield to stay in dialog. How to achieve this?
          My dialog contains 9 text field and 1 dropdown field inside multifield. The values should be prepopulated inside the dialog
          • 2. Re: Prepopulate values in multifield
            James R Green Level 1
            Do you mean the "Drop-down List" Adaptive Form component with Allow multiple selection checked?
            If so, you can just configure with the spanner and add options under the items property.
            Or you can add them with javascript using the Rules editor (hammer tool) and populate with code similar to this:
                var testValues = ["1", "2", "3"]; this.items = testValues;
            • 3. Re: Prepopulate values in multifield
              Naresh Katkam Level 1
              Hi
              you have to write loadcontent event js to prepopulate values.
              In JS you have to add a item first based on the condition check and add values to that multifield.
              example:
              loadcontent js
              if(multifield.getValue()=='')
                   multifield.addItem();
                   if{
                        here you can write your logic to set prepopulate values.
              if you need any further help. just let me know.
              Thanks.
