2 Replies Latest reply on Mar 27, 2017 7:53 AM by joell91868939
    hooking up custom validation
    joell91868939 Level 1
      Hi all.
      AEM (6.2) Forms provides validation facilities for entry fields (email, telephone) for example. We'd like to add new functions that we can share, for more than just simple patterns. In the rules editor (visual editor) there is function list you can use. We'd like to add to that.
      We tried creating this:
       *Validate pattern
        *@param {string} pattern - the pattern to use
       function ValidatePattern(pattern) {
          console.log('hello');
           return (this.value && this.value.match(pattern) == null) ? false : true;
      ..Just to see if "ValidatePattern" would show up in the VisualEditor/FunctionsList. It *does*, but it's not called.
      Suggestions?
      -Joel
        • 1. Re: hooking up custom validation
          Further to this...AEM uses the JCR property "validateExp" to do validation.
          guideRuntime.js:25733:
                      if (validFlag && this.validateExp ) {
            >>              validFlag = this.executeExpression("validateExp");
          guideRuntime.js:25149:
                  _expressionHandler: function (expressionName) {
                      var expFn, returnValue;
                      if (this._compiledExpressions[expressionName]) {
                          expFn = this._compiledExpressions[expressionName];
                          try {
          >>                     returnValue = expFn.apply(this);
          We have the option to override guideRuntime.js (I think) to check our own JCR property for a function we implement, but we'd rather not override core stuff.
          Is there a more standard way to do this to build our own library of functions to validate?
          • 2. Re: hooking up custom validation
            We solved this ourselves.
            Basically you need to:
            1. Create js specifically for validation. Similar to:
                var saveAndAddClickHandler = function(param) {
                    //do something
            2. Now "saveAndClickHandler" is available as a drag and drop function for your button function list.
            Joel
