Expand my Community achievements bar.
Floating Fields in Adaptive forms
Avatar
Level 2
Hello Experts,
I am working on a project where we are creating dynamic Adaptive forms.  Within that Adaptive form, we have a requirement to put Static text (disclosures, information etc). The static text can have some placeholders where data from XML needs to be populated.
For example, it could be a information text such as -
"You credit card allows you to withdraw $10000 a month" . Here the $10000 must be populated from prefill XML.
I know in Livecycle world, we had something like Floating Fields. Do we have something similar in Adaptive forms?
Avatar
Level 8
It's not there for Adaptive Forms at the moment and something we're looking to add to a future release based on demand to drive the priority.  Thanks for indicating the interest and I've let the Product Management team and engineering know there was a request for this capability.
Avatar
Level 2
Oh - Is there a workaround that you know of?
Avatar
Employee
You can use fillable text box in disabled mode(disable via rule).
Avatar
Level 2
deepak k. wrote...
You mean - derive/calculate the entire paragraph as a part of Javascript and assign it to a textbox ?
Well - I did think of this option earlier but I had to let that go because
1) The actual content (paragraph text/language) is in the Javascript. Which means I can't let my business users have control over it OR i can't use the dictionary for multi-language support.
2) I won't be able to handle RichText as TextBox would typically only capture plain Text.
I am actually working on another work-around and unfortunately I haven't been successful so far
I am creating a static text - "Your Credit Card allows you to Withdraw {DollarAmount} dollars".
I am trying to use Rule Editor (Code Editor mode) to write a rule on Initialize event to replace the string {DollarAmount} with the actual value.
Here's what my rule looks like
var strVal = this.value ; // this gives me the static text value strVal = strVal.replace("{DollarAmount}","$10000"); alert(strVal); this.value = strVal; alert("After");
The problem is all the lines are getting executed. I am getting both the alerts, but the rendered Adaptive Form wouldn't update the Static text.
Any idea why it wouldn't let me set the value of TextDraw (static text) element?
Priyank P
