4 Replies Latest reply on Jul 26, 2017 8:51 PM by Sreedhar V
    Sidebar/siderail not coming in touchUI mode
    arjitbansal
      In my instance(http://localhost:4502/editor.html/content/anypage) the siderail option is not coming and the whole toolbar(marked in yellow) is not working. Its working with another instance(http://localhost:4512/editor.html/content/anypage).
      The Edit dropdown, Preview and Annotate are also not working.
      red
      Error.log is giving this:
      16.03.2017 12:22:00.616 *WARN* [0:0:0:0:0:0:0:1 [1489647120248] GET /editor.html/content/geometrixx/en.html HTTP/1.1] libs.granite.ui.components.foundation.admin.page.page$jsp @deprecated /libs/granite/ui/components/foundation/admin/page; Shell 1.0 components are deprecated. 16.03.2017 12:22:00.731 *WARN* [0:0:0:0:0:0:0:1 [1489647120248] GET /editor.html/content/geometrixx/en.html HTTP/1.1] libs.granite.ui.components.foundation.admin.toolbar.toolbar$jsp @deprecated /libs/granite/ui/components/foundation/admin/toolbar; Shell 1.0 components are deprecated. 16.03.2017 12:22:00.757 *WARN* [0:0:0:0:0:0:0:1 [1489647120248] GET /editor.html/content/geometrixx/en.html HTTP/1.1] libs.granite.ui.components.foundation.admin.layouts.toolbar.toolbar$jsp @deprecated /libs/granite/ui/components/foundation/admin/layouts/toolbar; Shell 1.0 components are deprecated.
      How to bring back the siderail in touchUI?
        • 1. Re: Sidebar/siderail not coming in touchUI mode
          hemant_1991 Level 1
          I am also facing the same problem. All of a sudden, the side panel stopped working, edit, annotate no more in function.
          Did you get the solution?
          ************************************************Error log***************************************************************************
          24.03.2017 13:13:45.141 *WARN* [127.0.0.1 [1490341425137] GET /editor.html/content/aia-sg-stp/en/lufthansa-test.html HTTP/1.1] libs.granite.ui.components.foundation.admin.page.page$jsp @deprecated /libs/granite/ui/components/foundation/admin/page; Shell 1.0 components are deprecated.
          24.03.2017 13:13:45.147 *WARN* [127.0.0.1 [1490341425137] GET /editor.html/content/aia-sg-stp/en/lufthansa-test.html HTTP/1.1] libs.granite.ui.components.foundation.admin.toolbar.toolbar$jsp @deprecated /libs/granite/ui/components/foundation/admin/toolbar; Shell 1.0 components are deprecated.
          24.03.2017 13:13:45.148 *WARN* [127.0.0.1 [1490341425137] GET /editor.html/content/aia-sg-stp/en/lufthansa-test.html HTTP/1.1] libs.granite.ui.components.foundation.admin.layouts.toolbar.toolbar$jsp @deprecated /libs/granite/ui/components/foundation/admin/layouts/toolbar; Shell 1.0 components are deprecated.
          • 2. Re: Sidebar/siderail not coming in touchUI mode
            rishim22446870 Level 2
            hemant_1991 wrote...
            Could you try using the incognito mode of browser and check if the functionality works ? The side panel toggle button is hidden in preview mode.
            Also, could you share the browser console logs ?
            • 3. Re: Sidebar/siderail not coming in touchUI mode
              hemant_1991 Level 1
              Issue solved.. The annotate js was corrupted.. Installed the package for the path : /libs/cq/gui/components/authoring/editors/clientlibs/plugin/annotate
              Things are back on track...
              • 4. Re: Sidebar/siderail not coming in touchUI mode
                Sreedhar V
                What package was that ? Where to get that package ?
                Evan I am facing the issue similar to the above one.
