9 Replies Latest reply on Dec 16, 2016 10:59 AM by Mayank Gandhi
    installing AEM forms on JBOSS application cluster
      Every time I try to start the JBOSS master instance to deploy the EARs, I get a Java Fatal Error. How can  I install AEM forms without getting this error?
      D:\jboss\bin>domain.bat -b adobeformsd3 -c domain_mssql.xml
      Calling "D:\jboss\bin\domain.conf.bat"
      Setting JAVA property to "C:\Program Files\Java\jdk1.8.0_112\bin\java"
        JBoss Bootstrap Environment
        JBOSS_HOME: "D:\jboss"
        JAVA: "C:\Program Files\Java\jdk1.8.0_112\bin\java"
        JAVA_OPTS: " -Dadobeidp.serverName=adobeformsd3 -Dadobe.cache.cluster-locators
      =[2718],[2718] -Dfile.encoding=utf8 -Djava.net.prefe
      rIPv4Stack=true -DentityExpansionLimit=10000 -Dcom.adobe.livecycle.crx.integrati
      on.url=http://localhost:8080 -XX:+HeapDumpOnOutOfMemoryError -Dorg.jboss.net.pro
      tocol.file.useURI=false -Dorg.jboss.as.logging.per-deployment=false -Xms1024M -X
      mx4096M -XX:MaxPermSize=1024M -XX:+UseCompressedOops -Djava.net.preferIPv4Stack=
      true  -Djboss.modules.policy-permissions=true  -Djboss.modules.system.pkgs=org.j
      boss.byteman -server"
      Java HotSpot(TM) 64-Bit Server VM warning: ignoring option MaxPermSize=1024M; su
      pport was removed in 8.0
      15:51:20,915 INFO  [org.jboss.modules] (main) JBoss Modules version 1.3.7.Final-
      15:51:21,156 INFO  [org.jboss.as.process.Host Controller.status] (main) JBAS0120
      17: Starting process 'Host Controller'
      [Host Controller] 15:51:22,103 INFO  [org.jboss.modules] (main) JBoss Modules ve
      rsion 1.3.7.Final-redhat-1
      [Host Controller] 15:51:22,448 INFO  [org.jboss.msc] (main) JBoss MSC version 1.
      [Host Controller] 15:51:22,579 INFO  [org.jboss.as] (MSC service thread 1-1) JBA
      S015899: JBoss EAP 6.4.5.GA (AS 7.5.5.Final-redhat-3) starting
      [Host Controller] 15:51:24,088 INFO  [org.jboss.as] (Controller Boot Thread) JBA
      S010902: Creating http management service using network interface (management) p
      ort (9990) securePort (-1)
      [Host Controller] 15:51:24,116 INFO  [org.xnio] (MSC service thread 1-1) XNIO Ve
      rsion 3.0.15.GA-redhat-1
      [Host Controller] 15:51:24,125 INFO  [org.xnio.nio] (MSC service thread 1-1) XNI
      O NIO Implementation Version 3.0.15.GA-redhat-1
      [Host Controller] 15:51:24,286 INFO  [org.jboss.remoting] (MSC service thread 1-
      1) JBoss Remoting version 3.3.6.Final-redhat-1
      [Host Controller] 15:51:24,586 INFO  [org.jboss.as.remoting] (MSC service thread
       1-2) JBAS017100: Listening on
      [Host Controller] 15:51:26,135 ERROR [org.jboss.as.controller.management-operati
      on] (Controller Boot Thread) JBAS014612: Operation ("add") failed - address: ([(
      "deployment" => "adobe-livecycle-native-jboss-x86_win32.ear")]) - failure descri
      ption: "JBAS010876: No deployment content with hash d7eb949e5cf6309ec842fdb0a887
      301a951f06ed is available in the deployment content repository for deployment 'a
      dobe-livecycle-native-jboss-x86_win32.ear'. This is a fatal boot error. To corre
      ct the problem, either restart with the --admin-only switch set and use the CLI
      to install the missing content or remove it from the configuration, or remove th
      e deployment from the xml configuraiton file and restart."
      [Host Controller] 15:51:26,138 FATAL [org.jboss.as.host.controller] (Controller
      Boot Thread) JBAS010933: Host Controller boot has failed in an unrecoverable man
      ner; exiting. See previous messages for details.
      [Host Controller] 15:51:26,194 INFO  [org.jboss.as] (MSC service thread 1-4) JBA
      S015950: JBoss EAP 6.4.5.GA (AS 7.5.5.Final-redhat-3) stopped in 35ms
      [Host Controller] Java HotSpot(TM) 64-Bit Server VM warning: ignoring option Max
      PermSize=1024M; support was removed in 8.0
      15:51:26,630 INFO  [org.jboss.as.process.Host Controller.status] (reaper for Hos
      t Controller) JBAS012010: Process 'Host Controller' finished with an exit status
       of 99
      15:51:26,636 INFO  [org.jboss.as.process] (Thread-8) JBAS012016: Shutting down p
      rocess controller
      15:51:26,640 INFO  [org.jboss.as.process] (Thread-8) JBAS012015: All processes f
      inished; exiting
      Press any key to continue . . .
