1 Reply Latest reply on Dec 9, 2016 11:14 AM by JoelLucuik
    Adaptive Forms translator not translating after power outage
    JoelLucuik
      I'm using AEM 6.2, with http://localhost:4501/libs/cq/i18n/translator.html to do french translations. This has been working well until the power went out.
      I just tried changing button text from "French3" to "French4" and it's not taking.
      Any suggestions?
      I have seen warnings [1] and [2], not sure if they are related.
      Joel
      [1]
      09.12.2016 13:53:15.457 *WARN* [sling-default-50-Registered Service.5129] PDFG Acr Cleanup Daemon Error while retrieving system environment variable: TEMP
      java.lang.NullPointerException: null
          at com.adobe.pdfg.impl.CleanUpAcrFilesTask.calculateSystemPath(CleanUpAcrFilesTask.java:381)
          at com.adobe.pdfg.impl.CleanUpAcrFilesTask.populateListOfFolders(CleanUpAcrFilesTask.java:21 8)
          at com.adobe.pdfg.impl.CleanUpAcrFilesTask.cleanUp(CleanUpAcrFilesTask.java:143)
          at com.adobe.pdfg.impl.CleanUpAcrFilesTask.run(CleanUpAcrFilesTask.java:87)
          at org.apache.sling.commons.scheduler.impl.QuartzJobExecutor.execute(QuartzJobExecutor.java: 118)
          at org.quartz.core.JobRunShell.run(JobRunShell.java:202)
          at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
          at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
          at java.lang.Thread.run(Thread.java:745)
      09.12.2016 13:53:15.472 *WARN* [sling-default-50-Registered Service.5129] PDFG Acr Cleanup Daemon Error while retrieving system environment variable: TMP
          at com.adobe.pdfg.impl.CleanUpAcrFilesTask.populateListOfFolders(CleanUpAcrFilesTask.java:21 9)
      09.12.2016 13:53:15.472 *INFO* [sling-default-50-Registered Service.5129] PDFG Acr Cleanup Daemon Cleaning up directories: [C:\Users\JOEL~1.LUC\AppData\Local\Temp]
      [2]
      09.12.2016 13:14:16.434 *WARN* [0:0:0:0:0:0:0:1 [1481307256364] POST /etc/workflow/instances HTTP/1.1] org.apache.jackrabbit.oak.jcr.session.RefreshStrategy This session has been idle for 20 minutes and might be out of date. Consider using a fresh session or explicitly refresh the session.
      java.lang.Exception: The session was created here:
          at org.apache.jackrabbit.oak.jcr.session.RefreshStrategy$LogOnce.<init>(RefreshStrategy.java :169)
          at org.apache.jackrabbit.oak.jcr.repository.RepositoryImpl.login(RepositoryImpl.java:277)
          at com.adobe.granite.repository.impl.CRX3RepositoryImpl.login(CRX3RepositoryImpl.java:94)
          at org.apache.jackrabbit.oak.jcr.repository.RepositoryImpl.login(RepositoryImpl.java:219)
          at org.apache.jackrabbit.oak.jcr.session.SessionImpl.impersonate(SessionImpl.java:274)
          at org.apache.sling.jcr.base.AbstractSlingRepository2.createServiceSession(AbstractSlingRepo sitory2.java:182)
          at com.adobe.granite.repository.impl.SlingRepositoryImpl.createServiceSession(SlingRepositor yImpl.java:124)
          at org.apache.sling.jcr.base.AbstractSlingRepository2.loginService(AbstractSlingRepository2. java:331)
          at com.adobe.granite.workflow.core.util.ServiceLoginUtil.getWorkflowInstanceDataSession(Serv iceLoginUtil.java:58)
          at com.adobe.granite.workflow.core.model.WorkflowModelCacheImpl.<init>(WorkflowModelCacheImp l.java:82)
