Expand my Community achievements bar.
Learn about Edge Delivery Services in upcoming GEM session
SOLVED
How can I encode Javascript snippets in widget.jsp?
Avatar
Level 3
Hi
I use a lot of Javascript in custom components. Therefor I use custom properties that I added to the custom component's dialog.
I've found that all properties provided by the user via the component's dialog are encoded in the JSP:
name="${guide:encodeForHtmlAttr(guideField.name,xssAPI)}"
com.adobe.aemds.guide.taglibs.GuideELUtils provides
encodeForHtml(String str, XSSAPI xssapi)
encodeForHtmlAttr(String str, XSSAPI xssapi)
but does not provide methods for other encoding recommended by https://www.owasp.org/index.php/OWASP_Java_Encoder_Project#tab=Use_the_Java_Encoder_Project
How can I protect against XSS using the aem toolset?
Thank you,
Urs
1 Accepted Solution
Avatar
Correct answer by
Level 2
Avatar
Correct answer by
Level 2
I guess xssAPI.encodeForJSString("") is what you are looking for.
https://docs.adobe.com/docs/en/cq/5-6-1/javadoc/com/adobe/granite/xss/XSSAPI.html#encodeForJSString(...)
Anshika
Avatar
Level 3
Hi Anshika
thanks a lot.
That's what I was looking for.
Urs
Avatar
Level 3
Hi Anshika,
sorry to come back to this issue I had no time before. How can I access xssAPI from within widget.jsp in AEM 6.1?
Thank you,
Urs
Avatar
Level 2
Hi Urs,
The example you gave in your first comment already had the xssAPI instance so I assumed you already have access to it.
However, if you don't, you could either include <%@include file="/libs/granite/ui/global.jsp" %>  or alternatively add  <%@taglib prefix="cq" uri="http://www.day.com/taglibs/cq/1.0" %> in your jsp.
And in case you are asking how to use it within the script in your jsp, attaching a sample below :
<script>xyz.registerConfig("serverUrlConfig", {"contextPath" : "<%=xssAPI.encodeForJSString(contextPath)%>"      } );</script>
Hope that helps.
Anshika
