1 Reply Latest reply on May 12, 2016 5:32 AM by benm48734484
    AEM Forms 6.2 Workbench/Designer Preview HTML5
    benm48734484
      Hello,
      I have recently installed and configured AEM Forms 6.2 on JEE on a 2012 VM using the Turnkey solution, and have installed Workbench and Forms Designer on a separate 2008 VM. Through Workbench, I have successfully configured the connection to the Forms server and logged in. I have set up a TestForm, and when I open it in Workbench it launches the Forms Designer as expected. After adding a couple of fields to the form, I can preview in PDF and it renders properly. However, when I attempt to preview as HTML the screen is blank. When I view source  all that displays is the blank page:  <html><head></head><body></body></html>. Has anyone experienced this issue?
      On the Forms Server admin console, I have added IP of the 2008 server Workbench and Designer have been installed on to the Allowed Referrer whitelist and specified port value 0 to allow all ports. After which I restarted the server as directed
      Based on an article I came across (https://helpx.adobe.com/aem-forms/6-2/preview-xdp-forms-html.html#html_preview_of_forms_in _forms_designer), I logged in to configMgr (http://[server]:[port]/lc/system/console/configMgr) to configure the Apache Sling Authentication Service where:
      • I enabled anonymous access
      • added the following to the authentication requirements field:
      •     -/content/xfaforms
      •     -/etc/clientlibs
      After another server restart, I logged into the Workbench/Designer machine and relaunched Workbench > opened the TestForm which launched the designer, previewed as PDF successfully > Attempted to preview as HTML with no luck.
      Has anyone come across this issue? Any tips/insight would be greatly appreciated.
