4 Replies Latest reply on Oct 20, 2008 5:00 PM by Newsgroup_User
    cffeed
    reggiejackson88
      I would like to read a feed from a URL and then loop through to display on my website. Below is my code but I get an Error running this code: Connection refused by the specified host on the specified port.
      Please help. Thank you.
      <cffeed action="read" source=" http://rssfeeds.webmd.com/rss/rss.aspx" query="myfeed">
      <cfset myfeed = REReplaceNoCase (trim(myfeed), "^[^<]*", "") />
      <cfoutput query = "myfeed" maxrows="6">
      <a href = "#rsslink#" target="_blank">#myfeed.title#</a> <br />
      </cfoutput>
        • 1. Re: cffeed
          Level 7
          > Connection
          Well the error kinda does explain what the problem is. Can the CF server
          actually reach that URL? It would seem not.
          Adam
          • 2. Re: cffeed
            John Whish
            I just tried it and it works fine (CF8.0.1). You do need to remove your second line of code as you can't use ReReplace on a query object. You should have this:
            <cfoutput query="myfeed" maxrows="6">
            <a href="#myfeed.rsslink#" target="_blank">#myfeed.title#</a> <br />
            </cfoutput>
            • 3. Re: cffeed
              reggiejackson88 Level 1
              ...I JUST found out that my script works when accessed from a server but I was using it in a development environment locally on my computer and the connection was being refused there. Why won't this code work locally? Is there a setting I need to change in my administrator?
              Thanks for everyones help.
              • 4. Re: cffeed
                Level 7
                Your local firewall?
                Adam
