1 Reply Latest reply on Oct 15, 2015 7:30 PM by AlexanderWillett
    AEM 6.1 Forms - Set up certificates for Reader extensions: Error occurred while adding the private key
    AlexanderWillett Level 1
      I just tried to setup a Reader Extensions certificate in AEM 6.1 Forms and received an exception "Invalid keystore format". An error message on the screen says: "Error occurred while adding the private key"
      I followed the description https://helpx.adobe.com/aem-forms/6-1/configuring-document-services.html. I did the same procedure some month ago in AEM 6.0 where everything worked fine. I tested with several certificate files, also with the one that worked in AEM6. In 6.1 they all lead to the same "Invalid keystore format"
      Has anybody successfully imported a ares certificate into an AEM 6.1 user's keystore?
      This is the exception:
      Caused by: java.io.IOException: Invalid keystore format
          at sun.security.provider.JavaKeyStore.engineLoad(Unknown Source)
          at sun.security.provider.JavaKeyStore$JKS.engineLoad(Unknown Source)
          at java.security.KeyStore.load(Unknown Source)
          at com.adobe.granite.security.user.internal.servlets.KeyStoreManagingServlet.importKeyFromKe yStore(KeyStoreManagingServlet.java:479)
          at com.adobe.granite.security.user.internal.servlets.KeyStoreManagingServlet.doPost(KeyStore ManagingServlet.java:310)
      Thanks for any help on this
      Alex
      • 0. Re: AEM 6.1 Forms - Set up certificates for Reader extensions: Error occurred while adding the private key
        Found the reason: It is causes by the browser.
        Firefox (V41) is causing the error described above
        MS InternetExplorer (V11) does just nothing when  pressing "submit" in the  "Add private key from key store file" dialog
        Google Chrome (V40) works fine
