1 Reply Latest reply on Dec 10, 2015 7:52 PM by varundua
    Pre-populating Adaptive Form in Workspace
    DarrenBiz Level 3
      Can you tell me what the format for pre-populating adaptive forms used within Workspace is?
      Does it follow the old standard PDF/HTML XML structure or the <afData><afBoundData><dataRoot>... structure?
        • 1. Re: Pre-populating Adaptive Form in Workspace
          varundua Level 2
          Hi Darren,
          New Standard is followed for all the Adaptive Forms. In addition to that for XFA based Adaptive Forms old standard is still followed, but in that case if you have dropped some fields form the sidekick and not from the Data Hierarchy tab, those fields will not be pre-populated. So as an example, if in your XFA based Adaptive Form, you have used only XFA based Fields then the following two XML structures are equivalent for pre-populating
          <afdata><afUnboundData></afUnboundData><afBoundData><dataRoot>...</afBoundData></afData>
          <xdp><xfa><data>...</xdp>
          But if you have some fields that are not bound to XFA, then in that case the second structure will not pre-populate those fields.
          Hope I have answered your Query
          Regards
          Varun Dua
