4 Replies Latest reply on Jan 18, 2016 2:45 AM by urs h.
    How to extend or sub-type 'guideField' ?
    urs h. Level 1
      I'want to implement a kind of sub-type of or specialized text box.
      • The specialized text box shall have an additional property like 'urlForAutocompleteLookUp'.
      • Form authors shall be able to configure the value of this property in the widget's dialog.
      • The new property shall be exposed in the Jsp object 'guideField' so that I can use it to implement additional logic:
      <%------------------------------------------------------------------------ ~ ~ ADOBE CONFIDENTIAL ~ __________________ ~ ~  Copyright 2014 Adobe Systems Incorporated ~  All Rights Reserved. ~ NOTICE:  All information contained herein is, and remains ~ the property of Adobe Systems Incorporated and its suppliers, ~ if any.  The intellectual and technical concepts contained ~ herein are proprietary to Adobe Systems Incorporated and its ~ suppliers and may be covered by U.S. and Foreign Patents, ~ patents in process, and are protected by trade secret or copyright law. ~ Dissemination of this information or reproduction of this material ~ is strictly forbidden unless prior written permission is obtained ~ from Adobe Systems Incorporated. --------------------------------------------------------------------------%> <%-- TextBox Component --%> <%@include file="/libs/fd/af/components/guidesglobal.jsp"%> <%-- todo: In case of repeatable panels, please change this logic at view layer --%> <div class="<%= GuideConstants.GUIDE_FIELD_WIDGET%> ${guideField.multiLine ? " multiline" : ""}" style="${guide:encodeForHtmlAttr(guideField.styles,xssAPI)}"> <c:choose> <c:when test="${guideField.multiLine}"> <textarea id="${guideid}${'_widget'}" name="${guide:encodeForHtmlAttr(guideField.name,xssAPI)}" style="${guide:encodeForHtmlAttr(guideField.widgetInlineStyles,xssAPI)}" placeholder="${guide:encodeForHtmlAttr(guideField.placeholderText,xssAPI)}">${guide:encodeForHtml(guideField.value,xssAPI)}</textarea> </c:when> <c:otherwise> <input type="text" id="${guideid}${'_widget'}" name="${guide:encodeForHtmlAttr(guideField.name,xssAPI)}" value="${guide:encodeForHtmlAttr(guideField.value,xssAPI)}" style="${guide:encodeForHtmlAttr(guideField.widgetInlineStyles,xssAPI)}" placeholder="${guide:encodeForHtmlAttr(guideField.placeholderText,xssAPI)}"/>
                      <c:if test="${guideField.hasUrlForAutocompleteLookUp}">                    ... ... logic I want to add that will use the property urlForAutocompleteLookUp ...
                      </c:if>
      </c:otherwise> </c:choose> <%-- End of Widget Div --%> </div>
      My problem is that I don't know how I can add properties to the 'guideField' object.
        • 1. Re: How to extend or sub-type 'guideField' ?
          rishim22446870 Level 2
          You can create a new "customized texbox component" which inherits from textbox component and leverage the global object "properties" [1] exposed by AEM for your use-case. I don't think there is a need to create a bean.
          Rishi
          [1] https://docs.adobe.com/docs/en/cq/5-6-1/developing/scripts.print.html
          • 2. Re: How to extend or sub-type 'guideField' ?
            urs h. Level 1
            Hi Rishi
            thanks for your answer. I tried to test the solution you proposed but I get an error.
            That's how my widgets.jsp looks like:
            <%------------------------------------------------------------------------ ~ ~ ADOBE CONFIDENTIAL ~ __________________ ~ ~  Copyright 2014 Adobe Systems Incorporated ~  All Rights Reserved. ~ ~ NOTICE:  All information contained herein is, and remains ~ the property of Adobe Systems Incorporated and its suppliers, ~ if any.  The intellectual and technical concepts contained ~ herein are proprietary to Adobe Systems Incorporated and its ~ suppliers and may be covered by U.S. and Foreign Patents, ~ patents in process, and are protected by trade secret or copyright law. ~ Dissemination of this information or reproduction of this material ~ is strictly forbidden unless prior written permission is obtained ~ from Adobe Systems Incorporated. --------------------------------------------------------------------------%> <%-- TextBox Component --%> <%@include file="/libs/fd/af/components/guidesglobal.jsp"%> <%-- todo: In case of repeatable panels, please change this logic at view layer --%> <div class="<%= GuideConstants.GUIDE_FIELD_WIDGET%> ${guideField.multiLine ? " multiline" : ""}" style="${guide:encodeForHtmlAttr(guideField.styles,xssAPI)}"> <input type="text" id="${guideid}${'_widget'}" name="${guide:encodeForHtmlAttr(guideField.name,xssAPI)}" value="${guide:encodeForHtmlAttr(guideField.value,xssAPI)}" style="${guide:encodeForHtmlAttr(guideField.widgetInlineStyles,xssAPI)}" placeholder="${guide:encodeForHtmlAttr(guideField.placeholderText,xssAPI)}"/> <script> <c:forEach var="property" items="${guideField.properties}"> console.log("${property.key} : " + "${property.value}"); </c:forEach> </script> </div>
            And this is the jsp error that is logged in the log file:
            Caused by: javax.el.PropertyNotFoundException: Property 'properties' not found on type com.adobe.aemds.guide.common.GuideTextBox
                at javax.el.BeanELResolver$BeanProperties.get(BeanELResolver.java:193)
                at javax.el.BeanELResolver$BeanProperties.access$400(BeanELResolver.java:170)
                at javax.el.BeanELResolver.property(BeanELResolver.java:279)
                at javax.el.BeanELResolver.getValue(BeanELResolver.java:60)
                at javax.el.CompositeELResolver.getValue(CompositeELResolver.java:53)
                at org.apache.el.parser.AstValue.getValue(AstValue.java:97)
                at org.apache.el.ValueExpressionImpl.getValue(ValueExpressionImpl.java:186)
                at org.apache.sling.scripting.jsp.jasper.runtime.PageContextImpl.proprietaryEvaluate(PageCon textImpl.java:975)
                at org.apache.jsp.apps.stzh_002daf_002dcomponents.components.stzh_002daf_005fmail_005ftextbo x.widget_jsp._jspx_meth_c_005fforEach_005f0(widget_jsp.java:266)
                at org.apache.jsp.apps.stzh_002daf_002dcomponents.components.stzh_002daf_005fmail_005ftextbo x.widget_jsp._jspService(widget_jsp.java:238)
                at org.apache.sling.scripting.jsp.jasper.runtime.HttpJspBase.service(HttpJspBase.java:70)
                at javax.servlet.http.HttpServlet.service(HttpServlet.java:725)
                at org.apache.sling.scripting.jsp.jasper.servlet.JspServletWrapper.service(JspServletWrapper .java:502)
            Is the property you mentioned only available in Sightly?
            • 3. Re: How to extend or sub-type 'guideField' ?
              properties object is exposed as part of global objects, it is not a part of guideField bean. You should try the following code in the component's jsp,
              <% String hasUrlForAutocompleteLookUp = properties.get("hasUrlForAutocompleteLookUp", null); %> <% if(hasUrlForAutoCompleteLookUp != null) {%> <!-- Insert your markup here --> <% } %>
              • 4. Re: How to extend or sub-type 'guideField' ?
                urs h. Level 1
                Thanks a lot, using the global property 'properties' it works.
                adding following code to widget.jsp list all properties currently available smiley
                ... <script> <c:forEach var="property" items="${properties}"> console.log("${property.key} : " + "${property.value}"); </c:forEach> </script> ...
                Regards,
                Urs
