1 Reply Latest reply on Oct 15, 2015 7:30 PM by mandeepgandhi
    dispatcher configuration in apache
    aem_dev Level 1
      Hi, i have installed AEM 6 in tomcat server (Unix). Publish port is 4503 and application will be accessed as below.
      Example content: localhost:4503/aempublish/content/geometrixx-media/en.html.
      Installed SSL in tomcat and apache web server. i am using dispatcher 4.1.8 and added below configs
      /virtualhosts
              "localhost:10000"
          /renders
            /rend01
              /hostname "127.0.0.1"
              /port "4503"
      in filters added below.
      /0023 { /type "allow" /url "/aempublish/content/*
      Apache configurations: Apache is running at 4504
      <VirtualHost localhost:4504>
              ProxyRequests Off
              <Location "/" >
                      ProxyPass  https://localhost:10000/ (tried http as well)
                      ProxyPassReverse  https://localhost:10000/ (tried http as well)
              </Location>
              SSLEngine on
              SSLCertificateFile <cert file location>
              SSLCertificateKeyFile <cert key location>
      </VirtualHost>
      <VirtualHost localhost:10000>
              ProxyPreserveHost On
              <Directory "/" >
                <IfModule disp_apache2.c>
                        SetHandler dispatcher-handler
                        ModMimeUsePathInfo On
                </IfModule>
              </Directory>
             SSLEngine on
      </VirtualHost>
      When i hit the page with apache port i am getting 503 service temporarily unavailable and also see below in apache error logs. But no error in dispatcher logs
      [Wed Apr 01 11:38:49 2015] [error] (111)Connection refused: proxy: HTTPS: attempt to connect to <ip address>:10000 (localhost) failed
      [Wed Apr 01 11:38:49 2015] [error] ap_proxy_connect_backend disabling worker for (localhost)
      [Wed Apr 01 11:38:49 2015] [error] proxy: HTTPS: disabled connection for (localhost)
      [Wed Apr 01 11:38:53 2015] [error] proxy: HTTPS: disabled connection for (localhost)
      when i tried with http, got the same error but it says http: disabled connection for (localhost)
      Appreciated for quick response
      • 0. Re: dispatcher configuration in apache
        mandeepgandhi Adobe Employee
        Let me ask a few basic questions first. Are you able to access you page when you hit the apache port ?
        If you are not using dispacher but trying a web server (apache in your case). This looks to me a very common configuration problem.
        Can you try the first few links mentioned in  https://www.google.co.in/search?q=ap_proxy_connect_backend+disabling+worker+for&oq=ap_prox y_connect_backend+disabling+worker+for&aqs=chrome..69i57&sourceid=chrome&es_sm=122&ie=UTF- 8
        Let me know if you still face the issue. I would  then try to setup the same architecture and see what is going wrong.
