2 Replies Latest reply on Oct 15, 2015 7:30 PM by smacdonald2008
    Rendering HTML5 forms using Workbench
    RDBNDB
      Can anyone tell me if it's possible to render HTML5 forms from within Workbench?  I can render forms as PDFs and HTML4 but I can't find anything n HTML5.  If it is possible how would I do it?
      Thanks.
      • 0. Re: Rendering HTML5 forms using Workbench
        smacdonald2008 Adobe Employee
        With Adobe Experience Manager - there is no Workbench tool.
        However -  AEM Forms is delivered with the entire JEE stack (same way as LiveCycle ES) and includes Workbench.
          • 1. Re: Rendering HTML5 forms using Workbench
            DarrenBiz Level 3
            Sorry Scott but that is not strictly true. You can still use Workbench when you have AEM Forms 6.0 JEE and you can still render HTML5 output from Process Manager which requires Workbench to configure.
            If you are using Workbench I assume you are using either Livecycle ES4+ or AEM Forms 6.0 JEE. This is a good link to help explain HTML5 (aka Mobile Forms) https://helpx.adobe.com/livecycle/topics/mobile-forms-dev.html
            You cannot render HTML5 as an output option natively from within a process like PDF or HTML4. It has to be rendered as a Mobile Form using the CRX/AEM sub-system. You need the form to be accessed via a supported browser or via Mobile Workspace
            There are two ways you can render HTML5 forms:
            1. Directly using CRX/AEM from the AEM server or the JEE server (see Mobile Forms link above)
            2. Or if you are using Process Manager, you can specify the form render type as HTML5 for rendering the form in the Task in either HTML Workspace or using Mobile Workspace as mentioned above
            You can preview the XDP as HTML5 from within Livecycle Designer, you just have to configure it to point to your AEM / Livecycle server first
            Darren
