2 Replies Latest reply on Oct 15, 2015 7:30 PM by Sham HC
    Page forward  doesn't happen when the file size is larger than 5 mb
    depath
      1. I have a form with multipart/form-data which posts to a servlet.
      2. The servlet processes the request and forwards to a page.
      I have written a custom servlet that extends a SlingAllMethodsServlet.
      In the servlet I am checking wether it is a multi part
      try
                  if(ServletFileUpload.isMultipartContent(request))
                      List<File> attachedFiles = new ArrayList<File>();
                      Map<String, RequestParameter[]> params = request.getRequestParameterMap();
                      Map<String, String[]> parameterMap = null;
                      for ( Map.Entry<String, RequestParameter[]> pairs : params.entrySet())
                          String key = pairs.getKey();
                          if(key.equals("fileName1") || key.equals("fileName2") || key.equals("fileName3"))
                              RequestParameter[] paramArray = pairs.getValue();
                              if(paramArray != null && paramArray.length > 0)
                                  RequestParameter param = paramArray[0];
                                  InputStream inputStream = param.getInputStream();
                                  if(inputStream.available() != 0)
                                      final File tempFile = File.createTempFile(PREFIX, SUFFIX);
                                      tempFile.deleteOnExit();
                                      try (FileOutputStream outputStream = new FileOutputStream(tempFile))
                                          IOUtils.copy(inputStream, outputStream);
                                      attachedFiles.add(tempFile);
                                      forwardToThankYouPage(request, response, thankYouPagePath);
      for some reason the  forwardToThankYouPage does not work when the file size is larger than 1 mb. For files of 100bytes the process run's just fine.
      Can some one help me figure out.
      depath
      • 0. Re: Page forward  doesn't happen when the file size is larger than 5 mb
        Sham HC Level 7
        Hi depath,
             Make use of copyLarge method of IOUtil instead of copy.
        Sham
        Twitter: @adobe_sham
