4 Replies Latest reply on Oct 15, 2015 7:30 PM by bajwaya
    Importing XFA form into AEM, change event hander doesn't fire
    bajwaya
      Hi
      I have an XFA form with a change event handler on a field.  When the form is rendered as a PDF and opened in Reader, the change event handler works fine.
      However, when importing the XFA into AEM forms, adding the field to the AEM form works, but the change event doesn't fire when it is supposed to.  I had a change listener setup on a drop-down list.  I tried the simple case of a javascript pop-up on any change, but no luck.
      Are change events supported this way in AEM?  Is there documentation describing what type of event handling is supported?
      Thank you
      • 0. Re: Importing XFA form into AEM, change event hander doesn't fire
        bajwaya Level 1
        Thank you.  In PDF, the 'exit' event triggers when changing the drop-down value.  However, this is not happening with the adaptive form.  On the adaptive form, I need change focus to another field, then it fires the exit handler.
        Also, will adaptive form support capturing / filtering keystrokes?  In PDF, I can filter out what the user is typing, it didn't work in adaptive form.
