1 Reply Latest reply on Oct 15, 2015 7:30 PM by rishim22446870
    Script to Show Hide
    Tim Goodman_BTES Level 1
      Hi
      I'm looking for documentation or an example of a field Visibility Expression.  Is there a help page online?
      • 0. Re: Script to Show Hide
        rishim22446870 Level 2
        Visibility Expression is used to control the visibility of field/panel. The return value of visibility expression should be a boolean(true/false), where true says that the component should be visible and false says that it should be hidden.
        Suppose, you have two fields A and B and say, you want to control the visibility of A based on the value present in B. In such case, the visibility expression would look like this,
        // suppose we want to make the field A visible only when the value of // field B is set to "female", then the visibility expression of field A // would look something like this B.value === "female"
        Also, with the expression above, the initial visibility of field A would be hidden, assuming that B.value is not set to "female" initially.
        Visibility Expression can be found in field/panel dialog configuration.
        The "help page" for all the "expression" supported would be available soon.
