4 Replies Latest reply on Oct 21, 2008 12:18 PM by Peter Lorent
    Unable to Validate Configuration
    Jim Daniel
      Using MAMP I was able to get both the Apache & MySAL servers running. Ports were set to default values of 80 & 3306. When I ran netstat -na | grep 80 I got a return information. When I attempt to create a PHP Flex application I get an error message when I attempt to Validate Configuration.
      The Web root: /users/JimDaniel/Lawn Cats/KityCats
      The Root URL: http://localhost/KityCatSite
      The folder KityCatSite is in the /Documents/Apache folder and can be seen by my browser when I enter the Root URL. The KityCats folder also already exits. Whats going on here and can anyone help?
      P.S. I'm runing OSX 10.5.5
        • 1. Re: Unable to Validate Configuration
          Peter Lorent Level 2
          I'm having the same issue and can only get it to validate when I use the following settings:
          root folder: /Applications/MAMP/htdocs
          root URL: http://localhost:80/
          I'm still checking this so if anything turns up, I'll let you know.
          • 2. Re: Unable to Validate Configuration
            Level 7
            "Jim Daniel" <webforumsuser@macromedia.com> wrote in message
            news:gdito2$73q$1@forums.macromedia.com...
            > Ports
            > I
            > I
            > by
            > exits.
            I run Windows, but you may find this helpful
            http://tinyurl.com/flMamp
            • 3. Re: Unable to Validate Configuration
              Jim Daniel Level 1
              LuigiL,
              Thanks for the help, that solved the problem once I changed the MAMP Apache Document Root to match. Other than having to give the port number with the localhost I'm thinking that the Root Folder setting in Flex Builder needs to match the Apache Document Folder setting in MAMP.
              • 4. Re: Unable to Validate Configuration
                I've tested several things but I just can't get it to work with other settings. I'm not using this feature of FB3 (all backend work is done with other frameworks) so I'm not investing a lot of time in solving this - if possible - but if something turns up, I'll post the result. In the meantime I've also asked a specialist to look into this so maybe he finds out what is going on.
