0 Replies Latest reply on Apr 28, 2017 1:20 AM by BjornEricsson
    Capture process XML variable in XSLT template?
    BjornEricsson
      I can't figure out how to capture an AEM Forms process XML variable and use it in an XSLT template. The capture part works, but somehow the processor removes the tags in the variable and only outputs the values (1 2 3) as if I would have used value-of instead of copy-of. Using a local variable as a reference works fine.
      This is my XSL:
      <xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform">
      <xsl:output omit-xml-declaration="yes" indent="yes"/>
      <xsl:variable name="insertedXML"><insert_data>1</insert_data></xsl:variable>
      <xsl:variable name ="dummyXML">'{$/process_data/BlankettXML$}'</xsl:variable>
      <xsl:template match="node()|@*">
          <xsl:copy>
              <xsl:apply-templates select="node()|@*"/>
          </xsl:copy>
      </xsl:template>
      <xsl:template match="FormSpecifics">
          <xsl:copy-of select="$dummyXML"/>
      </xsl:template>
      <xsl:template match="/*/*/*[last()]">
          <xsl:copy>
          </xsl:copy>
          <xsl:copy-of select="$insertedXML"/>
      </xsl:template>
      This is my input:
      <ContainerRoot>
      <DocumentList>
          <Document name="second">
              <FormRef>2222_2</FormRef>
              <FormSpecifics>
                  <name>Björn</name>
                  <date>2017-01-01</date>
              </FormSpecifics>
          </Document>
          <Document>
              <FormSpecifics>
                  <address>Home street 12</address>
                  <zip>123 45</zip>
                  <state>Alabama</state>
              </FormSpecifics>
          </Document>
      </DocumentList>
      This is my process variable (blankettXML)
          <insert_root>
              <insert_data>2</insert_data>
              <insert_data>3</insert_data>
          </insert_root>
      This is my output:
          <ContainerRoot>
          <DocumentList>
                    1  2  3
                      <name>Björn</name>
              </Document>
              <Document>
                    1  2  3
                      <zip>123 45</zip>
              </Document>
          </DocumentList>
      </ContainerRoot>
      How would you solve this?
