9 Replies Latest reply on Nov 24, 2008 5:06 PM by etnot96
    Need help with Flex3 Web Services.
    etnot96 Level 1
      I used the Flex3 Builder Web Service Introspection Wizard to generated my web service objects. I am having trouble invoking my webservice. Mainly because Flex is calling the wrong endpoint. The error msg I get in the flex console is as follows: [SWF] C:\dev\projects\{ProjectName}\bin-debug\{ProjectName}Application.swf - 1,106,208 bytes after decompression
      faultCode:Server.Error.Request faultString:'HTTP request error' faultDetail:'Error: [IOErrorEvent type="ioError" bubbles=false cancelable=false eventPhase=2 text="Error #2032: Stream Error. URL: http://localhost:8080/{ProjectName}-WS/services" URL: http://localhost:8080/{ProjectName}-WS/services'
      The error message I get on Tomcat for Spring-WS is as follows: EndpointNotFound - No endpoint mapping found for [SaajSoapMessage { http://www.{ProjectName}.com/WebserviceClient}webServiceClient
      The correct end point that should be called from flex is as follows: { http://www.{ProjectName}.com/system/schemas}Process{ProjectName}NumberRequest as defined in my spring-ws servlet.xml file. Now I am not sure if it is or not calling this endpoint but I do know it is calling the { http://www.{ProjectName}.com/WebserviceClient}webServiceClient endpoint because that is in my error message.
      It seem Flex is trying to call a seperate endpoint for each node in my {ProjectName}Type.xsd file; when it should be calling the root node from in my {ProjectName}Type.xsd file.
      One last thing. I know my Webservice works because I have tested it with my java spring client via JUnit using the root node of the {ProjectName}Type.xsd; which is what is wired up in my [ProjectName]-servlet.xml file.
      See reply post to view my xml schemas, servlet.xml, and error messages with the project name, among other information, stripped out.
      Thanks in advance!
      Tonté
        • 1. Need help with Flex3 Web Services.
          etnot96 Level 1
          Below I have listed a copy of my xml schemas, servlet.xml, and error messages with the project name, among other information, stripped out.
          [ProjectName]Type.xsd:
          <?xml version="1.0" encoding="UTF-8"?>
          <xs:schema xmlns:xs=" http://www.w3.org/2001/XMLSchema"
          targetNamespace=" http://www.{ProjectName}com/system/schemas"
          xmlns:tns=" http://www.{ProjectName}com/system/schemas"
          xmlns:wsClient=" http://www.{ProjectName}.com/WebserviceClient"
          xmlns:cpln=" http://www.{ProjectName}.com/system/common-schemas"
          elementFormDefault="qualified">
          <xs:import namespace=" http://www.{ProjectName}.com/WebserviceClient" schemaLocation="WebserviceClient.xsd"/>
          <xs:import namespace=" http://www.{ProjectName}.com/system/common-schemas" schemaLocation="[ProjectName]CommonTypes.xsd"/>
          <xs:element name="Process[ProjectName]NumberRequest">
          <xs:complexType>
          <xs:sequence>
          <xs:element ref="wsClient:webServiceClient" />
          <xs:element ref="cpln:[ProjectName]Number" />
          </xs:sequence>
          </xs:complexType>
          </xs:element>
          <xs:element name="Process[ProjectName]NumberResponse">
          <xs:complexType>
          <xs:sequence>
          <xs:element ref="cpln:[ProjectName]Numbers"/>
          </xs:sequence>
          </xs:complexType>
          </xs:element>
          </xs:schema>
          • 2. Need help with Flex3 Web Services.
            etnot96 Level 1
            WebserviceClient.xsd:
            targetNamespace=" http://www.{ProjectName}.com/WebserviceClient"
            xmlns:tns=" http://www.{ProjectName}.com/WebserviceClient"
            <xs:element name="webServiceClient" type="tns:webServiceClient" />
            <xs:complexType name="webServiceClient">
            <xs:sequence>
            <xs:element name="id" type="tns:idType" />
            <xs:element name="customerName" type="tns:nameType"/>
            <xs:element name="customerUserName" type="tns:nameType" />
            <xs:element name="custoemrPw" type="tns:pwType"/>
            </xs:sequence>
            </xs:complexType>
            <xs:simpleType name="idType">
            <xs:restriction base="xs:integer">
            <xs:totalDigits value="10" />
            </xs:restriction>
            </xs:simpleType>
            <xs:simpleType name="nameType">
            <xs:restriction base="xs:string">
            <xs:maxLength value="50" />
            </xs:restriction>
            </xs:simpleType>
            <xs:simpleType name="pwType">
            <xs:maxLength value="15" />
            </xs:restriction>
            </xs:simpleType>
            </xs:schema>
            • 3. Need help with Flex3 Web Services.
              etnot96 Level 1
              [ProjectName]CommonType.xsd:
              targetNamespace=" http://www.{ProjectName}.com/system/common-schemas"
              xmlns:tns=" http://www.{ProjectName}.com/system/common-schemas"
              <xs:element name="Number" type="tns:NumberType"/>
              <xs:element name="[ProjectName]Number" type="tns:[ProjectName]Number" />
              <xs:element name="[ProjectName]Numbers">
              <xs:complexType>
              <xs:sequence>
              <xs:element name="[ProjectName]Number" type="tns:[ProjectName]Number" minOccurs="0" maxOccurs="unbounded"/>
              </xs:sequence>
              </xs:complexType>
              </xs:element>
              <xs:complexType name="[ProjectName]Number">
              <xs:sequence>
              <xs:element name="number" type="tns:NumberType" />
              <xs:element name="requestDate" type="xs:dateTime" />
              <xs:element name="drawinType" default="Night">
              <xs:simpleType>
              <xs:enumeration value="Night"/>
              <xs:enumeration value="MidDay"/>
              <xs:enumeration value="Day"/>
              </xs:restriction>
              </xs:simpleType>
              </xs:element>
              <xs:element name="type" default="MSG1">
              <xs:simpleType>
              <xs:enumeration value="MSG1"/>
              <xs:enumeration value="MSG2"/>
              <xs:enumeration value="MSG3"/>
              </xs:restriction>
              </xs:simpleType>
              </xs:element>
              </xs:sequence>
              </xs:complexType>
              <xs:simpleType name="NumberType">
              <xs:totalDigits value="3" />
              </xs:restriction>
              </xs:simpleType>
              </xs:schema>
              • 4. Need help with Flex3 Web Services.
                etnot96 Level 1
                [ProjectName]-servlet.xml:
                <beans xmlns=" http://www.springframework.org/schema/beans"
                xmlns:xsi=" http://www.w3.org/2001/XMLSchema-instance"
                xsi:schemaLocation=" http://www.springframework.org/schema/beans http://www.springframework.org/schema/beans/spring-beans-2.0.xsd">
                <bean id="[ProjectName]NumberRequestProcessor"
                class="com.pouncilt.[ProjectName].webservices.core.models.[ProjectName]NumberRequestProce ssor" />
                <bean id="marshaller"
                class="org.springframework.oxm.jaxb.Jaxb2Marshaller">
                <!-- JAXB1 property name="contextPath" value="com.pouncilt.[ProjectName].webservices.commons.models.generated"/-->
                <property name="classesToBeBound">
                <list>
                <value>
                com.pouncilt.[ProjectName].webservices.commons.models.generated.Process[ProjectName]Numbe rRequest
                </value>
                <value>
                com.pouncilt.[ProjectName].webservices.commons.models.generated.Process[ProjectName]Numbe rResponse
                </value>
                </list>
                </property>
                </bean>
                <bean id="payloadMapping"
                class="org.springframework.ws.server.endpoint.mapping.PayloadRootQNameEndpointMapping">
                <property name="endpointMap">
                <map>
                <entry
                key="{ http://www.[ProjectName
                value-ref="process[ProjectName]NumberRequestEndPoint" />
                </map>
                </property>
                <property name="order" value="2" />
                </bean>
                <bean id="payloadMapping2"
                <map>
                <entry
                </map>
                </property>
                </bean>
                <bean id="process[ProjectName]NumberRequestEndPoint"
                class="com.pouncilt.[ProjectName].webservices.core.Process[ProjectName]NumberRequestMarsh allingEndpoint">
                <property name="[ProjectName]NumberRequestProcessor"
                ref="[ProjectName]NumberRequestProcessor" />
                <property name="marshaller" ref="marshaller" />
                <property name="unmarshaller" ref="marshaller" />
                </bean>
                <bean id="endpointExceptionResolver"
                class="org.springframework.ws.soap.server.endpoint.SoapFaultMappingExceptionResolver">
                <property name="exceptionMappings">
                <props>
                <prop
                key="org.springframework.oxm.UnmarshallingFailureException">
                SENDER, Invalid message received
                </prop>
                <prop
                key="org.springframework.oxm.ValidationFailureException">
                </prop>
                </props>
                </property>
                <property name="defaultFault" value="RECEIVER, Server error" />
                </bean>
                <bean id="[ProjectName]"
                class="org.springframework.ws.wsdl.wsdl11.DynamicWsdl11Definition">
                <property name="builder">
                <bean
                class="org.springframework.ws.wsdl.wsdl11.builder.XsdBasedSoap11Wsdl4jDefinitionBuilder">
                <property name="schema">
                <value>
                classpath:xml-schemas/[ProjectName]Types.xsd
                </value>
                </property>
                <!--property name="schema" value="[ProjectName]Types.xsd"/-->
                <property name="portTypeName" value="[ProjectName]" />
                <property name="locationUri" value=" http://localhost:8080/[ProjectName />
                </bean>
                </property>
                </bean>
                <!--bean id="[ProjectName]"
                class="org.springframework.ws.wsdl.wsdl11.DefaultWsdl11Definition">
                <property name="schema" ref="schema"/>
                </bean-->
                <!--bean id="schema" class="org.springframework.xml.xsd.SimpleXsdSchema">
                <property name="xsd">
                <value>classpath:xml-schemas/[ProjectName]Types.xsd</value>
                </property>
                </bean-->
                </beans>
                • 5. Re: Need help with Flex3 Web Services.
                  etnot96 Level 1
                  Tomcat Spring-WS error:
                  [ INFO] 10:31:30 MessageDispatcherServlet - FrameworkServlet '[ProjectName]': init
                  ialization started
                  [ INFO] 10:31:30 XmlWebApplicationContext - Refreshing org.springframework.web.c
                  ontext.support.XmlWebApplicationContext@8ceeea: display name [WebApplicationCont
                  ext for namespace '[ProjectName]-servlet']; startup date [Sun Oct 19 10:31:30 CDT
                  2008]; root of context hierarchy
                  [ INFO] 10:31:30 XmlBeanDefinitionReader - Loading XML bean definitions from Ser
                  vletContext resource [/WEB-INF/[ProjectName]-servlet.xml]
                  [ INFO] 10:31:31 XmlWebApplicationContext - Bean factory for application context
                  [org.springframework.web.context.support.XmlWebApplicationContext@8ceeea]: org.
                  springframework.beans.factory.support.DefaultListableBeanFactory@987a33
                  [ INFO] 10:31:31 DefaultListableBeanFactory - Pre-instantiating singletons in or
                  g.springframework.beans.factory.support.DefaultListableBeanFactory@987a33: defin
                  ing beans [[ProjectName]NumberRequestProcessor,marshaller,payloadMapping,processCh
                  ucksPick3NumberRequestEndPoint,endpointExceptionResolver,[ProjectName]]; root of f
                  actory hierarchy
                  [ INFO] 10:31:31 Jaxb2Marshaller - Creating JAXBContext with classes to be bound
                  [class com.pouncilt.[ProjectName].webservices.commons.models.generated.ProcessChu
                  cksPick3NumberRequest,class com.pouncilt.[ProjectName].webservices.commons.
                  models.generated.Process[ProjectName]NumberResponse]
                  [ INFO] 10:31:31 SaajSoapMessageFactory - Creating SAAJ 1.3 MessageFactory with
                  SOAP 1.1 Protocol
                  [ INFO] 10:31:31 MessageDispatcherServlet - FrameworkServlet '[ProjectName]': init
                  ialization completed in 906 ms
                  [ WARN] 10:31:31 EndpointNotFound - No endpoint mapping found for [SaajSoapMessa
                  ge { http://www.[ProjectName
                  • 6. Re: Need help with Flex3 Web Services.
                    etnot96 Level 1
                    It would seem the Fx Webservice Introspection is not interpreting the wsdl correctly. By using TCPMonitor I was able to capture my soap request from my java spring-ws junit test. The correct response is as follows:
                    <SOAP-ENV:Envelope xmlns:SOAP-ENV=" http://schemas.xmlsoap.org/soap/envelope/">
                    <SOAP-ENV:Header/>
                    <SOAP-ENV:Body>
                    <ns4:ProcessChucksPick3LotteryNumberRequest
                    xmlns:ns2=" http://www.chuckspick3.com/WebserviceClient"
                    xmlns:ns3=" http://www.chuckspick3.com/lotterysystem/common-schemas"
                    xmlns:ns4=" http://www.chuckspick3.com/lotterysystem/schemas">
                    <ns2:webServiceClient>
                    <ns2:id>0</ns2:id>
                    <ns2:customerName>test</ns2:customerName>
                    <ns2:customerUserName>test</ns2:customerUserName>
                    <ns2:custoemrPw>test</ns2:custoemrPw>
                    </ns2:webServiceClient>
                    <ns3:chucksPick3LotteryNumber>
                    <ns3:number>345</ns3:number>
                    <ns3:requestDate>2008-10-29T20:32:37.171-05:00</ns3:requestDate>
                    <ns3:drawingType>MidDay</ns3:drawingType>
                    </ns3:chucksPick3LotteryNumber>
                    </ns4:ProcessChucksPick3LotteryNumberRequest>
                    </SOAP-ENV:Body>
                    </SOAP-ENV:Envelope>
                    Using the code generated from the Fx Webservice Introspection wizard I get the following invalid soap request:
                    <SOAP-ENV:Envelope>
                    <SOAP-ENV:Body>
                    <tns:webServiceClient>
                    <tns:id>1</tns:id>
                    <tns:customerName>test</tns:customerName>
                    <tns:customerUserName>test</tns:customerUserName>
                    <tns:custoemrPw>test</tns:custoemrPw>
                    </tns:webServiceClient>
                    <ns0:chucksPick3LotteryNumber>
                    <ns0:number>234</ns0:number>
                    <ns0:requestDate xsi:nil="true"/>
                    <ns0:drawingType>Day</ns0:drawingType>
                    <ns0:type>Customer Provided Winning Pick 3 Lottery Number</ns0:type>
                    </ns0:chucksPick3LotteryNumber>
                    </SOAP-ENV:Body>
                    I think there is a bug in the code generated from the Fx Webservice Introspection wizard. You can down load my wsdl at http://bugs.adobe.com/jira/secure/attachment/25971/chuckspick3.wsdl.xml. I hope someone will respond to this post as I really want to use flex for webservices; but have not been successful.
                    Thanks!
                    • 7. Re: Need help with Flex3 Web Services.
                      grkkrishna
                      Hi
                      this topic is very good
                      • 8. Need help with Flex3 Web Services.
                        grkkrishna Level 1
                        Hi
                        best topic
                        • 9. Re: Need help with Flex3 Web Services.
                          etnot96 Level 1
                          I fixed my issue with my webservices. It turns out the generated webservices did not include the root node that my webservices was expecting. So I had to extend the generated webservices to include the right node.
