Bonsoir je suis actuellement un débutant et dans ma composition je peux déplacer les images ou les secondes 1 par 1.
Avez-vous une solution a mon problème ?
Merci.
Make your composition longer.
The current time indicator can not sit in between frames. It only sits on whole frames.
Your composition is only a couple of frames long. Most videos are 24, 25, 30, or 60 frames per second. If you have only 5 frames in your composition, your composition is only a fraction of a second long. That is the situation you are in. Make your composition five seconds long instead of five frames long and things will behave more like you expect.
Your composition is only 5 FRAMES long. It is NOT 5 seconds long. The timeline is showing you frames zero through four.
You can change the length in the composition settings.
Je ne peux pas déplacer mon curseur sur ma timeline comme dans cette vidéo.(4:03)
Si vous avez le temps pouvez vous me faire un petit tutoriel avec des images ?
Go to your composition settings:
See how this value is only five frames long? Change this value:
See how it's now changed to five seconds long? Change it to be something like this:
Press OK. Now you'll probably notice that your timeline is zoomed way in so you're still looking at the same five frames.
Now drag on that little bar up there (or go to the bottom where the little mountain pictures are and zoom out on your timeline.
And you will see that it looks like this now:
It should now behave as you expect.
C'est bon vous aviez raison merci pour votre aide.
If any of these posts helped you, don't forget to mark the post with the right answer as the Correct Answer by pressing the button with the green star under the appropriate post.
Merci beaucoup pour votre aide. ^^
You are welcome.
