I created a table of contents and need help figuring out how to split in it into columns (2 per page). So far all I can get it to do is have one long column that I can't fit onto one page. I tried the "span column" function in the control panel menu but can't get that to work either. Do I have to create 4 different TOC styles to get the desired columns?
Also, a side note my mac keeps freezing up when I try to highlight anything in the TOC text box. Anyone else have this issue?
Ken
Posting screenshots showing what you want and what you are getting presently would have been helpful.
Just to demonstrate I creates a very basic TOC...
I then divided the columns in 2. Do note I have some overset text in my TOC text frame.
When I divided I got some of my overset text in the second column. I then pressed the outport of this frame and placed the remaining overset text of the TOC frame on a new page
You can then use Span columns if you intend to make the title "Content" span across the 2 columns
Let me know if this is something what you wanted.
Regarding the problem
Ken
You can update to InDesign CC 2017.1 if you are on InDesign CC 2017.0 and it may resolve your issue.
If you for some reason do not wish to upgrade then try this Troubleshoot text selection issues
-Aman
