2 Replies Latest reply on Jun 1, 2017 1:26 AM by c.pfaffenbichler
    Galleries de filtres
    thierryl60103786
      Bonjour
      Depuis un moment, l'application de certains filtres sur mes photos ne fonctionne plus
      Je vois la vignertte avec les modifications selon les parametres que j'utilise, puis au moment d'appliquer, rien ne se passe
      Je suis abonné a Photoshop CS - donc logiciel a jour.
      Merci de vos aides
      Thierry
        • 1. Re: Galleries de filtres
          Trevor.Dennis Adobe Community Professional
          thierryl60103786  wrote
          Hello
          For a while, the application of some filters on my photos no longer works
          I see the vignertte with changes according to the parameters I use, then when applying, nothing happens
          I am a Subscriber has Photoshop CS - so software update.
          Thank you for your aid
          Thierry
          Hi Thierry.  What zoom ratio are you viewing the images at?  If it is a high res image, as are so many photographs with today's high res camera sensors, then viewing at a 'Fit to Screen' ratio will not show anything in the preview unless you use high settings.  You need to set the zoom to 100% to get a true preview.
          • 2. Re: Galleries de filtres
            c.pfaffenbichler Level 9
            Could you please post screenshots taken at View > 100% and with the pertinent Panels (Layers, Channels, Options Bar, …) visible?
