This content has been marked as final.
Show 8 replies
1. Re: Collection filtering performance issue
Newsgroup_User Dec 29, 2008 9:06 AM (in response to rtalton)Try just running the e4x expression that's the same as the filter and
checking its length. Or use that instead of a filterFunction to come up
with the XMLList in the first place.
HTH;
Amy
"rtalton" <webforumsuser@macromedia.com> wrote in message
news:gjavn6$7s3$1@forums.macromedia.com...
> I'm filtering a XMLListCollection by date. The date in the Collection has
> to be
>>= today's date, and then a List component using it as a dataProvider will
>>show
> only items with an item date >= today.
> Today I ran into an issue where if there are no items matching this
> criteria,
> the List opens up empty. Confusing. So I added a line after the List's
> filter
> is applied to check if the length property of the dataProvider == 0 after
> filtering. If so, I remove the filter, and apply the refresh() method, and
> now
> all items are showing. This seems terribly inefficient and makes the List
> flicker, but I can't think of a way to check for zero items before a
> filter is
> applied.
> Any ideas on how I could do this efficiently?
2. Re: Collection filtering performance issue
rtalton Dec 29, 2008 10:40 AM (in response to rtalton)Thanks Amy, that helped. Only problem I had was I got an error when trying to filter my XMLListCollection directly "Can't apply e4x filtering to...", or something like that. Didn't know that was a no-no as I'd never tried it before.
I created a temp var as XMLList, assigned the HTTPService's lastResult (e4x format) to it with an e4x filtering expression, and checked its length:
var tempList:XMLList = new XMLList;
tempList = eventsService.lastResult..event.(eventdate >= startDate);
if (tempList.length > 0){
//..calls function to filter XMLListCollection here...
This worked fine. Any comments on doing it this way?
Thanks again for your assistance! -
3. Re: Collection filtering performance issue
ntsiii Dec 29, 2008 11:33 AM (in response to rtalton)* you do not need to "new" the XMLList
* don't use lastResult in code. Use event.result. lastResult can be overwritten, nulled, etc by the framework outside of your control. It is rarely a problem in simple apps, but still..
* With XMLList, always use the *method*, with the parens, length() to check the length.
Tracy -
4. Re: Collection filtering performance issue
rtalton Dec 29, 2008 11:53 AM (in response to rtalton)I made the changes you suggested, thanks.
One question...
When I create the XMLList and do the e4x filtered assignment to it, the length property is not available in the debug window (if there is no data as a result of the filter), so I can't see the length prop at all. That's why I tried the new keyword, but that didn't expose the length prop, either.
I've run into this before, but never found out why this is. Do you know? -
5. Re: Collection filtering performance issue
Newsgroup_User Dec 29, 2008 1:46 PM (in response to rtalton)
news:gjb9sg$k87$1@forums.macromedia.com...
> One question...
> length
> result
> the
If you're talking about in the expressions window, look at this:
http://flexdiary.blogspot.com/2008/03/debugger-and-e4x.html
Also, be aware that length on an XMLList is a method, not a property, so you
actually have to _call_ the method to retrieve the length...you can't
inspect it as if it were a property.
HTH;
Amy
6. Re: Collection filtering performance issue
rtalton Dec 29, 2008 2:07 PM (in response to rtalton)Hi Amy!
Yeah, I knew the expressions window cannot parse e4x expressions. I'm talking about the variables window not showing props for a var within my function when I assign data using an e4x expression. I just though if I created a var as XMLList, it would have a length prop, even before any assignments to it. -
7. Re: Collection filtering performance issue
rtalton Dec 29, 2008 2:09 PM (in response to rtalton)I just re-read your reply..."length on an XMLList is a method, not a property" that answers my question, thanks again! -
8. Re: Collection filtering performance issue
Newsgroup_User Dec 29, 2008 6:25 PM (in response to rtalton)
news:gjbhrf$lk$1@forums.macromedia.com...
You're welcome :-)
