14 Replies Latest reply on Jun 22, 2017 11:00 AM by rayek.elfin
    Photoshop Speed issue
    carlm46444995
      My work computer has issues when it comes to Photoshop and it's basic features.  Takes a full minute to show me font options, application freezes for basic tasks like switching tools.  I have already "optimized" my Photoshop setup and have gone through the entire forum post describing all the ways to improve performance.  My work computer is quite the beast:
      • 64 GB of ram
      • intel core, i7-6900K cpu - 3.20ghz
      • 2 GPU's GTX 1070, and 1080
      • 2 TB Hard Drive
      I switch between my SDD and HD and both have poor performance, my SDD is kinda full so ill stick to the HD for now.  This computer is optimized for 3D rendering ( if that affects anything ) and cost around $5000.  Yet my $2000 home computer i built myself, with about half of the specs that i have given here, has no trouble at all with photoshop.  If i had to guess there has to be some type of software issue, some driven not updated or something.  But im not sure, hope I can get some insight here, thanks.
        • 2. Re: Photoshop Speed issue
          carlm46444995 Level 1
          Most of these thread are not specific to my issue.  It is not a layer issue when it comes to type, its when i attempt to pick the font, its as if it having trouble loading my fonts.  And this is an overall issue with Photoshop, I have checked my task manager while these issues happen, and Photoshop stops responding and only maxes out at 19% memory usage, and a mere 5% CPU is being used.
          • 3. Re: Photoshop Speed issue
            This issue is still not solved, and adobe's "solution" of having a community driven forum to help there own customer is a cheap solution.  This is incredibly unhelpful, I CANNOT USE YOUR PROGRAM PROPERLY  - it runs slow, slows down for every task, and this doesnt happen on computers with worse specs.  I have gone through all the pre-written , one size fits all, troubleshooting forums for performance issues, they have not solved this issue.  Not to mention you don't even allow us the option to contact support directly if we need, if its a "troubleshooting" question, you only give us one option, the forums, that is basically a gamble if people feel like helping or not.
            • 4. Re: Photoshop Speed issue
              I can not agree with your statement "a community driven forum to help there own customer is a cheap solution.  This is incredibly unhelpful" Most users will not agree with incredibly unhelpful.   You right about it not being an expensive line item for Adobe.   If you wish to communicate this to Adobe you should you the site the setup for feedback to them: Photoshop Family Customer Community not this forun as you know we are users like you.
              • 5. Re: Photoshop Speed issue
                Let me rephrase:  It's unhelpful to me."  My issue went into a sea of issues of hundreds of users and was answered, once.  incorrectly.  So, I was not helped, and they only way to get more help is to ask again.  My issue still stands, photoshop is running bad.  Its a top of the line PC, and it can't run Photoshop properly.  I have done EVERYTHING posted on these forums about "optimizing", It's obvious that it is an advanced issue, and I am at the mercy of some photoshop master of peering at forum post.  This area should be a last resort, not the only resort....
                • 6. Re: Photoshop Speed issue
                  Have you posted  your Photoshop CC 2017.1.1 menu Helpl>System Info?  If not you should. Someone here may see something in there that is meaningless to you but may help others see where you many have a problem.  We do not use crystal balls here we need more then that.  Even if you machine only  has a slow hard drive  Photoshop should perform better then way your getting and Photoshop should not freeze.   You  install may be triggering bugs others may not be.  You problem could be an Adobe bug or it could be an installation or configuration problem. The more system information you give us gives us more to think about. Follow the guide lines:
                  Supply pertinent information for quicker answers
                  • The more information you supply about your situation, the better equipped other community members will be to answer. Consider including the following in your question:
                  • Adobe product and version number
                  • Operating system and version number
                  • The full text of any error message(s)
                  • What you were doing when the problem occurred
                  • Screenshots of the problem
                  • Computer hardware, such as CPU; GPU; amount of RAM; etc.
                  • 7. Re: Photoshop Speed issue
                    I would have easily supplied this if I was asked, I had no clue what you needed, sorry.  This whole process is very frustrating.
                    • 8. Re: Photoshop Speed issue
                      Then Please do it it should look something like this not a single line. We should not need to] ask....
                      Adobe Photoshop Version: 2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967  x64
                      Number of Launches: 481
                      Version: 10 or greater
                      System architecture: Intel CPU Family:6, Model:13, Stepping:7 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, HyperThreading
                      Physical processor count: 12
                      Logical processor count: 24
                      Processor speed: 1995 MHz
                      Built-in memory: 40886 MB
                      Free memory: 2 MB
                      Memory available to Photoshop: 36954 MB
                      Memory used by Photoshop: 70 %
                      History Thumbnails: Disabled.
                      Touch Bar: Disabled.
                      Alias Layers: Disabled.
                      Modifier Palette: Disabled.
                      Highbeam: Enabled.
                      Image tile size: 1028K
                      Image cache levels: 6
                      Font Preview: Medium
                      TextComposer: Latin
                      Display: 1
                      Display Bounds: top=0, left=0, bottom=1080, right=1920
                      Display: 2
                      Display Bounds: top=0, left=-1360, bottom=768, right=0
                      OpenGL Drawing: Enabled.
                      OpenGL Allow Old GPUs: Not Detected.
                      OpenGL Drawing Mode: Normal
                      OpenGL Allow Normal Mode: True.
                      OpenGL Allow Advanced Mode: False.
                      AIFCoreInitialized=1
                      AIFOGLInitialized=1
                      OGLContextCreated=1
                      NumGLGPUs=1
                      NumCLGPUs=1
                      NumNativeGPUs=0
                      glgpu[0].GLVersion="4.1"
                      glgpu[0].IsIntegratedGLGPU=0
                      glgpu[0].GLMemoryMB=2048
                      glgpu[0].GLName="NVIDIA Quadro 4000"
                      glgpu[0].GLVendor="NVIDIA Corporation"
                      glgpu[0].GLVendorID=4318
                      glgpu[0].GLDriverVersion="21.21.13.7735"
                      glgpu[0].GLRectTextureSize=16384
                      glgpu[0].GLRenderer="Quadro 4000/PCIe/SSE2"
                      glgpu[0].GLRendererID=1757
                      glgpu[0].HasGLNPOTSupport=1
                      glgpu[0].GLDriver="C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_2db3 5200ede2a85a\nvd3dumx,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispwi.inf_amd64_2 db35200ede2a85a\nvwgf2umx,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispwi.inf_amd 64_2db35200ede2a85a\nvwgf2umx,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispwi.inf _amd64_2db35200ede2a85a\nvwgf2umx,C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispwi .inf_amd64_2db35200ede2a85a\nvd3dum,C:\WINDOWS\System32\DriverStore\FileRepository\nv_disp wi.inf_amd64_2db35200ede2a85a\nvwgf2um,C:\WINDOWS\System32\DriverStore\FileRepository\nv_d ispwi.inf_amd64_2db35200ede2a85a\nvwgf2um,C:\WINDOWS\System32\DriverStore\FileRepository\n v_dispwi.inf_amd64_2db35200ede2a85a\nvwgf2um"
                      glgpu[0].GLDriverDate="20170501000000.000000-000"
                      glgpu[0].CanCompileProgramGLSL=1
                      glgpu[0].GLFrameBufferOK=1
                      glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.50 NVIDIA"
                      glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[6553 6]
                      glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
                      glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
                      glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
                      glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
                      glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
                      glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
                      glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
                      glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
                      glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
                      glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
                      glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
                      glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
                      glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
                      glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
                      glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
                      glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
                      glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
                      glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
                      glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
                      clgpu[0].CLPlatformVersion="1.2"
                      clgpu[0].CLDeviceVersion="1.1 CUDA"
                      clgpu[0].IsIntegratedCLGPU=0
                      clgpu[0].CLMemoryMB=2048
                      clgpu[0].CLName="Quadro 4000"
                      clgpu[0].CLVendor="NVIDIA Corporation"
                      clgpu[0].CLVendorID=4318
                      clgpu[0].CLDriverVersion="377.35"
                      clgpu[0].CLBandwidth=7.48181e+10
                      clgpu[0].CLCompute=191.65
                      License Type: Subscription
                      Serial number: 90970090970448917498
                      GUIDBucket:
                        bucket: 235
                        test: DocumentPanel
                      Application folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\
                      Temporary file path: C:\Users\JOHNJM~1\AppData\Local\Temp\
                      Photoshop scratch has async I/O enabled
                      Scratch volume(s):
                        E:\, 3.64T, 3.11T free
                      Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\Plug-ins\
                      Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\
                      Installed components:
                         A3DLIBS.dll   A3DLIB Dynamic Link Library   9.2.0.112
                         ACE.dll   ACE 2017/01/26-01:10:02   79.579975   79.579975
                         AdbePM.dll   PatchMatch 2016/11/03:19:48:57   1.578146   1.578146
                         AdobeLinguistic.dll   Adobe Linguisitc Library   10.0.0
                         AdobeOwl.dll   Adobe Owl   5.2.11
                         AdobePDFL.dll   PDFL 2016/08/10-16:53:20   79.195992   79.195992
                         AdobePIP.dll   Adobe Product Improvement Program   7.4.1.60.45263
                         AdobeSVGAGM.dll   AdobeSVGAGM   79.579975   79.579975
                         AdobeXMP.dll   Adobe XMP Core 2016/09/14-01:09:01   79.159824   79.159824
                         AdobeXMPFiles.dll   Adobe XMP Files 2016/09/14-01:09:01   79.159824   79.159824
                         AdobeXMPScript.dll   Adobe XMP Script 2016/09/14-01:09:01   79.159824   79.159824
                         adobe_caps.dll   Adobe CAPS   10,0,0,6
                         AGM.dll   AGM 2017/01/26-01:10:02   79.579975   79.579975
                         ahclient.dll    AdobeHelp Dynamic Link Library   2.2.0.1
                         AIDE.dll   AIDE 2016/05/27-01:08:49   79.574279   79.574279
                         amtlib.dll   AMTLib (64 Bit)   10.0.0.119 BuildVersion: 10.0; BuildDate: Thu Dec 22 2016 3:0:7)   1.000000
                         ARE.dll   ARE 2017/01/26-01:10:02   79.579975   79.579975
                         AXE8SharedExpat.dll   AXE8SharedExpat 2015/03/13-23:40:54   79.562390   79.562390
                         AXEDOMCore.dll   AXEDOMCore 2015/03/13-23:40:54   79.562390   79.562390
                         Bib.dll   BIB 2017/01/26-01:10:02   79.579975   79.579975
                         BIBUtils.dll   BIBUtils 2017/01/26-01:10:02   79.579975   79.579975
                         boost_date_time.dll   photoshopdva   10.0.0
                         boost_signals.dll   photoshopdva   10.0.0
                         boost_system.dll   photoshopdva   10.0.0
                         boost_threads.dll   photoshopdva   10.0.0
                         cg.dll   NVIDIA Cg Runtime   3.0.00007
                         cgGL.dll   NVIDIA Cg Runtime   3.0.00007
                         CITThreading.dll   Adobe CITThreading   2.1.0.1   2.1.0.1
                         CoolType.dll   CoolType 2017/01/26-01:10:02   79.579975   79.579975
                         dnssd.dll   Bonjour   3,0,0,2
                         dvaaudiodevice.dll   photoshopdva   10.0.0
                         dvacore.dll   photoshopdva   10.0.0
                         dvacrashhandler.dll   Adobe Audition CC 2017   10.0.0
                         dvamarshal.dll   photoshopdva   10.0.0
                         dvamediatypes.dll   photoshopdva   10.0.0
                         dvametadata.dll   photoshopdva   10.0.0
                         dvametadataapi.dll   photoshopdva   10.0.0
                         dvametadataui.dll   photoshopdva   10.0.0
                         dvaplayer.dll   photoshopdva   10.0.0
                         dvatransport.dll   photoshopdva   10.0.0
                         dvaui.dll   photoshopdva   10.0.0
                         dvaunittesting.dll   photoshopdva   10.0.0
                         dynamiclink.dll   photoshopdva   10.0.0
                         ExtendScript.dll   ExtendScript 2016/12/13-13:10:33   80.1089815   80.1089815
                         icucnv40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
                         icudt40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
                         icuuc40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
                         igestep30.dll   IGES Reader   9.3.0.113
                         imslib.dll   IMSLib DLL   10.0.0.11
                         JP2KLib.dll   JP2KLib 2017/04/05-14:24:38   79.266006   79.266006
                         libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
                         libiomp5md.dll   Intel(R) OpenMP* Runtime Library   5.0
                         libmmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
                         LogSession.dll   LogSession   7.4.1.60.45263
                         mediacoreif.dll   photoshopdva   10.0.0
                         MPS.dll   MPS 2016/09/14-15:20:26   79.577269   79.577269
                         pdfsettings.dll   Adobe PDFSettings   1.04
                         Photoshop.dll   Adobe Photoshop CC 2017   18.1.1
                         Plugin.dll   Adobe Photoshop CC 2017   18.1.1
                         PlugPlugExternalObject.dll   Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit)   7.0.0
                         PlugPlugOwl.dll   Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit)   7.0.0.67
                         PSArt.dll   Adobe Photoshop CC 2017   18.1.1
                         PSViews.dll   Adobe Photoshop CC 2017   18.1.1
                         SCCore.dll   ScCore 2016/12/13-13:10:33   80.1089815   80.1089815
                         SVGRE.dll   SVGRE   79.579975   79.579975
                         svml_dispmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
                         tbb.dll   Intel(R) Threading Building Blocks for Windows   4, 4, 2016, 0412
                         tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   4, 4, 2016, 0412
                         TfFontMgr.dll   FontMgr   9.3.0.113
                         TfKernel.dll   Kernel   9.3.0.113
                         TFKGEOM.dll   Kernel Geom   9.3.0.113
                         TFUGEOM.dll   Adobe, UGeom©   9.3.0.113
                         updaternotifications.dll   Adobe Updater Notifications Library   10.0.0.1 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   10.0.0.1
                         VulcanControl.dll   Vulcan Application Control Library   5.3.0.16
                         VulcanMessage5.dll   Vulcan Message Library   5.3.0.16
                         WRServices.dll   WRServices Thu Jan 07 2016 04:50:10   Build 0.21960   0.21960
                         wu3d.dll   U3D Writer   9.3.0.113
                      Required plug-ins:
                         3D Studio 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                         Accented Edges 18.1.1 - from the file “Filter Gallery.8bf”
                         Adaptive Wide Angle 18.1.1 - from the file “Adaptive Wide Angle.8bf”
                         Angled Strokes 18.1.1 - from the file “Filter Gallery.8bf”
                         Average 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Average.8bf”
                         Bas Relief 18.1.1 - from the file “Filter Gallery.8bf”
                         BMP 18.1.1 - from the file “Standard MultiPlugin.8bf”
                         Camera Raw 9.10.1 - from the file “Camera Raw.8bi”
                         Camera Raw Filter 9.10.1 - from the file “Camera Raw.8bi”
                         Chalk && Charcoal 18.1.1 - from the file “Filter Gallery.8bf”
                         Chrome 18.1.1 - from the file “Filter Gallery.8bf”
                         Cineon 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Cineon.8bi”
                         Clouds 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Clouds.8bf”
                         Collada 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                         Color Halftone 18.1.1 - from the file “Standard MultiPlugin.8bf”
                         Colored Pencil 18.1.1 - from the file “Filter Gallery.8bf”
                         CompuServe GIF 18.1.1 - from the file “Standard MultiPlugin.8bf”
                         Conté Crayon 18.1.1 - from the file “Filter Gallery.8bf”
                         Craquelure 18.1.1 - from the file “Filter Gallery.8bf”
                         Crop and Straighten Photos 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “CropPhotosAuto.8li”
                         Crop and Straighten Photos Filter 18.1.1 - from the file “Standard MultiPlugin.8bf”
                         Crosshatch 18.1.1 - from the file “Filter Gallery.8bf”
                         Crystallize 18.1.1 - from the file “Standard MultiPlugin.8bf”
                         Cutout 18.1.1 - from the file “Filter Gallery.8bf”
                         Dark Strokes 18.1.1 - from the file “Filter Gallery.8bf”
                         De-Interlace 18.1.1 - from the file “Standard MultiPlugin.8bf”
                         Dicom 18.1.1 - from the file “Dicom.8bi”
                         Difference Clouds 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Clouds.8bf”
                         Diffuse Glow 18.1.1 - from the file “Filter Gallery.8bf”
                         Displace 18.1.1 - from the file “Standard MultiPlugin.8bf”
                         Dry Brush 18.1.1 - from the file “Filter Gallery.8bf”
                         Eazel Acquire 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “EazelAcquire.8ba”
                         Entropy 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                         Export Color Lookup Tables 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Export3DLUT.8be”
                         Extrude 18.1.1 - from the file “Standard MultiPlugin.8bf”
                         FastCore Routines 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “FastCore.8bx”
                         Fibers 18.1.1 - from the file “Standard MultiPlugin.8bf”
                         Film Grain 18.1.1 - from the file “Filter Gallery.8bf”
                         Filter Gallery 18.1.1 - from the file “Filter Gallery.8bf”
                         Flash 3D 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                         Fresco 18.1.1 - from the file “Filter Gallery.8bf”
                         Glass 18.1.1 - from the file “Filter Gallery.8bf”
                         Glowing Edges 18.1.1 - from the file “Filter Gallery.8bf”
                         Google Earth 4 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                         Graphic Pen 18.1.1 - from the file “Filter Gallery.8bf”
                         Halftone Pattern 18.1.1 - from the file “Filter Gallery.8bf”
                         HDRMergeUI 18.1.1 - from the file “HDRMergeUI.8bf”
                         HSB/HSL 18.1.1 - from the file “Standard MultiPlugin.8bf”
                         IFF Format 18.1.1 - from the file “Standard MultiPlugin.8bf”
                         IGES 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                         Ink Outlines 18.1.1 - from the file “Filter Gallery.8bf”
                         JPEG 2000 18.1.1 - from the file “JPEG2000.8bi”
                         Kurtosis 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                         Lens Blur 18.1.1 - from the file “Lens Blur.8bf”
                         Lens Correction 18.1.1 - from the file “Lens Correction.8bf”
                         Lens Flare 18.1.1 - from the file “Standard MultiPlugin.8bf”
                         Liquify 18.1.1 - from the file “Liquify.8bf”
                         Matlab Operation 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “ChannelPort.8bf”
                         Maximum 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                         Mean 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                         Measurement Core 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “MeasurementCore.8me”
                         Median 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                         Mezzotint 18.1.1 - from the file “Standard MultiPlugin.8bf”
                         Minimum 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                         MMXCore Routines 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “MMXCore.8bx”
                         Mosaic Tiles 18.1.1 - from the file “Filter Gallery.8bf”
                         Multiprocessor Support 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “MultiProcessor Support.8bx”
                         Neon Glow 18.1.1 - from the file “Filter Gallery.8bf”
                         Note Paper 18.1.1 - from the file “Filter Gallery.8bf”
                         NTSC Colors 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “NTSC Colors.8bf”
                         Ocean Ripple 18.1.1 - from the file “Filter Gallery.8bf”
                         OpenEXR 18.1.1 - from the file “Standard MultiPlugin.8bf”
                         Paint Daubs 18.1.1 - from the file “Filter Gallery.8bf”
                         Palette Knife 18.1.1 - from the file “Filter Gallery.8bf”
                         Patchwork 18.1.1 - from the file “Filter Gallery.8bf”
                         Paths to Illustrator 18.1.1 - from the file “Standard MultiPlugin.8bf”
                         PCX 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “PCX.8bi”
                         Photocopy 18.1.1 - from the file “Filter Gallery.8bf”
                         Photoshop 3D Engine 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Photoshop3DEngine.8bi”
                         Photoshop Touch 14.0 - from the file “PSDX.8bi”
                         Picture Package Filter 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “ChannelPort.8bf”
                         Pinch 18.1.1 - from the file “Standard MultiPlugin.8bf”
                         Pixar 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Pixar.8bi”
                         Plaster 18.1.1 - from the file “Filter Gallery.8bf”
                         Plastic Wrap 18.1.1 - from the file “Filter Gallery.8bf”
                         PLY 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                         PNG 18.1.1 - from the file “Standard MultiPlugin.8bf”
                         Pointillize 18.1.1 - from the file “Standard MultiPlugin.8bf”
                         Polar Coordinates 18.1.1 - from the file “Standard MultiPlugin.8bf”
                         Portable Bit Map 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “PBM.8bi”
                         Poster Edges 18.1.1 - from the file “Filter Gallery.8bf”
                         PRC 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                         Radial Blur 18.1.1 - from the file “Standard MultiPlugin.8bf”
                         Radiance 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Radiance.8bi”
                         Range 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                         Render Color Lookup Grid 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Export3DLUT.8be”
                         Reticulation 18.1.1 - from the file “Filter Gallery.8bf”
                         Ripple 18.1.1 - from the file “Standard MultiPlugin.8bf”
                         Rough Pastels 18.1.1 - from the file “Filter Gallery.8bf”
                         Save for Web 18.1.1 - from the file “Save for Web.8be”
                         ScriptingSupport 18.1.1 - from the file “ScriptingSupport.8li”
                         Shake Reduction 18.1.1 - from the file “Shake Reduction.8bf”
                         Shear 18.1.1 - from the file “Standard MultiPlugin.8bf”
                         Skewness 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                         Smart Blur 18.1.1 - from the file “Standard MultiPlugin.8bf”
                         Smudge Stick 18.1.1 - from the file “Filter Gallery.8bf”
                         Solarize 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Solarize.8bf”
                         Spaces 18.1.1 - from the file “Spaces.8li”
                         Spatter 18.1.1 - from the file “Filter Gallery.8bf”
                         Spherize 18.1.1 - from the file “Standard MultiPlugin.8bf”
                         Sponge 18.1.1 - from the file “Filter Gallery.8bf”
                         Sprayed Strokes 18.1.1 - from the file “Filter Gallery.8bf”
                         Stained Glass 18.1.1 - from the file “Filter Gallery.8bf”
                         Stamp 18.1.1 - from the file “Filter Gallery.8bf”
                         Standard Deviation 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                         STL 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                         Sumi-e 18.1.1 - from the file “Filter Gallery.8bf”
                         Summation 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                         Targa 18.1.1 - from the file “Standard MultiPlugin.8bf”
                         Texturizer 18.1.1 - from the file “Filter Gallery.8bf”
                         Tiles 18.1.1 - from the file “Standard MultiPlugin.8bf”
                         Torn Edges 18.1.1 - from the file “Filter Gallery.8bf”
                         Twirl 18.1.1 - from the file “Standard MultiPlugin.8bf”
                         U3D 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                         Underpainting 18.1.1 - from the file “Filter Gallery.8bf”
                         Vanishing Point 18.1.1 - from the file “VanishingPoint.8bf”
                         Variance 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                         Virtual Reality Modeling Language | VRML 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                         Water Paper 18.1.1 - from the file “Filter Gallery.8bf”
                         Watercolor 18.1.1 - from the file “Filter Gallery.8bf”
                         Wave 18.1.1 - from the file “Standard MultiPlugin.8bf”
                         Wavefront|OBJ 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                         WIA Support 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “WIASupport.8li”
                         Wind 18.1.1 - from the file “Standard MultiPlugin.8bf”
                         Wireless Bitmap 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “WBMP.8bi”
                         ZigZag 18.1.1 - from the file “Standard MultiPlugin.8bf”
                      Optional and third party plug-ins:
                         Analog Efex Pro 2 2.0.12.12 - from the file “C:\Program Files\Google\Nik Collection\Analog Efex Pro 2\Analog Efex Pro 2 (64-Bit)\Analog Efex Pro 2.8bf”
                         BackgroundFilter 2.2.21.12 - from the file “C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\Background.8bf”
                         Color Efex Pro 4 4.3.24.12 - from the file “C:\Program Files\Google\Nik Collection\Color Efex Pro 4\Color Efex Pro 4 (64-Bit)\Color Efex Pro 4.8bf”
                         CUR (Windows Cursor) NO VERSION - from the file “C:\Photoshop64 Plug-Ins\icon format\ICOFormat64.8bi”
                         Dfine 2 2.2.21.12 - from the file “C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\Dfine2.8bf”
                         Face Control II 2.00 - from the file “C:\Photoshop64 Plug-Ins\Redfield\FaceControl(X64).8bf”
                         Fine Touch 3.25 - from the file “C:\Photoshop64 Plug-Ins\Redfield\FineTouch(X64).8bf”
                         FineStructuresFilter 2.2.21.12 - from the file “C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\FineStructures.8bf”
                         GREYCstoration NO VERSION - from the file “C:\Photoshop64 Plug-Ins\GreycShop_x64_LAA_2013-08-04\Greyc-x64.8bf”
                         HDR Efex Pro 2 2.2.24.12 - from the file “C:\Program Files\Google\Nik Collection\HDR Efex Pro 2\HDR Efex Pro 2 (64-Bit)\HDR Efex Pro 2.8bf”
                         HotPixelsFilter 2.2.21.12 - from the file “C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\HotPixels.8bf”
                         ICO Windows Icon/Favicon NO VERSION - from the file “C:\Photoshop64 Plug-Ins\icon format\ICOFormat64.8bi”
                         Import from FastPictureViewer Codec Pack 3.8.0.96 - from the file “C:\Photoshop64 Plug-Ins\FastPictureViewerCodecPack\FastPictureViewerCodecPack.PhotoshopImport64.8ba”
                         JPEG XR 1, 1, 0, 0 - from the file “C:\Photoshop64 Plug-Ins\Microsoft\JPEGXR_x64.8bi”
                         Lazy Nezumi Pro 17.06.09.0147 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\MouseHookPro64.8li”
                         Luce NO VERSION - from the file “C:\Photoshop64 Plug-Ins\Luce2_64\luce_64.8bf”
                         Merge to HDR Efex Pro 2 2.2.24.12 - from the file “C:\Program Files\Google\Nik Collection\HDR Efex Pro 2\HDR Efex Pro 2 (64-Bit)\HDR Efex Pro 2.8bf”
                         Nik Collection Selective Tool 2.1.28 - from the file “C:\Photoshop64 Plug-Ins\Google\Selective Tool\SelectivePalette.8li”
                         Reduce Noise v8 8.2.0.0 - from the file “C:\Photoshop64 Plug-Ins\NeatImage8\NeatImage8.8bf”
                         ScriptListener 13.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\ScriptListener.8li”
                         SGI RGB 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00) - from the file “C:\Photoshop64 Plug-Ins\SGIRGB\SGIRGB.8BI”
                         ShadowsFilter 2.2.21.12 - from the file “C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\Shadows.8bf”
                         Sharpener Pro 3: (1) RAW Presharpener 3.1.21.12 - from the file “C:\Program Files\Google\Nik Collection\Sharpener Pro 3\Sharpener Pro 3 (64-Bit)\SHP3RPS.8bf”
                         Sharpener Pro 3: (2) Output Sharpener 3.1.21.12 - from the file “C:\Program Files\Google\Nik Collection\Sharpener Pro 3\Sharpener Pro 3 (64-Bit)\SHP3OS.8bf”
                         Silver Efex Pro 2 2.2.24.12 - from the file “C:\Program Files\Google\Nik Collection\Silver Efex Pro 2\Silver Efex Pro 2 (64-Bit)\Silver Efex Pro 2.8bf”
                         SkinFilter 2.2.21.12 - from the file “C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\Skin.8bf”
                         SkyFilter 2.2.21.12 - from the file “C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\Sky.8bf”
                         StarFilter Pro 3 3.0.5.1 - from the file “C:\Photoshop64 Plug-Ins\ProDigitalSoftware\StarFilterPro3X64.8bf”
                         StrongNoiseFilter 2.2.21.12 - from the file “C:\Program Files\Google\Nik Collection\Dfine 2\Dfine 2 (64-Bit)\StrongNoise.8bf”
                         SuperPNG 2.0 - from the file “C:\Photoshop64 Plug-Ins\SuperPNG\SuperPNG.8bi”
                         Viveza 2 2.1.21.12 - from the file “C:\Program Files\Google\Nik Collection\Viveza 2\Viveza 2 (64-Bit)\Viveza2.8bf”
                      Duplicate and Disabled plug-ins: NONE
                      Plug-ins that failed to load: NONE
                      Extensions: NONE
                      Installed TWAIN devices: NONE
                      • 9. Re: Photoshop Speed issue
                        Number of Launches: 2
                        Version: 8.1
                        System architecture: Intel CPU Family:6, Model:15, Stepping:1 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2, HyperThreading
                        Physical processor count: 8
                        Logical processor count: 16
                        Processor speed: 3199 MHz
                        Built-in memory: 65459 MB
                        Free memory: 2 MB
                        Memory available to Photoshop: 59448 MB
                        History Thumbnails: Enabled.
                        Touch Bar: Enabled.
                        Modifier Palette: Enabled.
                        Highbeam: Enabled.
                        Image tile size: 1024K
                        Image cache levels: 4
                        TextComposer: Latin
                        Display: 1
                        Display: 2
                        Display Bounds: top=0, left=1920, bottom=1080, right=3840
                        OpenGL Drawing Mode: Advanced
                        OpenGL Allow Advanced Mode: True.
                        AIFOGLInitialized=1
                        OGLContextCreated=1
                        NumGLGPUs=1
                        NumCLGPUs=2
                        NumNativeGPUs=0
                        glgpu[0].GLMemoryMB=8192
                        glgpu[0].GLName="NVIDIA GeForce GTX 1070"
                        glgpu[0].GLDriverVersion="22.21.13.8253"
                        glgpu[0].GLRectTextureSize=32768
                        glgpu[0].GLRenderer="GeForce GTX 1070/PCIe/SSE2"
                        glgpu[0].GLRendererID=7041
                        glgpu[0].GLDriver="nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um"
                        glgpu[0].GLDriverDate="20170607000000.000000-000"
                        clgpu[0].CLDeviceVersion="1.2 CUDA"
                        clgpu[0].CLMemoryMB=8192
                        clgpu[0].CLName="GeForce GTX 1080"
                        clgpu[0].CLDriverVersion="382.53"
                        clgpu[0].CLBandwidth=2.32531e+11
                        clgpu[0].CLCompute=3396.65
                        clgpu[1].CLPlatformVersion="1.2"
                        clgpu[1].CLDeviceVersion="1.2 CUDA"
                        clgpu[1].IsIntegratedCLGPU=0
                        clgpu[1].CLMemoryMB=8192
                        clgpu[1].CLName="GeForce GTX 1070"
                        clgpu[1].CLVendor="NVIDIA Corporation"
                        clgpu[1].CLVendorID=4318
                        clgpu[1].CLDriverVersion="382.53"
                        clgpu[1].CLBandwidth=1.99012e+11
                        clgpu[1].CLCompute=2416.49
                        Serial number: 96650247579142659760
                        GUIDBucket:
                          bucket: 222
                          test: DocumentPanel
                        Temporary file path: C:\Users\WORKST~1\AppData\Local\Temp\
                        Scratch volume(s):
                          Startup, 238.0G, 100.6G free
                        Required plug-ins:
                           3D Studio 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
                           Accented Edges 18.1.1 - from the file “Filter Gallery”
                           Adaptive Wide Angle 18.1.1 - from the file “Adaptive Wide Angle”
                           Angled Strokes 18.1.1 - from the file “Filter Gallery”
                           Average 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Average”
                           Bas Relief 18.1.1 - from the file “Filter Gallery”
                           BMP 18.1.1 - from the file “Standard MultiPlugin”
                           Camera Raw 9.10.1 - from the file “Camera Raw”
                           Camera Raw Filter 9.10.1 - from the file “Camera Raw”
                           Chalk && Charcoal 18.1.1 - from the file “Filter Gallery”
                           Chrome 18.1.1 - from the file “Filter Gallery”
                           Cineon 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Cineon”
                           Clouds 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Clouds”
                           Collada 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
                           Color Halftone 18.1.1 - from the file “Standard MultiPlugin”
                           Colored Pencil 18.1.1 - from the file “Filter Gallery”
                           CompuServe GIF 18.1.1 - from the file “Standard MultiPlugin”
                           Conté Crayon 18.1.1 - from the file “Filter Gallery”
                           Craquelure 18.1.1 - from the file “Filter Gallery”
                           Crop and Straighten Photos 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “CropPhotosAuto”
                           Crop and Straighten Photos Filter 18.1.1 - from the file “Standard MultiPlugin”
                           Crosshatch 18.1.1 - from the file “Filter Gallery”
                           Crystallize 18.1.1 - from the file “Standard MultiPlugin”
                           Cutout 18.1.1 - from the file “Filter Gallery”
                           Dark Strokes 18.1.1 - from the file “Filter Gallery”
                           De-Interlace 18.1.1 - from the file “Standard MultiPlugin”
                           Dicom 18.1.1 - from the file “Dicom”
                           Difference Clouds 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Clouds”
                           Diffuse Glow 18.1.1 - from the file “Filter Gallery”
                           Displace 18.1.1 - from the file “Standard MultiPlugin”
                           Dry Brush 18.1.1 - from the file “Filter Gallery”
                           Eazel Acquire 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “EazelAcquire”
                           Entropy 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
                           Export Color Lookup Tables 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Export3DLUT”
                           Extrude 18.1.1 - from the file “Standard MultiPlugin”
                           FastCore Routines 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “FastCore”
                           Fibers 18.1.1 - from the file “Standard MultiPlugin”
                           Film Grain 18.1.1 - from the file “Filter Gallery”
                           Filter Gallery 18.1.1 - from the file “Filter Gallery”
                           Flash 3D 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
                           Fresco 18.1.1 - from the file “Filter Gallery”
                           Glass 18.1.1 - from the file “Filter Gallery”
                           Glowing Edges 18.1.1 - from the file “Filter Gallery”
                           Google Earth 4 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
                           Graphic Pen 18.1.1 - from the file “Filter Gallery”
                           Halftone Pattern 18.1.1 - from the file “Filter Gallery”
                           HDRMergeUI 18.1.1 - from the file “HDRMergeUI”
                           HSB/HSL 18.1.1 - from the file “Standard MultiPlugin”
                           IFF Format 18.1.1 - from the file “Standard MultiPlugin”
                           IGES 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
                           Ink Outlines 18.1.1 - from the file “Filter Gallery”
                           JPEG 2000 18.1.1 - from the file “JPEG2000”
                           Kurtosis 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
                           Lens Blur 18.1.1 - from the file “Lens Blur”
                           Lens Correction 18.1.1 - from the file “Lens Correction”
                           Lens Flare 18.1.1 - from the file “Standard MultiPlugin”
                           Liquify 18.1.1 - from the file “Liquify”
                           Matlab Operation 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “ChannelPort”
                           Maximum 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
                           Mean 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
                           Median 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
                           Mezzotint 18.1.1 - from the file “Standard MultiPlugin”
                           Minimum 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
                           MMXCore Routines 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “MMXCore”
                           Mosaic Tiles 18.1.1 - from the file “Filter Gallery”
                           Multiprocessor Support 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “MultiProcessor Support”
                           Neon Glow 18.1.1 - from the file “Filter Gallery”
                           Note Paper 18.1.1 - from the file “Filter Gallery”
                           NTSC Colors 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “NTSC Colors”
                           Ocean Ripple 18.1.1 - from the file “Filter Gallery”
                           OpenEXR 18.1.1 - from the file “Standard MultiPlugin”
                           Paint Daubs 18.1.1 - from the file “Filter Gallery”
                           Palette Knife 18.1.1 - from the file “Filter Gallery”
                           Patchwork 18.1.1 - from the file “Filter Gallery”
                           Paths to Illustrator 18.1.1 - from the file “Standard MultiPlugin”
                           PCX 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “PCX”
                           Photocopy 18.1.1 - from the file “Filter Gallery”
                           Photoshop 3D Engine 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Photoshop3DEngine”
                           Photoshop Touch 14.0 - from the file “PSDX”
                           Picture Package Filter 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “ChannelPort”
                           Pinch 18.1.1 - from the file “Standard MultiPlugin”
                           Pixar 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Pixar”
                           Plaster 18.1.1 - from the file “Filter Gallery”
                           Plastic Wrap 18.1.1 - from the file “Filter Gallery”
                           PLY 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
                           PNG 18.1.1 - from the file “Standard MultiPlugin”
                           Pointillize 18.1.1 - from the file “Standard MultiPlugin”
                           Polar Coordinates 18.1.1 - from the file “Standard MultiPlugin”
                           Portable Bit Map 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “PBM”
                           Poster Edges 18.1.1 - from the file “Filter Gallery”
                           PRC 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
                           Radial Blur 18.1.1 - from the file “Standard MultiPlugin”
                           Radiance 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Radiance”
                           Range 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
                           Render Color Lookup Grid 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Export3DLUT”
                           Reticulation 18.1.1 - from the file “Filter Gallery”
                           Ripple 18.1.1 - from the file “Standard MultiPlugin”
                           Rough Pastels 18.1.1 - from the file “Filter Gallery”
                           Save for Web 18.1.1 - from the file “Save for Web”
                           ScriptingSupport 18.1.1 - from the file “ScriptingSupport”
                           Shake Reduction 18.1.1 - from the file “Shake Reduction”
                           Shear 18.1.1 - from the file “Standard MultiPlugin”
                           Skewness 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
                           Smart Blur 18.1.1 - from the file “Standard MultiPlugin”
                           Smudge Stick 18.1.1 - from the file “Filter Gallery”
                           Solarize 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Solarize”
                           Spaces 18.1.1 - from the file “Spaces”
                           Spatter 18.1.1 - from the file “Filter Gallery”
                           Spherize 18.1.1 - from the file “Standard MultiPlugin”
                           Sponge 18.1.1 - from the file “Filter Gallery”
                           Sprayed Strokes 18.1.1 - from the file “Filter Gallery”
                           Stained Glass 18.1.1 - from the file “Filter Gallery”
                           Stamp 18.1.1 - from the file “Filter Gallery”
                           Standard Deviation 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
                           STL 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
                           Sumi-e 18.1.1 - from the file “Filter Gallery”
                           Summation 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
                           Targa 18.1.1 - from the file “Standard MultiPlugin”
                           Texturizer 18.1.1 - from the file “Filter Gallery”
                           Tiles 18.1.1 - from the file “Standard MultiPlugin”
                           Torn Edges 18.1.1 - from the file “Filter Gallery”
                           Twirl 18.1.1 - from the file “Standard MultiPlugin”
                           U3D 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
                           Underpainting 18.1.1 - from the file “Filter Gallery”
                           Vanishing Point 18.1.1 - from the file “VanishingPoint”
                           Variance 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics”
                           Virtual Reality Modeling Language | VRML 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
                           Water Paper 18.1.1 - from the file “Filter Gallery”
                           Watercolor 18.1.1 - from the file “Filter Gallery”
                           Wave 18.1.1 - from the file “Standard MultiPlugin”
                           Wavefront|OBJ 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D”
                           WIA Support 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “WIASupport”
                           Wind 18.1.1 - from the file “Standard MultiPlugin”
                           Wireless Bitmap 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “WBMP”
                           ZigZag 18.1.1 - from the file “Standard MultiPlugin”
                        Optional and third party plug-ins: NONE
                        Extensions:
                           Recent Files  1.4.2 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_1_4_2_009\index.html”
                           com.adobe.inapp.purchase  2.10.56 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_10_56\purchase.html”
                           New Document  1.4.2 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_1_4_2_009\fnft.html”
                           Libraries  2.10.56 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_10_56\index.html”
                           Start  1.4.2 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_1_4_2_009\index.html”
                           com.adobe.experimentation.extension  2.0.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.experimentation.extension\index.html”
                           Adobe Color Themes  6.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.KulerPanel.html\index.html”
                           Export As  3.0.8 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.photoshop.crema\PSPanel\dialog.html”
                           Device Preview  1.3.2 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\com.adobe.previewHD\PSPanel\panel.html”
                           com.adobe.preview.loader  1.3.2 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\com.adobe.previewHD\PSLoader\loader.html”
                        • 10. Re: Photoshop Speed issue
                          Thank you for posting the information.  I have looked through it  and am sorry you report I see nothing in it the strike me as a red flag.  You are not loading any third party plugins and I see no error messages.  In mint I see I set tile size and number of caches higher however your default Adobe settings should no cause and problems.
                          I use Windows 10 Preview and You use windows 8.  Windows 10 preview has its own issues the last one would not even install on my workstation.
                          You gave a great Gaming Nvidia GTX 1080 and a very recent driver.  You may wan to try  some of Nvidia's older drivers maybe so new bleeding edge update is giving Photoshop some problems. But I know of no issues with Nvifia's drivers.  Trying older drivers is just a shoot in the dark,   I see no problems with information.
                          The only thing I see that may be a problem is it look like you only have your C: SDD  as Photoshop scratch space and it has 100GB free.  CC 2017 could easily fill that and you system performance will go to pot windows needs free space on C: tho run well.   CC 2017 also has a known that fill scratch space.   Does Photoshop start OK then everything slow down?   Try changing Photoshops Preferences.  Remove C: from scratch space and make your 2TB drive Photoshop scratch drive.  Stop and start Photoshop than.
                          Are you having and other problems with other applications?x
                          • 11. Re: Photoshop Speed issue
                            adamel891
                            I am having a similar problem since the most recent update. Photoshop has become virtually unusable, even the most basic functions cause the program to lag and on occasion crash. Anything from trying to place/scale an object, to zooming in/out, to re positioning layers to editing text, I haven't even dared to try working with 3D layers through fear of my throwing my laptop out the window. These issues did not occur anywhere near as much previous to the most recent update. As helpful as these forums are, the fact there is no dedicated go to location to deal directly with the support team is unacceptable and a major cop out on Adobe's front. I am however, extremely grateful for the contributions of the users to these forums.
                            Windows 10 i7-4720HQ processor
                            16GB RAM
                            1TB HDD
                            AMD Radeon R9 GPU
                            • 12. Re: Photoshop Speed issue
                              I appreciate the help.  I am experiencing no issues with any other applications, I attempted changing the scratch disks, made the other drive the main, and even tried to activate both hard drives, no improvement was shown.  Its difficult to explain, from my experience the program is acting as if my hardware is just not up to par,  every action takes much longer then it should.  I can easily compare this computer ( work computer ) with my at home computer that runs Photoshop with no issues.  So, i know what its suppose to be running like, and something is not right.  It may be worth it to make a video, were I record the screen and compare both, response times, etc.
                              • 13. Re: Photoshop Speed issue
                                I do not think a video will help any we would just see what you see poor performance.  I do not think we would see what is the cause any more the you see the cause in a 3d World with touch, feel, sight and sound..
                                When all attempts fail  uninstall Photoshop delete preference files on the system. Download and use Adobe clear. Then have Photoshop re-install at work.
                                Use the Creative Cloud Cleaner Tool to solve installation problems
