2 Replies Latest reply on Jun 2, 2017 9:25 AM by pixxxel schubser
    Only open psd
    showshow Level 1
      Hello,
      How can i, when i use the script beyond, only opens ".psd files" ?
      Thanks a lot
      / Pops open a dialog for the user to
      // choose the folder of documents to process
      var inputFolder = Folder.selectDialog("Select a folder of documents to process");
      // Pops open a dialog for the user to
      // set the output folder
      // Open Folder of Images
      OpenFolder();
      // show the path to an output folder
      // FUNCTIONS
      // Given the a Folder of files, open them
      function OpenFolder() {
              var filesOpened = 0;
              var fileList = inputFolder.getFiles();
              for ( var i = 0; i < fileList.length; i++ ) {
                // Make sure all the files in the folder are compatible with PS
                      if ( fileList[i] instanceof File && ! fileList[i].hidden && ! IsFileOneOfThese( fileList[i], gFilesToSkip )) {
                              open( fileList[i] );
                              filesOpened++;
        // Put all your processing functions...
        // ...in the area between these two comments.
              return filesOpened;
      // given a file name and a list of extensions
      // determine if this file is in the list of extensions
      function IsFileOneOfThese( inFileName, inArrayOfFileExtensions ) {
        var lastDot = inFileName.toString().lastIndexOf( "." );
        if ( lastDot == -1 ) {
        return false;
        var strLength = inFileName.toString().length;
        var extension = inFileName.toString().substr( lastDot + 1, strLength - lastDot );
        extension = extension.toLowerCase();
        for (var i = 0; i < inArrayOfFileExtensions.length; i++ ) {
        if ( extension == inArrayOfFileExtensions[i] ) {
        return true;
        return false;
        • 1. Re: Only open psd
          Joachim Hiller Level 1
          You can try i
          File.prototype.fileExt = function () {
             return this.name.replace(/^.*\./, '');
          var inputFolder = Folder.selectDialog("Please select the input folder");
          if (inputFolder != null) {
             for (var a in fileList) {
             if (fileList[a] instanceof File) {
             //check fileextension(,psd...)
             var fileExtension = fileList[a].fileExt();
             //only psd
             if (fileExtension === "psd") {
             //open Image
             open(fileList[a]);
          • 2. Re: Only open psd
            pixxxel schubser MVP & Adobe Community Professional
            Hi showshow,
            you can simple use a "file mask"
            var SourceFolder = new Folder('~/desktop/Testdateien'); // use the folder with your psd-files
            sourcePics = SourceFolder.getFiles(/\.psd$/i);
            alert(sourcePics.join("\n"));
            Have fun
