0 Replies Latest reply on Jun 2, 2017 2:16 AM by Ibarim
    change skin on all instances of mx.Button with static var
    Ibarim Level 1
      I created class extending Button in mxml and this class has skin set to some flash picture from .swc.
      I would like to give users option to change look of the button. To do that I need to change skin of all instances of this button. I figured out that I'll create static function to change skin style. But of course it doesn't work
      In creationComplete event handler I attach the 'this' property to static var 'thisstatic'. Then when user changes option static functions are called inside my button class: test() and test2(). These functions should change skin by calling the 'thisstatic' var.  I tried setStyle, StyleManager and CSS styles, and nothing happens.
      I'm not sure if I made something wrong with the static/dynamic connection or changing skin dynamically is even possible, coz as far as I read forums it might not be possible at all.
      Example of my button class: (ButtonSkin is default mx button skin and btn_skin is my skin from .swc picture)
      <mx:Button xmlns:fx="http://ns.adobe.com/mxml/2009"
        xmlns:mx="library://ns.adobe.com/flex/mx"
        skin="{btn_skin}" creationComplete="cc()">
      <fx:Script>
        <![CDATA[
      private function cc():void {
            thisstatic = this;
      private static var thisstatic:Button;
      public static function test():void {
             trace('Btn.test()');
      //each solution from below doesn't work
             //thisstatic.setStyle('skin',ButtonSkin);
             //fl.managers.StyleManager.setStyle('skin',ButtonSkin);
             //fl.managers.StyleManager.setComponentStyle(thisstatic,'skin',ButtonSkin);
             //thisstatic.styleName = 'noskinstyle';
        public static function test2():void {
             trace('Btn.test2()');
             //thisstatic.setStyle('skin',btn_skin);
             //fl.managers.StyleManager.setStyle('skin',btn_skin);
             //fl.managers.StyleManager.setComponentStyle(thisstatic,'skin',btn_skin);
             //thisstatic.styleName = 'skinstyle';
        </fx:Script>
      <fx:Style>
        @namespace s "library://ns.adobe.com/flex/spark";
        @namespace mx "library://ns.adobe.com/flex/mx";
        .noskinstyle {
        skin: null;
        .skinstyle {
        skin: btn_skin;
        </fx:Style>
      </mx:Button>
