2 Replies Latest reply on Jun 2, 2017 6:39 AM by LeeBow
    Give Adobe Animate more Memory / Hardware Acceleration?
    LeeBow Level 1
      I've just got a new computer - its got a AMD Radeon R9 M485X -- which is miles better then the graphics card in my old laptop I used to work on.
      But adobe animate is running terrible - I click a movie clip on stage - and press the up arrow - and it doesn't move up, it "jumps" to the location when I let go of the button.
      I drag to resize text - and I don't see the font getting bigger/smaller -- it just appears at the size when I stop dragging.
      It's like my new pc is worse then my old one :-(
      Is there any way to give animate more memory to use -- or tell it to use more of the graphics card, or hardware acceleration? (Like you can in Photoshop)
      Thanks for any help!
        • 1. Re: Give Adobe Animate more Memory / Hardware Acceleration?
          reset your preferences by removing
          C:\Users\<username>\AppData\Local\Adobe\Animate CC 2017\ and
          /Users/<username>/Library/Application Support/Adobe/Animate CC 2017/ and
          and you can increase the virtual memory allocation used by animate by editing your jvm.ini file but that's not needed unless testing or publishing were a problem.
          2 people found this helpful
          • 2. Re: Give Adobe Animate more Memory / Hardware Acceleration?
            LeeBow Level 1
            Thanks Kglad - I've tried that - no luck :-(
            I've never known animate run so bad -- if I draw a freehand shape with the brush tool -- it first displays it as a bitmap looking shape, then takes "seconds" to redraw it as a vector shape. It's usually instant -- but seconds is very annoying when you are used to instantaneous.
            Especially when this is a new computers - and I never had any problems on my old laptop :-(
            If anyone has any other ideas on how to increase the memory usage, or cpu, or graphics usage of animation - it would be really appreciated!
            Thank you! :-)
