4 Replies Latest reply on Jun 2, 2017 9:32 AM by Günter Heißenbüttel
    Menu Appearance (Part 2)
    MstrPBK2010 Level 1
      Hoping someone understands the design dilemma.  Is there some way to control the appearance of an independent menu listing?  (i.e. Background color, Text background, Text formatting)
      This is a case where keeping all the elements on one menu will be more helpful to the reader.  In my case I'll be talking/writing about plants.  Some plants I have, others I have had in the past, still others are so unique that they are ONLY in my garden ... simply by the way they grow!  The reader will know what plant(s) they are looking for, but may not know the history of the plant in my garden.
        • 1. Re: Menu Appearance (Part 2)
          Ussnorway Adobe Community Professional
          what is this menu made from... i.e, is it a widget you got from a shop or maybe code someone made for you?
          • 2. Re: Menu Appearance (Part 2)
            Günter Heißenbüttel Adobe Community Professional
            But you can do, what you described in your third example!
            • Go to the menu configuration (small blue triangle to the right of the menu) and switch off "Edit Together".
            • Click onto a menu entry so often, until in the upper left corner of the application window appears "Menu Item".
            • Now, use the "States" panel to switch between the single menu states (normal, rollover, mouse down, active) in every state you can change the color, the font, the text background or whatever you like.
            Just look at this super ugly example, made with Muse’s standard menu:
            • 3. Re: Menu Appearance (Part 2)
              MstrPBK2010 Level 1
              • 4. Re: Menu Appearance (Part 2)
                Click onto the menu, until it is activated. Then click again and again.
                You'll see, that the label, shown in the top left corner of the application window changes from "Menu" to "Submenu" to "Menu Item" ( and further to "Menu Label", if you click once more).
                If the "menu item" is selected, you can change its attributes state-wise.
