8 Replies Latest reply on Jun 8, 2017 12:14 PM by bf15555616
    Refine Edge Tool Not Working At All
    bf15555616 Level 1
      This has been happening for a few days now. When I try to refine a mask or a selection no changes are made. I'll brush part of the mask using the refine edge tool and it will act as if it's loading something, but then nothing happens. I'm running Photoshop CC 2017.
      15.6" FHD IPS Matte Screen
      Intel® Kabylake i7-7700HQ
      NVIDIA® GeForce® GTX 1050 Ti [4GB] w/Optimus™ Technology
      8GB RAM
      1TB Hard Drive
      Windows 10 64-BIT
      I'm updating my graphics card as I type this and I updated Windows as well. I'd really appreciate any help with this. Thank you!
        • 1. Re: Refine Edge Tool Not Working At All
          Have you tried resetting all tools and if the does not fix your problem try resetting your Photoshop preferences if it use to work correctly
          • 2. Re: Refine Edge Tool Not Working At All
            bf15555616 Level 1
            Thank you for your reply!
            I did both of those things and it worked once, but then continued to fail. I made a selection and used the tool after each reset and it worked. Then I deselcted and tried to edit the mask, but the edge tool didn't work again. The old refine edge tool seems to work fine though.
            • 3. Re: Refine Edge Tool Not Working At All
              Try resetting the again.  It it works again. Something must be corrupting your Preferences.  If you have any third party extensions and plugins installed try removing them and reset your preferences and see if your Preferences remain good.
              • 4. Re: Refine Edge Tool Not Working At All
                bf15555616 Level 1
                Thank you so much for your help again.
                I'm unsure of what you mean when you refer to extensions and plugins. As far as I know, I don't have any. Unless you mean brushes, actions, patterns, gradients, or shapes. I do have those. Are they considered plugins or extensions? I apologize for my ignorance.
                • 5. Re: Refine Edge Tool Not Working At All
                  Use Photoshop menu Help>system Info copy and paste info here....
                  • 6. Re: Refine Edge Tool Not Working At All
                    bf15555616 Level 1
                    Adobe Photoshop Version: 2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877  x64
                    Number of Launches: 2
                    Version: 10 or greater
                    System architecture: Intel CPU Family:6, Model:14, Stepping:9 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2, HyperThreading
                    Physical processor count: 4
                    Logical processor count: 8
                    Processor speed: 2808 MHz
                    Built-in memory: 8047 MB
                    Free memory: 2 MB
                    Memory available to Photoshop: 6873 MB
                    Memory used by Photoshop: 70 %
                    History Thumbnails: Enabled.
                    Touch Bar: Enabled.
                    Alias Layers: Disabled.
                    Modifier Palette: Enabled.
                    Highbeam: Disabled.
                    Image tile size: 1024K
                    Image cache levels: 4
                    Font Preview: Medium
                    TextComposer: Latin
                    Display: 1
                    Display Bounds: top=0, left=0, bottom=1080, right=1920
                    OpenGL Drawing: Enabled.
                    OpenGL Allow Old GPUs: Not Detected.
                    OpenGL Drawing Mode: Advanced
                    OpenGL Allow Normal Mode: True.
                    OpenGL Allow Advanced Mode: True.
                    AIFCoreInitialized=1
                    AIFOGLInitialized=1
                    OGLContextCreated=1
                    NumGLGPUs=1
                    NumCLGPUs=2
                    NumNativeGPUs=0
                    glgpu[0].GLVersion="4.1"
                    glgpu[0].IsIntegratedGLGPU=0
                    glgpu[0].GLMemoryMB=4096
                    glgpu[0].GLName="NVIDIA GeForce GTX 1050 Ti"
                    glgpu[0].GLVendor="NVIDIA Corporation"
                    glgpu[0].GLVendorID=4318
                    glgpu[0].GLDriverVersion="22.21.13.8233"
                    glgpu[0].GLRectTextureSize=32768
                    glgpu[0].GLRenderer="GeForce GTX 1050 Ti/PCIe/SSE2"
                    glgpu[0].GLRendererID=7308
                    glgpu[0].HasGLNPOTSupport=1
                    glgpu[0].GLDriver="C:\WINDOWS\System32\DriverStore\FileRepository\nvcvi.inf_amd64_5a93b359 bc8bcc04\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nvcvi.inf_amd64_5a93b 359bc8bcc04\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nvcvi.inf_amd64_5a 93b359bc8bcc04\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nvcvi.inf_amd64 _5a93b359bc8bcc04\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nvcvi.inf_am d64_5a93b359bc8bcc04\nvldumd.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nvcvi.inf_ amd64_5a93b359bc8bcc04\nvldumd.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nvcvi.in f_amd64_5a93b359bc8bcc04\nvldumd.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nvcvi. inf_amd64_5a93b359bc8bcc04\nvldumd.dll"
                    glgpu[0].GLDriverDate="20170517000000.000000-000"
                    glgpu[0].CanCompileProgramGLSL=1
                    glgpu[0].GLFrameBufferOK=1
                    glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.50 NVIDIA"
                    glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[6553 6]
                    glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
                    glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
                    glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
                    glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
                    glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
                    glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
                    glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
                    glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
                    glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
                    glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
                    glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
                    glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
                    glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
                    glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
                    glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
                    glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
                    glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
                    glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
                    glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
                    clgpu[0].CLPlatformVersion="2.1 "
                    clgpu[0].CLDeviceVersion="2.1 "
                    clgpu[0].IsIntegratedCLGPU=1
                    clgpu[0].CLMemoryMB=3210
                    clgpu[0].CLName="Intel(R) HD Graphics 630"
                    clgpu[0].CLVendor="Intel(R) Corporation"
                    clgpu[0].CLVendorID=32902
                    clgpu[0].CLDriverVersion="21.20.16.4541"
                    clgpu[0].CLBandwidth=9.25118e+09
                    clgpu[0].CLCompute=33.8921
                    clgpu[1].CLPlatformVersion="1.2"
                    clgpu[1].CLDeviceVersion="1.2 CUDA"
                    clgpu[1].IsIntegratedCLGPU=0
                    clgpu[1].CLMemoryMB=4096
                    clgpu[1].CLName="GeForce GTX 1050 Ti"
                    clgpu[1].CLVendor="NVIDIA Corporation"
                    clgpu[1].CLVendorID=4318
                    clgpu[1].CLDriverVersion="382.33"
                    clgpu[1].CLBandwidth=6.89512e+10
                    clgpu[1].CLCompute=1106.59
                    License Type: Perpetual
                    Serial number: 91198701560031595861
                    GUIDBucket:
                      bucket: undefined
                      test: undefined
                    Application folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\
                    Temporary file path: C:\Users\brian\AppData\Local\Temp\
                    Photoshop scratch has async I/O enabled
                    Scratch volume(s):
                      Startup, 930.8G, 790.7G free
                    Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\Plug-ins\
                    Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\
                    Installed components:
                       A3DLIBS.dll   A3DLIB Dynamic Link Library   9.2.0.112
                       ACE.dll   ACE 2017/01/26-01:10:02   79.579975   79.579975
                       AdbePM.dll   PatchMatch 2016/11/03:19:48:57   1.578146   1.578146
                       AdobeLinguistic.dll   Adobe Linguisitc Library   10.0.0
                       AdobeOwl.dll   Adobe Owl   5.2.11
                       AdobePDFL.dll   PDFL 2016/08/10-16:53:20   79.195992   79.195992
                       AdobePIP.dll   Adobe Product Improvement Program   7.4.1.60.45263
                       AdobeSVGAGM.dll   AdobeSVGAGM   79.579975   79.579975
                       AdobeXMP.dll   Adobe XMP Core 2016/09/14-01:09:01   79.159824   79.159824
                       AdobeXMPFiles.dll   Adobe XMP Files 2016/09/14-01:09:01   79.159824   79.159824
                       AdobeXMPScript.dll   Adobe XMP Script 2016/09/14-01:09:01   79.159824   79.159824
                       adobe_caps.dll   Adobe CAPS   10,0,0,6
                       AGM.dll   AGM 2017/01/26-01:10:02   79.579975   79.579975
                       ahclient.dll    AdobeHelp Dynamic Link Library   2.2.0.1
                       AIDE.dll   AIDE 2016/05/27-01:08:49   79.574279   79.574279
                       amtlib.dll   AMTLib (64 Bit)   10.0.0.119 BuildVersion: 10.0; BuildDate: Thu Dec 22 2016 3:0:7)   1.000000
                       ARE.dll   ARE 2017/01/26-01:10:02   79.579975   79.579975
                       AXE8SharedExpat.dll   AXE8SharedExpat 2015/03/13-23:40:54   79.562390   79.562390
                       AXEDOMCore.dll   AXEDOMCore 2015/03/13-23:40:54   79.562390   79.562390
                       Bib.dll   BIB 2017/01/26-01:10:02   79.579975   79.579975
                       BIBUtils.dll   BIBUtils 2017/01/26-01:10:02   79.579975   79.579975
                       boost_date_time.dll   photoshopdva   10.0.0
                       boost_signals.dll   photoshopdva   10.0.0
                       boost_system.dll   photoshopdva   10.0.0
                       boost_threads.dll   photoshopdva   10.0.0
                       cg.dll   NVIDIA Cg Runtime   3.0.00007
                       cgGL.dll   NVIDIA Cg Runtime   3.0.00007
                       CITThreading.dll   Adobe CITThreading   2.1.0.1   2.1.0.1
                       CoolType.dll   CoolType 2017/01/26-01:10:02   79.579975   79.579975
                       dnssd.dll   Bonjour   3,0,0,2
                       dvaaudiodevice.dll   photoshopdva   10.0.0
                       dvacore.dll   photoshopdva   10.0.0
                       dvacrashhandler.dll   Adobe Audition CC 2017   10.0.0
                       dvamarshal.dll   photoshopdva   10.0.0
                       dvamediatypes.dll   photoshopdva   10.0.0
                       dvametadata.dll   photoshopdva   10.0.0
                       dvametadataapi.dll   photoshopdva   10.0.0
                       dvametadataui.dll   photoshopdva   10.0.0
                       dvaplayer.dll   photoshopdva   10.0.0
                       dvatransport.dll   photoshopdva   10.0.0
                       dvaui.dll   photoshopdva   10.0.0
                       dvaunittesting.dll   photoshopdva   10.0.0
                       dynamiclink.dll   photoshopdva   10.0.0
                       ExtendScript.dll   ExtendScript 2016/12/13-13:10:33   80.1089815   80.1089815
                       icucnv40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
                       icudt40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
                       icuuc40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
                       igestep30.dll   IGES Reader   9.3.0.113
                       imslib.dll   IMSLib DLL   10.0.0.11
                       JP2KLib.dll   JP2KLib 2016/05/26-01:08:58   79.262945   79.262945
                       libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
                       libiomp5md.dll   Intel(R) OpenMP* Runtime Library   5.0
                       libmmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
                       LogSession.dll   LogSession   7.4.1.60.45263
                       mediacoreif.dll   photoshopdva   10.0.0
                       MPS.dll   MPS 2016/09/14-15:20:26   79.577269   79.577269
                       pdfsettings.dll   Adobe PDFSettings   1.04
                       Photoshop.dll   Adobe Photoshop CC 2017   18.1.0
                       Plugin.dll   Adobe Photoshop CC 2017   18.1.0
                       PlugPlugExternalObject.dll   Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit)   7.0.0
                       PlugPlugOwl.dll   Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit)   7.0.0.67
                       PSArt.dll   Adobe Photoshop CC 2017   18.1.0
                       PSViews.dll   Adobe Photoshop CC 2017   18.1.0
                       SCCore.dll   ScCore 2016/12/13-13:10:33   80.1089815   80.1089815
                       SVGRE.dll   SVGRE   79.579975   79.579975
                       svml_dispmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
                       tbb.dll   Intel(R) Threading Building Blocks for Windows   4, 4, 2016, 0412
                       tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   4, 4, 2016, 0412
                       TfFontMgr.dll   FontMgr   9.3.0.113
                       TfKernel.dll   Kernel   9.3.0.113
                       TFKGEOM.dll   Kernel Geom   9.3.0.113
                       TFUGEOM.dll   Adobe, UGeom©   9.3.0.113
                       updaternotifications.dll   Adobe Updater Notifications Library   10.0.0.1 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   10.0.0.1
                       VulcanControl.dll   Vulcan Application Control Library   5.3.0.16
                       VulcanMessage5.dll   Vulcan Message Library   5.3.0.16
                       WRServices.dll   WRServices Thu Jan 07 2016 04:50:10   Build 0.21960   0.21960
                       wu3d.dll   U3D Writer   9.3.0.113
                    Required plug-ins:
                       3D Studio 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D”
                       Accented Edges 18.1.0 - from the file “Filter Gallery”
                       Adaptive Wide Angle 18.1.0 - from the file “Adaptive Wide Angle”
                       Angled Strokes 18.1.0 - from the file “Filter Gallery”
                       Average 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “Average”
                       Bas Relief 18.1.0 - from the file “Filter Gallery”
                       BMP 18.1.0 - from the file “Standard MultiPlugin”
                       Camera Raw 9.9 - from the file “Camera Raw”
                       Camera Raw Filter 9.9 - from the file “Camera Raw”
                       Chalk && Charcoal 18.1.0 - from the file “Filter Gallery”
                       Chrome 18.1.0 - from the file “Filter Gallery”
                       Cineon 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “Cineon”
                       Clouds 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “Clouds”
                       Collada 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D”
                       Color Halftone 18.1.0 - from the file “Standard MultiPlugin”
                       Colored Pencil 18.1.0 - from the file “Filter Gallery”
                       CompuServe GIF 18.1.0 - from the file “Standard MultiPlugin”
                       Conté Crayon 18.1.0 - from the file “Filter Gallery”
                       Craquelure 18.1.0 - from the file “Filter Gallery”
                       Crop and Straighten Photos 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “CropPhotosAuto”
                       Crop and Straighten Photos Filter 18.1.0 - from the file “Standard MultiPlugin”
                       Crosshatch 18.1.0 - from the file “Filter Gallery”
                       Crystallize 18.1.0 - from the file “Standard MultiPlugin”
                       Cutout 18.1.0 - from the file “Filter Gallery”
                       Dark Strokes 18.1.0 - from the file “Filter Gallery”
                       De-Interlace 18.1.0 - from the file “Standard MultiPlugin”
                       Dicom 18.1.0 - from the file “Dicom”
                       Difference Clouds 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “Clouds”
                       Diffuse Glow 18.1.0 - from the file “Filter Gallery”
                       Displace 18.1.0 - from the file “Standard MultiPlugin”
                       Dry Brush 18.1.0 - from the file “Filter Gallery”
                       Eazel Acquire 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “EazelAcquire”
                       Entropy 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics”
                       Export Color Lookup Tables 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “Export3DLUT”
                       Extrude 18.1.0 - from the file “Standard MultiPlugin”
                       FastCore Routines 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “FastCore”
                       Fibers 18.1.0 - from the file “Standard MultiPlugin”
                       Film Grain 18.1.0 - from the file “Filter Gallery”
                       Filter Gallery 18.1.0 - from the file “Filter Gallery”
                       Flash 3D 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D”
                       Fresco 18.1.0 - from the file “Filter Gallery”
                       Glass 18.1.0 - from the file “Filter Gallery”
                       Glowing Edges 18.1.0 - from the file “Filter Gallery”
                       Google Earth 4 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D”
                       Graphic Pen 18.1.0 - from the file “Filter Gallery”
                       Halftone Pattern 18.1.0 - from the file “Filter Gallery”
                       HDRMergeUI 18.1.0 - from the file “HDRMergeUI”
                       HSB/HSL 18.1.0 - from the file “Standard MultiPlugin”
                       IFF Format 18.1.0 - from the file “Standard MultiPlugin”
                       IGES 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D”
                       Ink Outlines 18.1.0 - from the file “Filter Gallery”
                       JPEG 2000 18.1.0 - from the file “JPEG2000”
                       Kurtosis 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics”
                       Lens Blur 18.1.0 - from the file “Lens Blur”
                       Lens Correction 18.1.0 - from the file “Lens Correction”
                       Lens Flare 18.1.0 - from the file “Standard MultiPlugin”
                       Liquify 18.1.0 - from the file “Liquify”
                       Matlab Operation 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “ChannelPort”
                       Maximum 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics”
                       Mean 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics”
                       Measurement Core 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “MeasurementCore.8me”
                       Median 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics”
                       Mezzotint 18.1.0 - from the file “Standard MultiPlugin”
                       Minimum 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics”
                       MMXCore Routines 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “MMXCore”
                       Mosaic Tiles 18.1.0 - from the file “Filter Gallery”
                       Multiprocessor Support 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “MultiProcessor Support”
                       Neon Glow 18.1.0 - from the file “Filter Gallery”
                       Note Paper 18.1.0 - from the file “Filter Gallery”
                       NTSC Colors 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “NTSC Colors”
                       Ocean Ripple 18.1.0 - from the file “Filter Gallery”
                       OpenEXR 18.1.0 - from the file “Standard MultiPlugin”
                       Paint Daubs 18.1.0 - from the file “Filter Gallery”
                       Palette Knife 18.1.0 - from the file “Filter Gallery”
                       Patchwork 18.1.0 - from the file “Filter Gallery”
                       Paths to Illustrator 18.1.0 - from the file “Standard MultiPlugin”
                       PCX 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “PCX”
                       Photocopy 18.1.0 - from the file “Filter Gallery”
                       Photoshop 3D Engine 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “Photoshop3DEngine”
                       Photoshop Touch 14.0 - from the file “PSDX”
                       Picture Package Filter 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “ChannelPort”
                       Pinch 18.1.0 - from the file “Standard MultiPlugin”
                       Pixar 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “Pixar”
                       Plaster 18.1.0 - from the file “Filter Gallery”
                       Plastic Wrap 18.1.0 - from the file “Filter Gallery”
                       PLY 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D”
                       PNG 18.1.0 - from the file “Standard MultiPlugin”
                       Pointillize 18.1.0 - from the file “Standard MultiPlugin”
                       Polar Coordinates 18.1.0 - from the file “Standard MultiPlugin”
                       Portable Bit Map 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “PBM”
                       Poster Edges 18.1.0 - from the file “Filter Gallery”
                       PRC 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D”
                       Radial Blur 18.1.0 - from the file “Standard MultiPlugin”
                       Radiance 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “Radiance”
                       Range 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics”
                       Render Color Lookup Grid 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “Export3DLUT”
                       Reticulation 18.1.0 - from the file “Filter Gallery”
                       Ripple 18.1.0 - from the file “Standard MultiPlugin”
                       Rough Pastels 18.1.0 - from the file “Filter Gallery”
                       Save for Web 18.1.0 - from the file “Save for Web”
                       ScriptingSupport 18.1.0 - from the file “ScriptingSupport”
                       Shake Reduction 18.1.0 - from the file “Shake Reduction”
                       Shear 18.1.0 - from the file “Standard MultiPlugin”
                       Skewness 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics”
                       Smart Blur 18.1.0 - from the file “Standard MultiPlugin”
                       Smudge Stick 18.1.0 - from the file “Filter Gallery”
                       Solarize 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “Solarize”
                       Spaces 18.1.0 - from the file “Spaces”
                       Spatter 18.1.0 - from the file “Filter Gallery”
                       Spherize 18.1.0 - from the file “Standard MultiPlugin”
                       Sponge 18.1.0 - from the file “Filter Gallery”
                       Sprayed Strokes 18.1.0 - from the file “Filter Gallery”
                       Stained Glass 18.1.0 - from the file “Filter Gallery”
                       Stamp 18.1.0 - from the file “Filter Gallery”
                       Standard Deviation 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics”
                       STL 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D”
                       Sumi-e 18.1.0 - from the file “Filter Gallery”
                       Summation 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics”
                       Targa 18.1.0 - from the file “Standard MultiPlugin”
                       Texturizer 18.1.0 - from the file “Filter Gallery”
                       Tiles 18.1.0 - from the file “Standard MultiPlugin”
                       Torn Edges 18.1.0 - from the file “Filter Gallery”
                       Twirl 18.1.0 - from the file “Standard MultiPlugin”
                       U3D 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D”
                       Underpainting 18.1.0 - from the file “Filter Gallery”
                       Vanishing Point 18.1.0 - from the file “VanishingPoint”
                       Variance 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “statistics”
                       Virtual Reality Modeling Language | VRML 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D”
                       Water Paper 18.1.0 - from the file “Filter Gallery”
                       Watercolor 18.1.0 - from the file “Filter Gallery”
                       Wave 18.1.0 - from the file “Standard MultiPlugin”
                       Wavefront|OBJ 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “U3D”
                       WIA Support 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “WIASupport”
                       Wind 18.1.0 - from the file “Standard MultiPlugin”
                       Wireless Bitmap 18.1.0 (2017.1.0 20170309.r.207 2017/03/09:23:00:00 CL 1107877) - from the file “WBMP”
                       ZigZag 18.1.0 - from the file “Standard MultiPlugin”
                    Optional and third party plug-ins: NONE
                    Duplicate and Disabled plug-ins: NONE
                    Plug-ins that failed to load: NONE
                    Extensions: NONE
                    Installed TWAIN devices: NONE
                    • 7. Re: Refine Edge Tool Not Working At All
                      I do not know if the CC 2017.1.1 update will fix the problem you write you have but you are missing that update that fixes some if the Issues in CC 2017.1.0 the version you have.  Your configuration look OK to me though I would think the feature should work.
                      • 8. Re: Refine Edge Tool Not Working At All
                        bf15555616 Level 1
                        I'm scared to ask, but could it be my computer?
