1 Reply Latest reply on Nov 29, 2017 10:20 AM by ed74609181
    Certificate for Windows
    danielb56741896
      I'm trying to create a certificate, but the instructions that are linked to aren't helpful at all.
      Can I please, please just get some simple instructions on how to create a certificate and the password you need?
      The current set of instructions just links to a page that begins with the sentence "Important  MakeCert.exe is deprecated.", and is really not helpful at all.
      It makes me file like having been given an English dictionary when all I want is a simple recepie.
      For example, it mentions an "AppxManifest.xml" file. Is that something that is created by phonegap, or do I need to include it?
      The link on that page says to use To manually create it says Create an app package with the MakeAppx.exe tool
      but that process won't create an .appxupload file, whatever that is.  Do I need one?
      Will I need to download the Windows 10 SDK?
      Do I need Visual Studio?
      Do I need to create an .appx file?
      Do I need to create an .appxsym file?
      Do I need to create a .pdb file?
      Do I need to create a x86 version or a x64 version?
      What exactly do I need to do with the MakeAppx? Pack, bundle or Encrypt?
      Where do I type the "MakeAppx <command> [options]" line?
      Which of the following options do I need to use?
      OptionDescription
      /dSpecifies the input, output, or content directory.
      /lUsed for localized packages. The default validation trips on localized packages. This options disables only that specific validation, without requiring that all validation be disabled.
      /kfEncrypts or decrypts the package or bundle using the key from the specified key file. This can't be used with /kt.
      /ktEncrypts the or decrypts package or bundle using the global test key. This can't be used with /kf.
      /noPrevents an overwrite of the output file if it exists. If you don't specify this option or the /o option, the user is asked whether they want to overwrite the file.
      /nvSkips semantic validation. If you don't specify this option, the tool performs a full validation of the package.
      /oOverwrites the output file if it exists. If you don't specify this option or the /no option, the user is asked whether they want to overwrite the file.
      /pSpecifies the app package or bundle.
      /vEnables verbose logging output to the console.
      /?Displays help text.
      Do I need a keyfile?
      Do I need a global test key?
      It says It requires PKI cmdlets, and lists them, which one do I need?
      PKIClient Cmdlets
      Add-CertificateEnrollmentPolicyServer
      Adds an enrollment policy server to the current user or local system configuration.
      Export-Certificate
      Exports a certificate from a certificate store into a file.
      Export-PfxCertificate
      Exports a certificate or a PFXData object to a Personal Information Exchange (PFX) file.
      Get-Certificate
      Submits a certificate request to an enrollment server and installs the response or retrieves a certificate for a previously submitted request.
      Get-CertificateAutoEnrollmentPolicy
      Retrieves certificate auto-enrollment policy settings.
      Get-CertificateEnrollmentPolicyServer
      Returns all of the certificate enrollment policy server URL configurations.
      Get-CertificateNotificationTask
      Returns all registered certificate notification tasks.
      Get-PfxData
      Extracts the content of a Personal Information Exchange (PFX) file into a structure without importing it to certificate store.
      Import-Certificate
      Imports one or more certificates into a certificate store.
      Import-PfxCertificate
      Imports certificates and private keys from a Personal Information Exchange (PFX) file to the destination store.
      New-CertificateNotificationTask
      Creates a new task in the Task Scheduler that will be triggered when a certificate is replaced, expired, or about to expired.
      New-SelfSignedCertificate
      Creates a new self-signed certificate for testing purposes.
      Remove-CertificateEnrollmentPolicyServer
      Removes an enrollment policy server and the URL of the enrollment policy server from the current user or local computer configuration.
      Remove-CertificateNotificationTask
      Removes a certificate notification task from Task Scheduler.
      Set-CertificateAutoEnrollmentPolicy
      Sets local certificate auto-enrollment policy.
      Switch-Certificate
      Marks one certificate as having been replaced by another certificate.
      Test-Certificate
      Verifies a certificate according to the input parameters.
      Do I need to use the sign tool?
      What is the hash algorithm used in SignTool? I have no clue as to how to get ahold of the AppxBlockMap.xml to check it myself
      Where do I write the following command structure?
      SignTool sign [options] <filename(s)>
      etc, etc, etc, etc, etc.
      Can I PLEASE get some simple instructions on creating the certificate needed for the windows version?
      I really want to try phonegap build, please just tell me how.
