0 Replies Latest reply on Jun 3, 2017 2:49 AM by godilo
    I retrieved and displayed all records from my external database but images not displaying
      I am sincerely new in phonegap framework.  I was able to connect to my external database and displayed records in my phonegap app but the images i stored in my server are not displaying.  Please can anyone help me  figure out where the problem is coming from.
      below is my php file that retrieves records from the database
      $q = $_GET['q'];
      $sql = $db->query("SELECT * FROM pforumtopics");
         @$briefs = $nrow['briefs'];
        @$topics = $nrow['topics'];
        @$imgtopic = $nrow['imgtopic'];
        echo "<div class='colome180'><span class='curme40 themsgs'>$topics</span></div>";
         echo "<img src='$imgtopic' width='250' height='150'/>";
         echo "<div class='colome180'><span class='curme40 themsgs'>$briefs</span></div>";
      this is my xml file
      <?xml version="1.0" encoding="UTF-8"?>
      <!-- config.xml reference: https://build.phonegap.com/docs/config-xml -->
      <widget xmlns     = "http://www.w3.org/ns/widgets"
              xmlns:gap = "http://phonegap.com/ns/1.0"
              id        = "com.gdmsite.gdmapp"
        versionCode = "3"
        version   = "3.4.0">
      <name>GDM App</name>
              Gospel messages.
          <author href="http://www.gdmsite.com" email="support@gdmsite.com">
              Godwin Nwanekpe
              If you do not want any permissions to be added to your app, add the
              following tag to your config.xml; you will still have the INTERNET
              permission on your app, which PhoneGap requires.
          <preference name="permissions"                value="none"/>
          <!-- Customize your app and platform with the preference element. -->
          <preference name="orientation"                value="default" />        <!-- all: default means both landscape and portrait are enabled -->
          <preference name="target-device"              value="universal" />      <!-- all: possible values handset, tablet, or universal -->
          <preference name="fullscreen"                 value="true" />           <!-- all: hides the status bar at the top of the screen -->
          <preference name="webviewbounce"              value="true" />           <!-- ios: control whether the screen 'bounces' when scrolled beyond the top -->
          <preference name="prerendered-icon"           value="true" />           <!-- ios: if icon is prerendered, iOS will not apply it's gloss to the app's icon on the user's home screen -->
          <preference name="stay-in-webview"            value="false" />          <!-- ios: external links should open in the default browser, 'true' would use the webview the app lives in -->
          <preference name="ios-statusbarstyle"         value="black-opaque" />   <!-- ios: black-translucent will appear black because the PhoneGap webview doesn't go beneath the status bar -->
          <preference name="detect-data-types"          value="true" />           <!-- ios: controls whether data types (such as phone no. and dates) are automatically turned into links by the system -->
          <preference name="exit-on-suspend"            value="false" />          <!-- ios: if set to true, app will terminate when home button is pressed -->
          <preference name="show-splash-screen-spinner" value="true" />           <!-- ios: if set to false, the spinner won't appear on the splash screen during app loading -->
          <preference name="auto-hide-splash-screen"    value="true" />           <!-- ios: if set to false, the splash screen must be hidden using a JavaScript API -->
          <preference name="disable-cursor"             value="false" />          <!-- blackberry: prevents a mouse-icon/cursor from being displayed on the app -->
          <preference name="android-installLocation"    value="auto" />           <!-- android: app install location. 'auto' will choose. 'internalOnly' is device memory. 'preferExternal' is SDCard. -->
              Define a specific version of PhoneGap to build into your app.
              <preference name="phonegap-version"       value="3.5.0" />
          <!-- Plugins -->
          <!-- Core plugins -->
          <plugin name="cordova-plugin-battery-status" />
          <plugin name="cordova-plugin-camera" />
          <plugin name="cordova-plugin-media-capture" />
          <plugin name="cordova-plugin-console" />
          <plugin name="cordova-plugin-contacts" />
          <plugin name="cordova-plugin-device" />
          <plugin name="cordova-plugin-device-motion" />
          <plugin name="cordova-plugin-device-orientation" />
          <plugin name="cordova-plugin-dialogs" />
          <plugin name="cordova-plugin-file" />
          <plugin name="cordova-plugin-file-transfer" />
          <plugin name="cordova-plugin-geolocation" />
          <plugin name="cordova-plugin-globalization" />
          <plugin name="cordova-plugin-inappbrowser" />
          <plugin name="cordova-plugin-media" />
          <plugin name="cordova-plugin-network-information" />
          <plugin name="cordova-plugin-splashscreen" />
          <plugin name="cordova-plugin-vibration" />
        <plugin name="cordova-plugin-whitelist" />
          <!-- Third party plugins -->
          <!-- A list of available plugins are available at https://build.phonegap.com/plugins -->
              <plugin name="com.phonegap.plugins.barcodescanner" />
          <!-- Define app icon for each platform. -->
          <icon src="icon.png" />
          <icon src="res/icon/android/icon-36-ldpi.png"   gap:platform="android"    gap:qualifier="ldpi" />
          <icon src="res/icon/android/icon-48-mdpi.png"   gap:platform="android"    gap:qualifier="mdpi" />
          <icon src="res/icon/android/icon-72-hdpi.png"   gap:platform="android"    gap:qualifier="hdpi" />
          <icon src="res/icon/android/icon-96-xhdpi.png"  gap:platform="android"    gap:qualifier="xhdpi" />
          <icon src="res/icon/blackberry/icon-80.png"     gap:platform="blackberry" />
          <icon src="res/icon/blackberry/icon-80.png"     gap:platform="blackberry" gap:state="hover"/>
          <icon src="res/icon/ios/icon-57.png"            gap:platform="ios"        width="57" height="57" />
          <icon src="res/icon/ios/icon-72.png"            gap:platform="ios"        width="72" height="72" />
          <icon src="res/icon/ios/icon-57-2x.png"         gap:platform="ios"        width="114" height="114" />
          <icon src="res/icon/ios/icon-72-2x.png"         gap:platform="ios"        width="144" height="144" />
          <icon src="res/icon/webos/icon-64.png"          gap:platform="webos" />
          <icon src="res/icon/windows-phone/icon-48.png"  gap:platform="winphone" />
          <icon src="res/icon/windows-phone/icon-173.png" gap:platform="winphone"   gap:role="background" />
          <!-- Define app splash screen for each platform. -->
          <gap:splash src="res/screen/android/screen-ldpi-portrait.png"       gap:platform="android" gap:qualifier="port-ldpi" />
          <gap:splash src="res/screen/android/screen-mdpi-portrait.png"       gap:platform="android" gap:qualifier="port-mdpi" />
          <gap:splash src="res/screen/android/screen-hdpi-portrait.png"       gap:platform="android" gap:qualifier="port-hdpi" />
          <gap:splash src="res/screen/android/screen-xhdpi-portrait.png"      gap:platform="android" gap:qualifier="port-xhdpi" />
          <gap:splash src="res/screen/blackberry/screen-225.png"              gap:platform="blackberry" />
          <gap:splash src="res/screen/ios/screen-iphone-portrait.png"         gap:platform="ios"     width="320" height="480" />
          <gap:splash src="res/screen/ios/screen-iphone-portrait-2x.png"      gap:platform="ios"     width="640" height="960" />
          <gap:splash src="res/screen/ios/screen-iphone-portrait-568h-2x.png" gap:platform="ios"     width="640" height="1136" />
          <gap:splash src="res/screen/ios/screen-ipad-portrait.png"           gap:platform="ios"     width="768" height="1024" />
          <gap:splash src="res/screen/ios/screen-ipad-landscape.png"          gap:platform="ios"     width="1024" height="768" />
          <gap:splash src="res/screen/windows-phone/screen-portrait.jpg"      gap:platform="winphone" />
          <gap:config-file platform="ios" parent="CFBundleShortVersionString">
              Define access to external domains.
              <access />            - a blank access tag denies access to all external resources.
              <access origin="*" /> - a wildcard access tag allows access to all external resource.
              Otherwise, you can specify specific domains:
              <access origin="http://phonegap.com" />                    - allow any secure requests to http://phonegap.com/
              <access origin="http://phonegap.com" subdomains="true" />  - same as above, but including subdomains, such as http://build.phonegap.com/
              <access origin="http://phonegap.com" browserOnly="true" /> - only allows http://phonegap.com to be opened by the child browser.
          <!-- Added the following intents to support the removal of whitelist code from base cordova to a plugin -->
          <!-- Whitelist configuration. Refer to https://cordova.apache.org/docs/en/edge/guide_appdev_whitelist_index.md.html -->
          <plugin name="cordova-plugin-whitelist" version="1" />
          <allow-intent href="http://*/*" />
          <allow-intent href="https://*/*" />
        <allow-navigation href="https://exportgist.com/*" />
          <allow-intent href="tel:*" />
          <allow-intent href="sms:*" />
          <allow-intent href="mailto:*" />
          <allow-intent href="geo:*" />
          <platform name="ios" />
         <platform name="android" />
         <platform name="winphone" />
