6 Replies Latest reply on Jun 4, 2017 11:12 AM by gener7
    Scrubby Zoom and my Wits End
    ItsReallyCharlie
      I recently bought the adobe suite for my self, having used it on a friends computer for the last few months. My first problem has come from Photoshop randomly deleting settings and preferences, including brushes, and canvas settings. slightly annoying but nothing too major. then the scrubby zoom stopped working, also rather minor as far as problems go, but enough to torpedo my work flow and causing serious issues using the software. so I browse the forums and subreddit, trying every change I can; including edit>preferences>performance and turning off and on OpenCL, changing the drawing setting from advanced to normal to basic, all to no avail. I turned on animated zoom. I turned down the resolution of the image in-case my PC couldn't handle it. I reset my preferences using ctrl +shift +alt on start up, worked for a bit but nah, after about 10 minutes it turned off again. I feel I tried every possible combination of settings suggested by both here and reddit all for nothing.
      So the issue must be my PC right? update the drives! after the rabbit that updating them dragged me down and all for naught I decided that there must be a problem with my instillation of Photoshop, a missing file or something. so I uninstall and re-install Photoshop, nada. even older versions of both drivers and photoshop aren't working.
      What can I do at this point? just accept my fate? Give up and use something like GIMP or MS Paint? Please, you are my only hope.
      My PC Specs are;
      Intel i5-4690k at 3.5 GHz
      NVIDIA GeForce GTX 960 4095 MB memory
      8192 MB of RAM
      Windows 7 premium 64-bit
      2TB hard drive and a 111 GB SSD
        • 1. Re: Scrubby Zoom and my Wits End
          MustacheBerry
          Hey, had the same problem, you need to update you GPU drivers, go to Preferences > Performance and check box "Use graphics processor" and then if necessary check the scrubby zoom box on the top panel with the magnifying glass chosen.
          • 2. Re: Scrubby Zoom and my Wits End
            gener7 Adobe Community Professional & MVP
            I'll add this for more GPU troubleshooting options.
            Troubleshoot Photoshop graphics processor (GPU) and graphics driver issues
            One problem other than drivers are multiple graphics cards that sometimes switch to save energy. You want to keep the high-performance card for Photoshop and this document shows you how.
            • 3. Re: Scrubby Zoom and my Wits End
              ItsReallyCharlie Level 1
              when I said I had done everything I have found on the forums, I was not joking. thank you for trying to help but this was the first place I started looking for a solution 3 weeks ago when this fiasco started, I even messed around with the advanced options where suggested.
              • 4. Re: Scrubby Zoom and my Wits End
                Can you go to Help > System Info and click on the Copy button? It will put all the System Info into the clipboard and then you Ctrl v the results into your reply.
                • 5. Re: Scrubby Zoom and my Wits End
                  Adobe Photoshop Version: 2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967  x64
                  Number of Launches: 8
                  Version: 7 SP1
                  System architecture: Intel CPU Family:6, Model:12, Stepping:3 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2
                  Physical processor count: 4
                  Processor speed: 3491 MHz
                  Built-in memory: 8080 MB
                  Free memory: 4134 MB
                  Memory available to Photoshop: 6989 MB
                  Memory used by Photoshop: 70 %
                  History Thumbnails: Enabled.
                  Touch Bar: Enabled.
                  Alias Layers: Disabled.
                  Modifier Palette: Disabled.
                  Highbeam: Enabled.
                  Image tile size: 1024K
                  Image cache levels: 4
                  Font Preview: Medium
                  TextComposer: Latin
                  Display: 1
                  Display Bounds: top=0, left=0, bottom=1080, right=1920
                  Display: 2
                  Display Bounds: top=0, left=1920, bottom=1080, right=3840
                  OpenGL Drawing: Enabled.
                  OpenGL Allow Old GPUs: Not Detected.
                  OpenGL Drawing Mode: Basic
                  OpenGL Allow Normal Mode: True.
                  OpenGL Allow Advanced Mode: True.
                  AIFCoreInitialized=1
                  AIFOGLInitialized=1
                  OGLContextCreated=1
                  NumGLGPUs=2
                  NumCLGPUs=2
                  NumNativeGPUs=0
                  glgpu[0].GLVersion="4.1"
                  glgpu[0].IsIntegratedGLGPU=0
                  glgpu[0].GLMemoryMB=2048
                  glgpu[0].GLName="NVIDIA GeForce GTX 960"
                  glgpu[0].GLVendor="NVIDIA Corporation"
                  glgpu[0].GLVendorID=4318
                  glgpu[0].GLDriverVersion="22.21.13.8233"
                  glgpu[0].GLRectTextureSize=16384
                  glgpu[0].GLRenderer="GeForce GTX 960/PCIe/SSE2"
                  glgpu[0].GLRendererID=5121
                  glgpu[0].HasGLNPOTSupport=1
                  glgpu[0].GLDriver="nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um"
                  glgpu[0].GLDriverDate="20170517000000.000000-000"
                  glgpu[0].CanCompileProgramGLSL=1
                  glgpu[0].GLFrameBufferOK=1
                  glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.50 NVIDIA"
                  glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[6553 6]
                  glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
                  glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
                  glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
                  glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
                  glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
                  glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
                  glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
                  glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
                  glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
                  glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
                  glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
                  glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
                  glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
                  glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
                  glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
                  glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
                  glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
                  glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
                  glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
                  clgpu[0].CLPlatformVersion="1.2 "
                  clgpu[0].CLDeviceVersion="1.2 "
                  clgpu[0].IsIntegratedCLGPU=1
                  clgpu[0].CLMemoryMB=1297
                  clgpu[0].CLName="Intel(R) HD Graphics 4600"
                  clgpu[0].CLVendor="Intel(R) Corporation"
                  clgpu[0].CLVendorID=32902
                  clgpu[0].CLDriverVersion="10.18.10.3960"
                  clgpu[0].CLBandwidth=1.62311e+10
                  clgpu[0].CLCompute=203.391
                  glgpu[1].GLVersion="4.1"
                  glgpu[1].IsIntegratedGLGPU=1
                  glgpu[1].GLMemoryMB=1696
                  glgpu[1].GLName="Intel(R) HD Graphics 4600"
                  glgpu[1].GLVendor="NVIDIA Corporation"
                  glgpu[1].GLVendorID=32902
                  glgpu[1].GLDriverVersion="10.18.10.3960"
                  glgpu[1].GLRectTextureSize=16384
                  glgpu[1].GLRenderer="GeForce GTX 960/PCIe/SSE2"
                  glgpu[1].GLRendererID=1042
                  glgpu[1].HasGLNPOTSupport=1
                  glgpu[1].GLDriver="igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igdumdim32,igd10iumd32,i gd10iumd32"
                  glgpu[1].GLDriverDate="20140929000000.000000-000"
                  glgpu[1].CanCompileProgramGLSL=1
                  glgpu[1].GLFrameBufferOK=1
                  glgpu[1].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.50 NVIDIA"
                  glgpu[1].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[6553 6]
                  glgpu[1].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
                  glgpu[1].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
                  glgpu[1].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
                  glgpu[1].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
                  glgpu[1].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
                  glgpu[1].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
                  glgpu[1].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
                  glgpu[1].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
                  glgpu[1].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
                  glgpu[1].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
                  glgpu[1].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
                  glgpu[1].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
                  glgpu[1].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
                  glgpu[1].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
                  glgpu[1].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
                  glgpu[1].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
                  glgpu[1].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
                  glgpu[1].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
                  glgpu[1].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
                  clgpu[1].CLPlatformVersion="1.2"
                  clgpu[1].CLDeviceVersion="1.2 CUDA"
                  clgpu[1].IsIntegratedCLGPU=0
                  clgpu[1].CLMemoryMB=2048
                  clgpu[1].CLName="GeForce GTX 960"
                  clgpu[1].CLVendor="NVIDIA Corporation"
                  clgpu[1].CLVendorID=4318
                  clgpu[1].CLDriverVersion="382.33"
                  clgpu[1].CLBandwidth=8.29327e+10
                  clgpu[1].CLCompute=1062.69
                  License Type: Subscription
                  Serial number: 90970687876367785122
                  GUIDBucket:
                    bucket: 45
                    test: control
                  Application folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\
                  Temporary file path: B:\Users\Charlie\AppData\Local\Temp\
                  Photoshop scratch has async I/O enabled
                  Scratch volume(s):
                    Startup, 111.7G, 27.3G free
                  Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\Plug-ins\
                  Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\
                  Installed components:
                     A3DLIBS.dll   A3DLIB Dynamic Link Library   9.2.0.112
                     ACE.dll   ACE 2017/01/26-01:10:02   79.579975   79.579975
                     AdbePM.dll   PatchMatch 2016/11/03:19:48:57   1.578146   1.578146
                     AdobeLinguistic.dll   Adobe Linguisitc Library   10.0.0
                     AdobeOwl.dll   Adobe Owl   5.2.11
                     AdobePDFL.dll   PDFL 2016/08/10-16:53:20   79.195992   79.195992
                     AdobePIP.dll   Adobe Product Improvement Program   7.4.1.60.45263
                     AdobeSVGAGM.dll   AdobeSVGAGM   79.579975   79.579975
                     AdobeXMP.dll   Adobe XMP Core 2016/09/14-01:09:01   79.159824   79.159824
                     AdobeXMPFiles.dll   Adobe XMP Files 2016/09/14-01:09:01   79.159824   79.159824
                     AdobeXMPScript.dll   Adobe XMP Script 2016/09/14-01:09:01   79.159824   79.159824
                     adobe_caps.dll   Adobe CAPS   10,0,0,6
                     AGM.dll   AGM 2017/01/26-01:10:02   79.579975   79.579975
                     ahclient.dll    AdobeHelp Dynamic Link Library   2.2.0.1
                     AIDE.dll   AIDE 2016/05/27-01:08:49   79.574279   79.574279
                     amtlib.dll   AMTLib (64 Bit)   10.0.0.119 BuildVersion: 10.0; BuildDate: Thu Dec 22 2016 3:0:7)   1.000000
                     ARE.dll   ARE 2017/01/26-01:10:02   79.579975   79.579975
                     AXE8SharedExpat.dll   AXE8SharedExpat 2015/03/13-23:40:54   79.562390   79.562390
                     AXEDOMCore.dll   AXEDOMCore 2015/03/13-23:40:54   79.562390   79.562390
                     Bib.dll   BIB 2017/01/26-01:10:02   79.579975   79.579975
                     BIBUtils.dll   BIBUtils 2017/01/26-01:10:02   79.579975   79.579975
                     boost_date_time.dll   photoshopdva   10.0.0
                     boost_signals.dll   photoshopdva   10.0.0
                     boost_system.dll   photoshopdva   10.0.0
                     boost_threads.dll   photoshopdva   10.0.0
                     cg.dll   NVIDIA Cg Runtime   3.0.00007
                     cgGL.dll   NVIDIA Cg Runtime   3.0.00007
                     CITThreading.dll   Adobe CITThreading   2.1.0.1   2.1.0.1
                     CoolType.dll   CoolType 2017/01/26-01:10:02   79.579975   79.579975
                     dnssd.dll   Bonjour   3,0,0,2
                     dvaaudiodevice.dll   photoshopdva   10.0.0
                     dvacore.dll   photoshopdva   10.0.0
                     dvacrashhandler.dll   Adobe Audition CC 2017   10.0.0
                     dvamarshal.dll   photoshopdva   10.0.0
                     dvamediatypes.dll   photoshopdva   10.0.0
                     dvametadata.dll   photoshopdva   10.0.0
                     dvametadataapi.dll   photoshopdva   10.0.0
                     dvametadataui.dll   photoshopdva   10.0.0
                     dvaplayer.dll   photoshopdva   10.0.0
                     dvatransport.dll   photoshopdva   10.0.0
                     dvaui.dll   photoshopdva   10.0.0
                     dvaunittesting.dll   photoshopdva   10.0.0
                     dynamiclink.dll   photoshopdva   10.0.0
                     ExtendScript.dll   ExtendScript 2016/12/13-13:10:33   80.1089815   80.1089815
                     icucnv40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
                     icudt40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
                     icuuc40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
                     igestep30.dll   IGES Reader   9.3.0.113
                     imslib.dll   IMSLib DLL   10.0.0.11
                     JP2KLib.dll   JP2KLib 2017/04/05-14:24:38   79.266006   79.266006
                     libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
                     libiomp5md.dll   Intel(R) OpenMP* Runtime Library   5.0
                     libmmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
                     LogSession.dll   LogSession   7.4.1.60.45263
                     mediacoreif.dll   photoshopdva   10.0.0
                     MPS.dll   MPS 2016/09/14-15:20:26   79.577269   79.577269
                     pdfsettings.dll   Adobe PDFSettings   1.04
                     Photoshop.dll   Adobe Photoshop CC 2017   18.1.1
                     Plugin.dll   Adobe Photoshop CC 2017   18.1.1
                     PlugPlugExternalObject.dll   Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit)   7.0.0
                     PlugPlugOwl.dll   Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit)   7.0.0.67
                     PSArt.dll   Adobe Photoshop CC 2017   18.1.1
                     PSViews.dll   Adobe Photoshop CC 2017   18.1.1
                     SCCore.dll   ScCore 2016/12/13-13:10:33   80.1089815   80.1089815
                     SVGRE.dll   SVGRE   79.579975   79.579975
                     svml_dispmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   12.0
                     tbb.dll   Intel(R) Threading Building Blocks for Windows   4, 4, 2016, 0412
                     tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   4, 4, 2016, 0412
                     TfFontMgr.dll   FontMgr   9.3.0.113
                     TfKernel.dll   Kernel   9.3.0.113
                     TFKGEOM.dll   Kernel Geom   9.3.0.113
                     TFUGEOM.dll   Adobe, UGeom©   9.3.0.113
                     updaternotifications.dll   Adobe Updater Notifications Library   10.0.0.1 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   10.0.0.1
                     VulcanControl.dll   Vulcan Application Control Library   5.3.0.16
                     VulcanMessage5.dll   Vulcan Message Library   5.3.0.16
                     WRServices.dll   WRServices Thu Jan 07 2016 04:50:10   Build 0.21960   0.21960
                     wu3d.dll   U3D Writer   9.3.0.113
                  Required plug-ins:
                     3D Studio 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                     Accented Edges 18.1.1 - from the file “Filter Gallery.8bf”
                     Adaptive Wide Angle 18.1.1 - from the file “Adaptive Wide Angle.8bf”
                     Angled Strokes 18.1.1 - from the file “Filter Gallery.8bf”
                     Average 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Average.8bf”
                     Bas Relief 18.1.1 - from the file “Filter Gallery.8bf”
                     BMP 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     Camera Raw 9.10.1 - from the file “Camera Raw.8bi”
                     Camera Raw Filter 9.10.1 - from the file “Camera Raw.8bi”
                     Chalk && Charcoal 18.1.1 - from the file “Filter Gallery.8bf”
                     Chrome 18.1.1 - from the file “Filter Gallery.8bf”
                     Cineon 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Cineon.8bi”
                     Clouds 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Clouds.8bf”
                     Collada 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                     Color Halftone 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     Colored Pencil 18.1.1 - from the file “Filter Gallery.8bf”
                     CompuServe GIF 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     Conté Crayon 18.1.1 - from the file “Filter Gallery.8bf”
                     Craquelure 18.1.1 - from the file “Filter Gallery.8bf”
                     Crop and Straighten Photos 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “CropPhotosAuto.8li”
                     Crop and Straighten Photos Filter 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     Crosshatch 18.1.1 - from the file “Filter Gallery.8bf”
                     Crystallize 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     Cutout 18.1.1 - from the file “Filter Gallery.8bf”
                     Dark Strokes 18.1.1 - from the file “Filter Gallery.8bf”
                     De-Interlace 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     Dicom 18.1.1 - from the file “Dicom.8bi”
                     Difference Clouds 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Clouds.8bf”
                     Diffuse Glow 18.1.1 - from the file “Filter Gallery.8bf”
                     Displace 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     Dry Brush 18.1.1 - from the file “Filter Gallery.8bf”
                     Eazel Acquire 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “EazelAcquire.8ba”
                     Entropy 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                     Export Color Lookup Tables 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Export3DLUT.8be”
                     Extrude 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     FastCore Routines 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “FastCore.8bx”
                     Fibers 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     Film Grain 18.1.1 - from the file “Filter Gallery.8bf”
                     Filter Gallery 18.1.1 - from the file “Filter Gallery.8bf”
                     Flash 3D 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                     Fresco 18.1.1 - from the file “Filter Gallery.8bf”
                     Glass 18.1.1 - from the file “Filter Gallery.8bf”
                     Glowing Edges 18.1.1 - from the file “Filter Gallery.8bf”
                     Google Earth 4 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                     Graphic Pen 18.1.1 - from the file “Filter Gallery.8bf”
                     Halftone Pattern 18.1.1 - from the file “Filter Gallery.8bf”
                     HDRMergeUI 18.1.1 - from the file “HDRMergeUI.8bf”
                     HSB/HSL 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     IFF Format 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     IGES 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                     Ink Outlines 18.1.1 - from the file “Filter Gallery.8bf”
                     JPEG 2000 18.1.1 - from the file “JPEG2000.8bi”
                     Kurtosis 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                     Lens Blur 18.1.1 - from the file “Lens Blur.8bf”
                     Lens Correction 18.1.1 - from the file “Lens Correction.8bf”
                     Lens Flare 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     Liquify 18.1.1 - from the file “Liquify.8bf”
                     Matlab Operation 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “ChannelPort.8bf”
                     Maximum 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                     Mean 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                     Measurement Core 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “MeasurementCore.8me”
                     Median 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                     Mezzotint 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     Minimum 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                     MMXCore Routines 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “MMXCore.8bx”
                     Mosaic Tiles 18.1.1 - from the file “Filter Gallery.8bf”
                     Multiprocessor Support 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “MultiProcessor Support.8bx”
                     Neon Glow 18.1.1 - from the file “Filter Gallery.8bf”
                     Note Paper 18.1.1 - from the file “Filter Gallery.8bf”
                     NTSC Colors 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “NTSC Colors.8bf”
                     Ocean Ripple 18.1.1 - from the file “Filter Gallery.8bf”
                     OpenEXR 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     Paint Daubs 18.1.1 - from the file “Filter Gallery.8bf”
                     Palette Knife 18.1.1 - from the file “Filter Gallery.8bf”
                     Patchwork 18.1.1 - from the file “Filter Gallery.8bf”
                     Paths to Illustrator 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     PCX 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “PCX.8bi”
                     Photocopy 18.1.1 - from the file “Filter Gallery.8bf”
                     Photoshop 3D Engine 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Photoshop3DEngine.8bi”
                     Photoshop Touch 14.0 - from the file “PSDX.8bi”
                     Picture Package Filter 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “ChannelPort.8bf”
                     Pinch 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     Pixar 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Pixar.8bi”
                     Plaster 18.1.1 - from the file “Filter Gallery.8bf”
                     Plastic Wrap 18.1.1 - from the file “Filter Gallery.8bf”
                     PLY 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                     PNG 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     Pointillize 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     Polar Coordinates 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     Portable Bit Map 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “PBM.8bi”
                     Poster Edges 18.1.1 - from the file “Filter Gallery.8bf”
                     PRC 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                     Radial Blur 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     Radiance 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Radiance.8bi”
                     Range 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                     Render Color Lookup Grid 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Export3DLUT.8be”
                     Reticulation 18.1.1 - from the file “Filter Gallery.8bf”
                     Ripple 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     Rough Pastels 18.1.1 - from the file “Filter Gallery.8bf”
                     Save for Web 18.1.1 - from the file “Save for Web.8be”
                     ScriptingSupport 18.1.1 - from the file “ScriptingSupport.8li”
                     Shake Reduction 18.1.1 - from the file “Shake Reduction.8bf”
                     Shear 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     Skewness 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                     Smart Blur 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     Smudge Stick 18.1.1 - from the file “Filter Gallery.8bf”
                     Solarize 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “Solarize.8bf”
                     Spaces 18.1.1 - from the file “Spaces.8li”
                     Spatter 18.1.1 - from the file “Filter Gallery.8bf”
                     Spherize 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     Sponge 18.1.1 - from the file “Filter Gallery.8bf”
                     Sprayed Strokes 18.1.1 - from the file “Filter Gallery.8bf”
                     Stained Glass 18.1.1 - from the file “Filter Gallery.8bf”
                     Stamp 18.1.1 - from the file “Filter Gallery.8bf”
                     Standard Deviation 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                     STL 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                     Sumi-e 18.1.1 - from the file “Filter Gallery.8bf”
                     Summation 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                     Targa 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     Texturizer 18.1.1 - from the file “Filter Gallery.8bf”
                     Tiles 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     Torn Edges 18.1.1 - from the file “Filter Gallery.8bf”
                     Twirl 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     U3D 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                     Underpainting 18.1.1 - from the file “Filter Gallery.8bf”
                     Vanishing Point 18.1.1 - from the file “VanishingPoint.8bf”
                     Variance 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “statistics.8ba”
                     Virtual Reality Modeling Language | VRML 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                     Water Paper 18.1.1 - from the file “Filter Gallery.8bf”
                     Watercolor 18.1.1 - from the file “Filter Gallery.8bf”
                     Wave 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     Wavefront|OBJ 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “U3D.8bi”
                     WIA Support 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “WIASupport.8li”
                     Wind 18.1.1 - from the file “Standard MultiPlugin.8bf”
                     Wireless Bitmap 18.1.1 (2017.1.1 20170425.r.252 2017/04/25:23:00:00 CL 1113967) - from the file “WBMP.8bi”
                     ZigZag 18.1.1 - from the file “Standard MultiPlugin.8bf”
                  Optional and third party plug-ins: NONE
                  Duplicate and Disabled plug-ins: NONE
                  Plug-ins that failed to load: NONE
                  Extensions:
                     com.adobe.inapp.purchase  2.7.122 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.DesignLibraryPanel.html\purchase.html”
                     Recent Files  1.4.2 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_1_4_2_009\index.html”
                     Libraries  2.7.122 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.DesignLibraryPanel.html\index.html”
                     New Document  1.4.2 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_1_4_2_009\fnft.html”
                     Start  1.4.2 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_1_4_2_009\index.html”
                     com.adobe.experimentation.extension  2.0.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.experimentation.extension\index.html”
                     Adobe Color Themes  6.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.KulerPanel.html\index.html”
                     Export As  3.0.8 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.photoshop.crema\PSPanel\dialog.html”
                     Device Preview  1.3.1 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\com.adobe.previewHD\PSPanel\panel.html”
                     com.adobe.preview.loader  1.3.1 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\com.adobe.previewHD\PSLoader\loader.html”
                  Installed TWAIN devices: NONE
                  • 6. Re: Scrubby Zoom and my Wits End
                    I see nothing wrong off the bat. I notice you have extras like extension panels. Plugins and fonts can also cause problems.
                    While I know you paid for those panels, you can remove them and reinstall those later just to get them out of the question.
                    I'm sure you ran your disk repair utility to make sure disk errors are not involved.
                    http://blogs.adobe.com/crawlspace/2012/07/photoshop-basic-troubleshooting-steps-to-fix-mos t-issues.html is a good start and notice you can reply to this topic. Pete Green is the product manager for Photoshop and an Adobe employee if you want to folllowup.
